Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
removing fuel lines
Reply
Thread Tools
Old 08-07-2009, 09:50 PM   #1
sean1rice
LP City, MD
sean1rice's Avatar
1994 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
removing fuel lines
So I'm replacing the entire fuel sending unit submerged in the gas tank on my 1994 explorer sport ... and I'm up to the point where I've exposed the top of the sending unit ... Now I need to disconnect the lines.
So I'm wondering if I need to first remove the top L-shaped metal bracket thingy before attempting to use the quick release tools I rented from the auto parts store.
I guess I will use the long blue tool shown below? (It also has a red, different-sized one)
Also since I'm replacing the whole thing, I think it might be easier to get the tools in there if I completely break off the rusted tubing that the lines connect to on the sending unit (thats where the leak is, why Im doing this) Is that a good idea?
... thanks
sean1rice is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-08-2009, 03:46 AM   #2
arco777
arco777's Avatar
1994 Explorer 2dr 4x4
Vehicle Specs
Quoted: 99 Post(s)
re:
The metal clips are just retainers, they should pop off easily with your fingers or the aid of a large flathead screwdriver. As I recall in the Ford Dealer Service Manual it says to replace those any time you remove them but that's your call, if they're in good shape and have tension they'd probably be fine to re-use. Remove them first, then the line disconnect.
arco777 is offline   Reply With Quote
Old 08-08-2009, 11:43 AM   #3
sean1rice
LP City, MD
sean1rice's Avatar
1994 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Wonderful thank you ... I guess I'll just snap off those rusty metal lines that I'm replacing so I can get in there. How about the tool, I guess you use the tool to squeeze that barrel-type thing under those clips?
Old 08-08-2009, 02:57 PM   #4
nitro71
Spokane WA
Vehicle Specs
Quoted: 0 Post(s)
That's a nifty looking tool! If it won't fit you can buy some small cheap plastic ones at the auto parts store. Be ready to get coated in gas!
nitro71 is offline   Reply With Quote
Old 08-08-2009, 03:28 PM   #5
fixxxer
Aurora, Co.
93 XLT 4X4
Vehicle Specs
Quoted: 3 Post(s)
I don't know about you, but from the pic, that small black tool just above the long blue one looks like it would work on the fuel-filter couplings and possible the fuel lines there at the pump.
__________________
-Larry
93 XLT 4x4
90 Celica GTS
97 Camry
fixxxer is offline   Reply With Quote
Old 08-08-2009, 03:46 PM   #6
sean1rice
LP City, MD
sean1rice's Avatar
1994 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
oh yea? That one is kinda weird, it snaps apart into two sides ... then I have two pieces that do not click together to form a round-type wrench thing as you would expect.
With either tool, whats the goal, to squeeze the barrell thing, or use the tool just behind the barrell thing?
Old 08-08-2009, 09:25 PM   #7
Anime
EF YEAH!!
Anime's Avatar
2016 EX Sport Concept
Vehicle Specs
Quoted: 181 Post(s)
Pop off the metal L-bracket. That's just a retainer to prevent any chance of the fuel fittings coming apart.
The goal of the fuel line disconnect tools is to expand the tiny retainer fittings INSIDE the metal retailer sleeve on the end of the hose. It won't be any easier if you hack of the lines from the fuel pump assembly, except maybe for getting a better angle with the tank out of the way.
Just keep shoving the tool in there and push the line towards the tool, usually one of the lines takes a lot more work than the others, but if the tool is deep enough, the fittings disconnect and pop off in a snap.
Be sure to replace the entire fuel pump assembly. You can get new ones with the fuel pump and filter attached for just a little more than you'd pay for a pump. Some of them are even stainless steel unlike the factory steel assembly that rusts as pictured.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is online now   Reply With Quote
Old 08-09-2009, 12:41 AM   #8
sean1rice
LP City, MD
sean1rice's Avatar
1994 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
OH! ... I think I got you ... the tool tries to slide under the metal cylinder thing from the rubber side of the line ... I'm not trying to squeeze the metal sleeve thing (or anything else ... it's more of a pushing and sliding thing) . .. am I correct in saying this?
Old 08-29-2009, 03:22 PM   #9
jpp50
endicott ny
91 XLT
Vehicle Specs
Quoted: 0 Post(s)
91 ford explorer xlt flex fuel line
sean1rice,
I just rented the same fuel line removal tool kit that your post shows.
Did you use the black plastic tool that has two half round pieces on each end of it to disconnect the connector on the end of the flex line and if so could you detail how you used it?
Thanks
jpp50
jpp7928@yahoo.com
jpp50 is offline   Reply With Quote
Old 09-09-2009, 01:03 PM   #10
sean1rice
LP City, MD
sean1rice's Avatar
1994 Explorer sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Originally Posted by jpp50 View Post
sean1rice,
Thanks
jpp50
jpp7928@yahoo.com
I went out and bought a metal one for 7 bucks, shaped kinda like a pair of sissors, with on size on one end and the other size on the other end. I was afraid of breaking the tool kit i rented, which was 90 bucks. The metal one worked pretty easily.
- Sean
Old 07-05-2011, 02:13 PM   #11
Keshet
Clearwater, FL
1994 Ranger
Vehicle Specs
Quoted: 0 Post(s)
Fuel Lines in 1994 Ford Ranger
I took all the fuel lines off getting the Gas tank out.. and forgot which line goes into which one.. Anyone have a picture? Or can tell me.. One has a hard plastic '90 on it.. and the other doesn't.. The middle Feed line into the Fuel pump sending unit, I expect needs to be the one going directly into the in-line Fuel Filter.. is this correct?
-Mike C.
Keshet is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
