laxmankk11
- May 15, 2009
- damascus. md
- 99 Eddie Bauer
My trans has what i think may be the 2-3 shift flare but its so bad i dont know for sure. when i accelerate my car lurches forward between 2-3 once then you can tell its not completely in gear, then it does it again, even worse, and my RPMS just to about 3500 even if i was only at 2000. also, it wont shift into o/d. and when i floor it, it used to drop a gear at 3000 rpms but now it just tries to keep going in whatever gear its in, and i have NO power. this is all with the o/d light off
sometimes it randomly comes on, it has since i got the truck about two months ago. when the o/d light comes on, it does not have the shift problem and even goes into o/d. the only problem is you can really feel it shift hard like its being forced. last time i had the code read, it said it was p0741 the torque converter i believe. but that was awhile ago, it just started getting bad again after i went through a little river about a foot deep. had oil and trans fluid flushed immediately after thinking there was water in it but theres not. shop told me my trans would die in a year but im taking it to a specialist next week, i think it just needs a new valve body. anyone have any ideas?
also is there a thread on here the tells you everything that happens when the o/d light comes on? i know it goes into limp mode, but i dont know exactly what that intales.
thanks.
thanks.
