Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
auto trans issue. wont auto go into the next higher gear
Reply
Thread Tools
Old 07-17-2009, 10:43 AM   #1
Jason1976
1992 xlt
Vehicle Specs
(Original Poster)
Unhappy auto trans issue. wont auto go into the next higher gear
auto trans issue. wont auto go into the next higher gear until the transmission warms up. I will be going about 25mph at 2k rpm and at 35 mph it is going at around 3k rpm. if i put it into low 2 then it goes at about 2200 rpm at 35mph. after it warms up it shifts good but after driving it so long then it starts to stay in to high of a gear on it's own. and i have to downshift by hand. what would make this issue happen? or what should I check.
I already replaced the transmission filter and fluid.
Jason1976 is offline   Reply With Quote
Old 07-17-2009, 04:58 PM   #2
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
If its not shifting 1-2 when cold, it could be the governor.
I'd also adjust the bands, if they need it.
Masterd is offline   Reply With Quote
Old 07-17-2009, 05:55 PM   #3
Jason1976
1992 xlt
Vehicle Specs
(Original Poster)
to tell the truth i don't even know how to do that. I was wondering if it was something simple i could do. the explorer has 115k miles. when it starts shifting good after it warms up in shifts nice. but i am wondering what would make it do that.
I am not even sure what part is the governor. I saw some parts in the bottom when I changed the filter and fluid that had wires going to them. I wasn't sure if they could be the issue or not. they look like they would be easy to replace.
Old 07-17-2009, 06:50 PM   #4
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
The wired things are the servos that control 3-4 shift and TC lockup. If the tranny acts normally when it warms up, It'd be unlikely that those two would be the culprit(s).
However, the governor (located inside the tail shaft housing) for sure causes cold shifting problems. It gets dirty and scored and wont move properly. Its not a hard job, but it takes some time none the less.
How did the fluid look when you drained it? Red / Brown / Black?
Did the filter or bottom of the pan have any residue or metal shavings?
Old 07-17-2009, 06:52 PM   #5
Jason1976
1992 xlt
Vehicle Specs
(Original Poster)
it was red. with some flakes. I cleaned the bottom of the pan good before I put it back in. but remember i said after it gets to warm then it doesn't want to down shift right. but if i turn the motor off and stop and put it back into gear then it will shift good again. sometimes i have to step on it to get it to down shift and other times it wont and I have to put it in low one or low two on my own. I dont know enough about them to take the housing apart. looks like I will have to take it to the garage. some days it doesn't act up for staying in to high of a gear and other days it does.
Old 07-17-2009, 07:06 PM   #6
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
Sounds like a band adjustment might be a good start then.
The only time I've ever had the tranny not downshift right is when the governor was bad and it was cold....IF it would shift to 2 by itself, it wouldn't always auto shift back to 1 until it warmed up.
Old 07-19-2009, 09:25 PM   #7
Jason1976
1992 xlt
Vehicle Specs
(Original Poster)
it doesn't like to downshift until it's warm enough. today i didn't drive far and i slowed down shortly after it started to up shift and it wouldn't downshift. I had to put it down in low two when i made a turn and started to go up a hill. then i put it back in over drive right away and it was fine after that. could the transmission computer make this happen or the speed censer? I don’t think its anything to do with the bands. I can stop and put it in park when it doesn’t want to down shift right and put it back in drive and it still acts up. But if I turn the explorer off and restart it and put it in drive then it will act normal again. Of course this is after it’s been warmed up.
Old 07-19-2009, 09:38 PM   #8
Masterd
Upland, CA
1993 Explorer Sport
Vehicle Specs
Try adjusting the kickdown cable then as well.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
