Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How To Change Antifreeze 2002 Explorer
Reply
Thread Tools
Old 07-10-2009, 03:42 PM   #1
cden
michigan city, indiana
2002 xls
Vehicle Specs
(Original Poster)
I have a 2002 Ford Explorer and I need to change the antifreeze. I do the oil changes myself but never changed the antifreeze. How hard is it? Can anyone give a step by step break down? Thanks for your help.
cden is offline   Reply With Quote
Old 07-10-2009, 07:13 PM   #2
zerodevil
Anchorage, AK
2003 XLT V8.
Vehicle Specs
Ignore/delete me!!!
zerodevil is offline   Reply With Quote
Old 07-10-2009, 07:14 PM   #3
zerodevil
Anchorage, AK
2003 XLT V8.
Vehicle Specs
very...very...very easy...just uncap the overflow tank on the firewall. then under and behind the radiator on the passenger side, there is a white plastic "nut" just turn that untill the anti-freeze starts to flow out. it will take around 10-15 minutes for the system to completely drain. If your going to flush the system, remove the thermostat(follow the hose coming from the top of the radiator to the engine). and put regular water in the engine, run it up to opperating temps, then drain it again make sure you let cool first. Mix up your new coolent (should be around 2-3 gallons) and add it to the propper level, check the level over the next few days as it will go down a little as air pockets leave the system..and dont forget to close that nut on the bottom of the radiator between the steps.
Old 07-11-2009, 08:18 AM   #4
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
the above is very good way of doing it.
For a quicker method,
do it when the engine is stone cold,
Pull the top hose first as you want to be sure you can fill it before you drain it.
Then i just pull one of the bottom radiator hoses, get ready for a big bath so have something ready to catch it. Once its drained put the hose back on.
Since this is a remote tank the only way i can figure out how to put it back is by filling it through the top hose. Once the coolant hits the thermostat its full. . .put the hose back on, fill the reservoir and run it to temp, look for leaks.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 15k
2010 Sport Trac Limited, V8 4WD, 55k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 07-11-2009, 11:31 AM   #5
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Vehicle Specs
FWIW, my cooling system has never been apart in 100K miles/seven years. I have never done a flush and my system looks brand new.
My process is to open the radiator drain cock annually (cold) and let it drain out slowly overnight (leaving the overflow tank cap off as well). I usually do this after changing the oil.
Then refill equivalent to the drained amount (I measure it) the next morning, using fresh coolant/water mixture. My cooling system looks brand new, as I never let the coolant and additives deplete, nor do I chemically shock it by using a harsh flush chemical (typically hydrazine - N2H4 - think about it), or by having a huge delta between the old and the new coolant solutions.
This is based on my experience with 'other' coolant chemistry, and it has served me well for several cars over the last two decades. I have never had a cooling system failure since going to this method, plus it is easy and cheap.
Just my .02
__________________
Wife's: '02 Limited 4.6L/4x4
Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe
EasyRhino is offline   Reply With Quote
Old 07-11-2009, 11:47 AM   #6
borland
Camarillo, CA
2002 XLT
Vehicle Specs
Because the engine block has no drains, you can only do a partial drain. Poor coolant chemistry only shows up months later as corrosion and loss of cooling efficiency.
Since you can't drain all the coolant, doing a chemical flush very difficult without destroying the coolant chemistry. You will never know how much flush chemicals are still left in the system. If you do ample water flushes to remove the chemical flush, you still don't know how much coolant to add to get a proper mix.
What I did on my 2002 XLT, was to drain and refill several times without a flush. I pre-mix 50/50 with distilled water in a plastic measuring jar prior to filling. That drain and refill does waste coolant, but perserves the coolant chemistry.
If you know the total coolant capacity, you can do the math to see how many drain and refills are needed to replace 95%.
So far my coolant system has never leaked or had a pump, thermostat failure.
borland is offline   Reply With Quote
Old 07-11-2009, 12:06 PM   #7
EasyRhino
Kailua, Hawai'i
Vehicle Specs
Agreed. You can never get all of any chemical solution out (think contaminant). If I was maintaining a '37 Bugatti, I would go after the scientific method (hinted at in your post). Instead, I am going with a modified "it will eventually fail, but extend it and minimize avoidable maintenace" method. I am going to guess that my cooling system will require replacement when the radiator/heater matrix fail (corrosive salt air here), at which point I will loose all chemistry control and start over.
Since my '02 Ex has rear heat/AC, I also have those lines and water traps to consider.
__________________
Old 07-11-2009, 10:08 PM   #8
trucku
Queens, New York and living in Budd Lake, NJ now.
trucku's Avatar
2002 Explorer XLS 4.0 4x4
Vehicle Specs
Buy the Prestone flush kit and you run your engine while a garden hose is connected. This will circulate your fresh water throughout your vehicles cooling system cleaning out all the debris. I would remove the thermostat( so you have constant high velocity of flow through your system. Your engine will be cold and a thermostat would remain closed, defeating the purpose of trying to flush it out.) before starting this procedure. If you have a drain plug on your radiator open it fully and try to adjust your water hoses flow to match the drain flow. let the truck idle with the heat set to maximum hot and you will clean everything out. If you don't have a drain plug, just open your reservoir cap and let the water out that way. You may use a chemical flush if you want the best cleaning method, but you first must drain the system, remove thermostat and fill with flush chemical and water. You will then idle/drive the vehicle for 30 minutes. You can then start your flush procedure as I mentioned above. The use of the Prestone flush kit will remove all traces of a chemical cleaner out of your system.. refill with 50/50 and your good. If you have to top off the system use 50/50 or distilled water.
__________________
2002 XLS 4.0 SOHC 4x4. Frantz Bypass filter, Mobil 1 5W30.Perma-cool dual remote (2 full flow PureOne PL30001). Perma-cool remote transmission filter (Pure One PL30001). Scanguage II, Sunpro Oil Pressure Guage
Gen 4 mirrors
"The More Complex The Mind, The Greater The Need For The Simplicity Of Play"
trucku is offline   Reply With Quote
Old 05-15-2011, 05:56 PM   #9
devlpr
Milwaukee, WI
2002 XLT
Vehicle Specs
Trucku...I have this kit but am not sure where all the pieces go...would you please snap some pics and post. Also, how do you remove the thermostat?
devlpr is offline   Reply With Quote
Old 05-15-2011, 07:48 PM   #10
trucku
trucku's Avatar
Vehicle Specs
Quote:
You want to install the right size tee into the heating core "in" line. That line goes into the vehicle and the other house will be the "out". Your top radiator hose goes into the thermostat housing.
If you have a maintenance manual, everything will be a lot easier for you.
Do a little searching the forum and you will be good to go.
__________________
Gen 4 mirrors
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
