EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
HELP! M5 Shift Rail Plugs
Reply
Thread Tools
Old 08-01-2009, 02:22 PM   #1
doonze
Fayetteville, Ar
'93 X Sport
Vehicle Specs
(Original Poster)
Ok, I've heard about the 3 plugs on top of the shift rail that fail, I'm having a bit of fluid leaking out from what seems the top of the M5 tranny. Now where the heck are these things??? I've looked around and see some stuff on the sides and bottom, but I can't see any part of the top of this thing... How the heck do you get to them, even to check them??? Also anyone know where you can get the replacement metal plugs.
I searched for this stuff, and found lots of threads talking about them, but no how-to or instructions or anything. I know they are supposed to be on top, behind the shift rails, kinda facing the rear or something...but I don't see a way to get to em! Or check em! Any ideas? I'll post a how to if I do this thing.
doonze is offline   Reply With Quote
Old 08-01-2009, 03:03 PM   #2
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
(attached image)
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 08-01-2009, 03:06 PM   #3
glfredrick
"The Pastornator"
Louisville, Kentucky
glfredrick's Avatar
86-98 Ranger STX
Vehicle Specs
Have to lower the crossmember to see them. Common fix is to replace the rubber plugs with steel cup plugs (like engine frost plugs). May have to pull the transmission to really do the fix.
Also, make sure you run the RIGHT oil. Many guys make the mistake of running gear oil. It takes auto transmission oil. Check the manual.
__________________
glfredrick is offline   Reply With Quote
Old 08-01-2009, 04:58 PM   #4
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
http://www.explorerforum.com/Singlet...es/manual.html
http://www.therangerstation.com/tech...aintenance.htm
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is offline   Reply With Quote
Old 08-01-2009, 11:45 PM   #5
doonze
Fayetteville, Ar
'93 X Sport
Vehicle Specs
(Original Poster)
Hmmm..... Does anyone know if we can get to ours from the cab too? It looks like it should be almost right under the shift boot, unless I'm mistaken. I haven't had mine off, if anyone has let me know what's under there! LOL, I might just pull mine and see anyway!
Old 08-02-2009, 04:06 PM   #6
Tshark299
Upstate NY
'93 XLT
Vehicle Specs
You can get at them by just removing the shift boot and upper shifter. I just re-sealed mine last week by doing it that way. I used a flat screwdriver to pry them out. Then I degreased them, and then coated them with a bead of RTV after they dried. I used needle-nose pliers to lower them down and back into their holes. After letting them cure overnight I haven't had a leak since.
__________________
'93 Explorer XLT 4x4 5-speed
Tshark299 is offline   Reply With Quote
Old 08-02-2009, 05:18 PM   #7
Freshmeat
Denham Springs, LA
1994 Ranger STX SC
Vehicle Specs
I'm glad I found this before I installed my transmission- plugs are ordered, will be installed Wednesday. I'd have hated to install it and then have to deal with it leaking everywhere.
__________________
2012 Wrangler Unlimited: Deep Cherry, Auto, 3.73s, Rock Krawler 2.5" Max Travel, Procomp shocks, JKS Discos, Rubi rails, A.C.E. sliders, EVO ProTek Skid System, EVO Rockstars, PSC Brawler Lite with stinger and grill hoop, ENGO 10k with synthetic, 35x12.50-15 BFG KM2s, MOPAR flat flares.
1994 Ranger STX SuperCab: 3.0, M5OD, under the knife.
Freshmeat is offline   Reply With Quote
Old 08-02-2009, 08:32 PM   #8
Brian1
Albuquerque, NM
Brian1's Avatar
1991 XLT
Vehicle Specs
Here are a few pics and a short writeup I did several years ago when I did mine: http://home.comcast.net/~explorer4x4/tech.htm
Brian1 is offline   Reply With Quote
Old 08-02-2009, 09:06 PM   #9
Freshmeat
Denham Springs, LA
1994 Ranger STX SC
Vehicle Specs
Brian1, thanks for the post- saw a couple other tips on your page that I may try to knock out this weekend, as mud is a primary ingredient in most of the local trails.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
