coheed
- November 18, 2008
- '94 4x4 v6
Tried searching, and couldn't find much info on this type of problem...
I just got my Ex back on the road from replacing the fuel pump. I took it for a couple of test drives, and after I'm satisfied that all is well, I return home, pull into my drive, go to put it into "P" (park) and the gear selector just flies right into park... Normally I feel the bumps/notches along the way through reverse and neutral, but now the gear selector just feels "loose". Needless to say, it's not working... my Ex is stuck in drive, and I had to just turn the engine off while it's in gear so that I could remove my foot from the brake.
I've tried fiddling with it, and I cannot get it into Park. The gear selector does move around and I can tell when it's "supposed" to be in gear, but the weight behind actually shifting the transmission is gone, if that makes sense.
Does anybody have any suggestions on where to start!? It's blocking the driveway!
