EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How To: Replacing Upper Ball Joints on a 3rd Gen 4x4 [Pictures]
Reply
Thread Tools
Old 10-09-2010, 05:51 PM   #81
05kAwBoy700
South East, MI
'03 XLT 4wd 4.0
Vehicle Specs
Wishing I would have looked on here before I went to Auto Zone lol.........just got back home and realized the tool I have will not work. The local auto zone said they do not have adapters for the ball joint tool. Since the part number for the adapters is listed on here, i called back with the part number......imagine that, they DO have it! Headed back into town tonight, should finish this up tomorrow am.
__________________
RoadSleezy 2.5/2 Spacer Lift, K&N Intake, 255/75-17 BFG M/Ts, BWM, E-Fan
05kAwBoy700 is offline   Reply With Quote
Old 10-12-2010, 12:41 AM   #82
TAGOFFICEUSA
FT LAUDERDALE, FL
TAGOFFICEUSA's Avatar
2003 XLT
Vehicle Specs
Thanks Pot Roast
Finally, i built up the confidence to do this myself after reading Pot Roast's very impressive post. My Mechanic wanted me to buy the control arms, thank God i came across you post Pot Roast. I am attempting the front upper and lower ball joints and the sway bars as well on my 2003 Ford Explorer Xlt, 4.0 2wd. I am using Moog Parts and i also rented from Advanced Auto parts, the Ball joint press kit #940579. I want to take pics or record the whole process. I'll let you guys know how it turns out. Cheers!
__________________
Clint Rawks
Soli Deo Gloria!
TAGOFFICEUSA is offline   Reply With Quote
Old 10-13-2010, 07:45 AM   #83
05kAwBoy700
South East, MI
'03 XLT 4wd 4.0
Vehicle Specs
Aside from the ball joint press tool being a little tricky/clumsey to use, I completed all four upper ball joints (and installed a new front differential while I was at it) in my driveway with common hand tools.
I just want to add that the brain-dead SOB's at auto zone do not have any knowldge of the parts they are selling. The rear ball joints are DIFFERENT than the front, regardless of what their computer tells you. Rear ball joints are not a stocking item and had to be special ordered directly from Moog. I am in the Detroit area, so this may depend on location.
One more heads up to anyone buying ball joints: Moog joints in my area were nearly $50 each for all four. Aftermarket "duralast" brand was $33. I purchased the duralast (FA2159) for the front and it was a MOOG BALL JOINT IN THE DURALAST BOX. The very same joint pictured in the previous posts (with the splines and black boot, pressed in easily). Just a heads up, not sure if this is the same everywhere but all four joints I purchased @ AZ had Moog joints in the duralast box.
Of coarse the rear joints were incorrect and I refused to order anything else from the incompetent, unskilled, waste of oxygen behind the counter at AZ. I ordered them from AutoValue and the job is now complete.
Drive safe!
__________________
Old 10-13-2010, 07:50 PM   #84
TAGOFFICEUSA
FT LAUDERDALE, FL
2003 XLT
Vehicle Specs
Hey Guys,
Well i finally accomplished the job of removing and installing the upper , lower ball joints and sway bars. It was a challenging task. Removing and installing the ball joints were the most challenging. I used all MOOG parts from Advanced Auto. Upper BJ w/ splines cost me $78.00 a pair and lowers were $82.74 a pair. Sway bar link kit $22.56 a pair. Ball joint service set #940579. $99.00. removing the upper control arms were simple enough. I struggled to remove the driver side ball joint using the press tool manually, i finally caved and used an impact wrench to turn the bolt to press out and press in. Uppers were in ok. For the lowers i used a mini sledge to pop them out and a floor jack to help me press em in.. the whole job took me nine hours split into two days. But it's done no more noise thanks again to POTROAST, YOU THE MAN! I took some pics but it's nothing impressive like PotRoast's
. Don't let the stealership drain your 401K! Cheers
__________________
Clint Rawks
Soli Deo Gloria!
Old 10-25-2010, 11:21 AM   #85
esclamada
KCMO
'02 Mountaineer AWD V8
Vehicle Specs
Did my own ball joint replacement using this post
Here are my pictures, I just bought a set of control arms from rockauto.com. They are mevotech's.
http://www.fuzzyshot.com/fabainkc/post/42x2P92sSz
esclamada is offline   Reply With Quote
Old 10-25-2010, 06:54 PM   #86
Swp Phillies Fan
Philadelphia, PA
'02 XLS 4.0l
Vehicle Specs
Just did this job today. I replace both Front Upper Ball joints. Passenger side is perfectly fine. but my driver side is giving me fits. id press the ball joint in and reassemble the control arm. i took it out for a test drive and the ball joint popped out when making a right turn. so i tried pressing it in again and it happened again. any ideas why this is happening?
Swp Phillies Fan is offline   Reply With Quote
Old 10-25-2010, 07:17 PM   #87
zpaperboyz
Prince Rupert, BC,
2004 Ford Explorer 4x4
Vehicle Specs
Let me guess. You're using Moog Ball joints? Don't. They come in at least 3 different sizes for the same part number drove me nuts until I changed brands and its been all good ever since.
__________________
2004 Explorer - 3" lift - 265/70/17 tires - Dick Cypeck DC2-Black wheels, 17x9 (-12mm offset) - Now for sale.
$12,000CD 13x,xxx km. 250-299-5367
zpaperboyz is offline   Reply With Quote
Old 10-25-2010, 07:25 PM   #88
Swp Phillies Fan
Philadelphia, PA
'02 XLS 4.0l
Vehicle Specs
no i used napa Brand. i know the local guys there. they do look like moogs. its nice to know that theres 3 different sizes now. just having the problem with the drivers side. passengers side is just fine . went out and bought a different make. gonna try that tomorrow. hopefully it works.
Old 10-30-2010, 01:48 PM   #89
JoshMcMadMac
Waynesboro, PA
2002 Mercury Mountaineer
Vehicle Specs
I just did my upper ball joints today. If you are even the slightest bit coordinated you can accomplish the job without removing the control arms. I pressed the old ball joints out and new ones in in less than two hours, all with the control arms in place. It saves a decent amount of time and effort, as well as saving money on an alignment.
__________________
2002 Mountaineer Premier: Intake, exhaust, under-drive pulleys, electric fan, tune, GF springs, 18's, tint
JoshMcMadMac is offline   Reply With Quote
Old 10-30-2010, 02:41 PM   #90
Swp Phillies Fan
Philadelphia, PA
'02 XLS 4.0l
Vehicle Specs
Thanks for the help. went and got a different ball joint. and everythings fine now.
__________________
2002 XLS 4.0 SOHC - Stock Tint all around. 3x10" MTX subwoofers with 1000W Alpine Amp. 4 new pioneer speakers. 55w Raptor HID kit with 6000k bulbs
Old 11-22-2010, 07:02 PM   #91
frankboat
Vehicle Specs
URGENT QUESTION: IS alignment needed after replacing ball joint
Hey Guys, I am going to change my ball joints in a few days. Do I have to do a alignment after replacing upper ball joints? (The car is perfectly aligned before replacement).
PLease advise thanks.
frankboat is offline   Reply With Quote
Old 11-22-2010, 07:51 PM   #92
JoshMcMadMac
Waynesboro, PA
Vehicle Specs
If you pull the control arm off, you will need an alignment. I did it easily with everything still on the vehicle. If you press the ball joints off and on while still on the vehicle, you will not need an alignment.
__________________
Old 11-22-2010, 08:21 PM   #93
frankboat
Vehicle Specs
Quote:
Thanks for the response. My understanding is the upper control arm has two bolts to fix and there is no adjustment. If I install it back on with bolts tightened, I do not understand why I need alignment.
Replacing ball joints without taking out upper control arm sounds great. Which ball joint press kit did you use? I thought some are too big to fit in the space.
Thanks
Old 11-29-2010, 04:29 PM   #94
pet575
Kansas City, MO
2004 Limited
Vehicle Specs
Thanks to the OP for this post. Got mine done over the weekend with only one problem-couldn't get the freaking ball joint out of the steering knuckle. Tried everything-heat, beating the sh!t out of it with a mini-sledge, ball joint separator tools-nothing.
Finally got it out using a pitman arm puller to push the threads of the ball joint up and out. That and more heat. If anyone runs into this problem, give it a shot.
Thanks again!
pet575 is offline   Reply With Quote
Old 12-13-2010, 12:31 AM   #95
Jager
San Clemente, California
2004 Explorer
Vehicle Specs
Installing mine tomorrow! Spent all weekend getting my front 2.25 spacers on. Holy crap, it was quite the job...
__________________
[ 2.25 Front Spacers by BTF-Fabrication ] [ Hankook 265/75/16 A/Tm ] [ Airbox Mod w/ K&N ] [ Black Wheels ] [ ANSA Exhaust ] [ WAAG Brushgaurd ] [ Pioneer Head Unit ] [ 12" Kicker Comp ] [ Blacked Out Lights ]
Jager is offline   Reply With Quote
Old 01-15-2011, 02:47 PM   #96
jmanolop
'03 XLS 4.0L 2WD
Vehicle Specs
I got both of them greasable, are they the same? I was searching and found this:
Thanks in advance.
https://www.explorerforum.com/forums...per+ball+joint
jmanolop is offline   Reply With Quote
Old 01-17-2011, 08:54 AM   #97
emberswzd
Port Richey, Fl
2001 Explorer XLT, 4WD
Vehicle Specs
US Upper Ball joint replacement
Great post... If i ever need to change my uppers i ill definitely have this post handy. i do have a question though. i have a 2001 Explorer XLT 4WD and my upper control arm looks nothing like this. Did they change them going into the 02's?? I am also assuming that you were doing the drivers side, I assume the passenger side is stationary like the 2001's and drivers side pivots hence you didn't have to take the nut off the lower ball joint ??
__________________
If you are against Teen Violence, Gangs and worthless Judges then your a friend of mine
Yours truly Joe
emberswzd is offline   Reply With Quote
Old 01-21-2011, 11:13 AM   #98
gaw
Fort Worth, Texas
03' XLT
Vehicle Specs
Torque specs on this? Doing mine tomorrow!!
EDIT:
Found this on AutoZone site for 2WD...
Upper control arm nuts 111 ft. lbs.
Ball joint nut 41 ft. lbs.
Did mine today...thanks for the great write up...this site is such a great resource....
gaw is offline   Reply With Quote
Old 01-24-2011, 05:35 PM   #99
farsscf
Navarre, florida
2004 Explorer XLT 4.6l
Vehicle Specs
Thank you for this thread. I changed mine along with the lowers and struts this weekend. I highly recommend getting the quick struts.
farsscf is offline   Reply With Quote
Old 02-20-2011, 10:29 PM   #100
jmacattack
Texas
2004 XLT
Vehicle Specs
Did my front 2 upper ball joints today. Went with the remove-the-control-arm method. I struggled quite a bit with it. Had to recruit a friend to help. Took me ~4 hours to do both. Rented the tools from Autozone without problem.
jmacattack is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
