Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
2005 Explorer with a front end noise.
Reply
Thread Tools
Old 07-20-2009, 04:13 PM   #1
MJuul
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have a 2005 explorer every time I go over a bump it makes a squeeky sound from the front end kinda like an old matteress spring, is it shocks or do the bushings need replaced?
MJuul is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-20-2009, 04:35 PM   #2
kshicks
Inner-City Detroit (USAF stationed in Germany)
2002 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
More than likely it's the bushing. I had the same problem going slow over speed bumps. Changed the front and rear swaybars with a full Eibach kit w/urethane bushings. Sound never came back....good luck!
__________________
(2002 Ford Explorer XLT 4.6L V8) MAC Intake, SCT X3 Custom Tuned by BamaChips, Gibson Catback Exhaust, Steeda Underdrive Pulleys, Trickflow Upper Intake Plenum, Crossdrilled/Slotted Rotors, Ground Force Springs, Eibach F+R Swaybars, 22" Rims
Waiting to receive and install Fox Lake Stage II Heads and Comp 272 Cams & Springs
My Ride is @ http://www.cardomain.com/ride/2928736
kshicks is offline   Reply With Quote
Old 07-20-2009, 08:59 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! I've moved your thread to the stock 2002-2005 section. Any part that is worn is going to squeak.
BrooklynBay is online now   Reply With Quote
Old 07-20-2009, 09:16 PM   #4
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Vehicle Specs
Quoted: 0 Post(s)
Front sway bar bushing squeak is a common niusance on these.
To confirm (and silence it short term), spray these bushings (two of them) with WD-40. The squeaking should go away.
This is what I am doing until a convenient time to replace them.
__________________
Wife's: '02 Limited 4.6L/4x4
Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe
EasyRhino is offline   Reply With Quote
Old 07-21-2009, 02:53 PM   #5
frankjc
Massachusetts
2005
Vehicle Specs
Quoted: 0 Post(s)
I've been spraying mine with WD40 every once in a while. Keeps coming back. I guess I'll change the bushings eventually.
__________________
2005 Explorer
1995 Lincoln Mark VIII
1988 Harley-Davidson
frankjc is offline   Reply With Quote
Old 07-21-2009, 03:05 PM   #6
XCAMP
2005, XLT
Vehicle Specs
Quoted: 2 Post(s)
Mine was doing it and I sprayed them with WD-40, it stopped it. Just look in the wheel well and they are right there.
XCAMP is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
