Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Uneven front brake pad wear
Reply
Thread Tools
Old 07-28-2009, 12:14 AM   #1
XedLos
Souther California
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I took a look at the brake pads on my explorer and the front inner pad has more wear than the outside one. What can be casuing this? Im gonna have to replace them and i wanted to do it myself. I tried looking for a how to but i didnt find one. If any one knows of a thread with pics prefrably id appreciate it. Or just give me a quick rundown of waht to do. I really have never done this stuff myself so sorry if it seems like a dumb question.
XedLos is offline   Reply With Quote
( Join the Elite Explorers )
Old 07-28-2009, 12:24 AM   #2
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 79 Post(s)
Nah we all gotta start somewhere, theyre really easy if you have the patience, I did mine with no knowledge of what i was doing hahaha, but im thinking that maybe one of your calipers could be sticking a little, OR you have uneven rotors,
when you stop, does your pedal vibrate or shake, with your explorer?
__________________
06 Charcoal Beige XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, Tan cloth interior swapped w/black carpet, black leather/power/heated seats from a Limited, iPad Mini installed in the dash
My iPad Dash Install Thread
BrianDye is online now   Reply With Quote
Old 07-28-2009, 12:31 AM   #3
XedLos
Souther California
96 Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It doesnt shake at all. It feels normal.
Old 07-28-2009, 12:37 AM   #4
BrianDye
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 79 Post(s)
Well your rotors seem fine then, im no brake genius but you can usually feel even the slightest bit if your rotors warped or anything, maybe the outter pads were just replaced, and the inners werent, do you have any pics?
__________________
Old 07-28-2009, 12:51 AM   #5
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
Quoted: 0 Post(s)
They kind of ride along two bolts. That system has to be free to do that for starters. There are two bolts holding the actual caliper housing to the spindle area. Then there are two more longer bolts that are intended for the break caliper to slide freely on, as it does its work. With that said there is another phenomena that can cause this problem. If you live in a sandy, muddy area such as in the south, the mud may be getting on the inside creating a sandpaper effect. There should be no looseness indicating a bad bearing as someone said.
If the brakes haven't been bled in a while then you will want to do that first. By nature air gets in the fluid somehow, and can change normal brake behavior. Old brake fluid can exourbe moisture, and its designed to do that, which can cause irregularities as well. That's why we bleed brakes regularly.
Have you inspected the rotors? They might tell you a story. At the end of the day brakes are fairly cheep and calipers are expensive. While you have the wheel off shake the calipers to check for looseness. Then see if it can move right to left as it would be needed in driving. You can get some idea about the warpage on the rotors at this time. They should spin relatively freely with very little drag on either side.
robertoa1a is offline   Reply With Quote
Old 07-30-2009, 02:02 PM   #6
Neil1750825
Brookings, SD
1997 Explorer XLT SOHC
Vehicle Specs
Quoted: 0 Post(s)
I might suggest that you have a vacuum leak or at least weak vacuum. I believe vacuum is what releases the brakes and pulls them away from the rotor. It may be that the vacuum isn't strong enough to pull the pad all the way off the rotor and therefore you are left with dragging brakes. That would explain the one side wearing harder than the other. Just a thought.
Neil1750825 is offline   Reply With Quote
Old 07-30-2009, 06:45 PM   #7
Heavymentill
Ann Arbor, Michigan
Heavymentill's Avatar
96 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Not true.
__________________
Heavymentill is offline   Reply With Quote
Old 07-31-2009, 12:17 AM   #8
chance942
B
Las Cruces, NM
2000 Sport sohc con trac
Vehicle Specs
Quoted: 0 Post(s)
right to left or in and out? does the caliper have a death grip on the rotor? like he said,it should turn rather freely.
chance942 is offline   Reply With Quote
Old 07-31-2009, 12:24 AM   #9
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Slide pins need to be lubed. Brake how to vid in my sig.
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
