Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
Wiring alternatives RG6 and Welding lead
Reply
Thread Tools
Old 07-09-2009, 05:54 PM   #1
stryfe
Louisiana
08 Sport Trac XLT
Vehicle Specs
(Original Poster)
I'm considering using 4 gauge superflex welding lead for amp power and ground. Rated for very high amperage, superflexible, and cheap.....less than a dollar a foot. Anyone see a problem with this?
Has anyone used RG6 with RCA connectors to run their inputs from HU to amp?
I've always got twin RG6 Quad Shield laying around....and I could get 20 of the RCA compression connectors for cheap....maybe even free...;-)
May be a little more of a challenge routing 3 runs of RG6 twin....but probably not too bad.
What do yall think.....would it work as well as the stuff in those "amp" kits?
stryfe is offline   Reply With Quote
Old 07-10-2009, 02:50 AM   #2
Nutzon20s
Wisconsin
1997 XLT
Vehicle Specs
Depending on how much power you plan on running, its fine. If you ever plan on REAL power use 2/0 welding wire. Its the same size as audio 1/0.
Nutzon20s is offline   Reply With Quote
Old 07-10-2009, 07:35 PM   #3
Wagonized
abbotsford bc
97 5.0 limited
Vehicle Specs
Quote:
not really..1/0 welding wire is usually the same as the 1/0 car audio wire. Just the car audio stuff often has a thicker jacket. Strand count of the wire makes no difference at all other than ur flexibility which you dont really need anyway welding cable is fine for flexibility.
to the OP you can make your rcas out of anything...ive made mine out of regular 16 gauge wire before and put a clear sheath overtop of them. You can twist them up in your drill and vice too before hand if you want to look fancy like the professional ones but I dont think it really does much for keeping interference out.
Wagonized is offline   Reply With Quote
Old 07-10-2009, 08:11 PM   #4
EMG7895
'91 xlt, 93
Vehicle Specs
I would not recommend rg6 for rca cables in the car. They work great signal wise but routing them will be a pain.
EMG7895 is offline   Reply With Quote
Old 07-10-2009, 09:05 PM   #5
stryfe
Louisiana
08 Sport Trac XLT
Vehicle Specs
(Original Poster)
@ Wagonized
This particular wire has SO style jacket....so I know it'll be tough as hell...and as far as flexibility, the stuff is as floppy as cotton rope.
I would imagine the RG6 would be superior for keeping noise out....quad shielded...foil, braid, foil, braid.
@ EMG7895
I don't think routing would be too bad.....I've become pretty good @ working with the stuff. Was thinking about routing it under the center console to the back..."If" it's possible.....have never looked under there so I wouldn't know.....pretty sure I couldn't get them all under the molding....maybe if I split them up
Old 07-11-2009, 06:11 AM   #6
Nutzon20s
Wisconsin
1997 XLT
Vehicle Specs
To Dustin Page... You are correct... However, when I bought terminals for my audio 1/0 I bought 2/0 terminals, from a semi repair shop that showed me 2/0 wire that they used for repairs... I'm not a pro or anything... Just saying what I saw at the shop...
Old 07-11-2009, 09:00 AM   #7
EMG7895
'91 xlt, 93
Vehicle Specs
Quote:
Originally Posted by stryfe View Post
@ Wagonized
@ EMG7895
I've got custom rg6 quad cables in mine with neutrik connectors. Routing is not bad they fit in the wiring channel, but if the out puts n your head unit are mounted on the back and not on a pigtail, it makes it a little difficult to stuff it in the dash, but it is possible.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
