Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Removing cargo cage
Reply
Thread Tools
Old 07-13-2009, 08:03 PM   #1
ruthcooks
Utah
04 sports trax
Vehicle Specs
(Original Poster)
Removing cargo cage
Hi all, this is my first post, as I figured I needed help
My husband and I have been trying to remove the cargo cage from our 2004 Sport Trac. We followed the meager directions that tell you to extend the cage, loosen the clip screws, then push on the clip and lift it out of the D column. We got as far as loosening the screws. Can't figure out what needs to be pushed, pulled or tugged. Also, what is the D column? Thanks for any help you can give.
ruthcooks is offline   Reply With Quote
Old 07-13-2009, 09:10 PM   #2
Stic-o
Elite Movie Star
Tujunga, CA
Stic-o's Avatar
'99 XL 4x4 & '06 XLT 4x2
Vehicle Specs
I've never had nor played with a Sport Trac, However, here's what I do know. The D Column is probally the rear where the tailgate closes ( Your Cab would be A,B,C) The Cage should have some kind of a latch. I belive it is:
Lower tailgate.
Rotate extender toward the tailgate.
Push the tabs, at the pivot points.
Raise extender up and out.
or more detailed......
If you open the tailgate, and pull out the two pins that hold the bed extender in the "closed" (in the bed) position, then rotate the bed extender into the "open" (on the tailgate) position, you should see the two brackets that connect the bed extender to the bed (and allow it to swivel). On each of these brackets is a small T/Y-shaped piece that keeps the bed extender from coming off the brackets when you swivel it open. You can push this T/Y piece out of the way to allow the bed extender to slide off the bracket; do the same on the other side, and you should be able to remove the bed extender from the brackets.
__________________
The JP Mobile ~'99 Explorer XL
The Mall Crawler ~'06 Explorer XLT
The Tow Rig ~ '05 F-150 SuperCrew
The Commuter ~ '10 Focus SES
Stic-o is offline   Reply With Quote
Old 07-17-2009, 06:49 PM   #3
Rotorhead
Mobile, AL area (northern NJ originally)
2005 Sport Trac XLT
Vehicle Specs
I had trouble figuring it out too! If I remember correctly (I did this over 2 months ago), there are clips that you kind of need to push in to lift the cargo cage out when it is in the extended position. The clips are in the middle - half way up - the side of the cage itself.
I hope this helps; if it does not - sorry!
__________________
2005 Sport Trac XLT 4x4
Xm Radio (Roady 2)
Leer Cap
Dark Stone Metallic
Rotorhead is offline   Reply With Quote
Old 07-22-2009, 02:25 PM   #4
sickwilly
Middle Tennessee
2005 Exp Sport Trac
Vehicle Specs
There is a screw in each side that extends or retracts a piston that blocks the clip from being able to be pushed in enough to remove it. From memory, I believe the screw loosens on the opposite side of the piston that blocks your ability to push the tab in far enough to get it off. I figure this is a theft deterrent, but since I live in crime free Middle Tennessee, I just left mine in the position where you can easily get it off of the truck.
sickwilly is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
