#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
05 explorer loud humming noise while driving
Reply
Thread Tools
Old 08-13-2009, 12:24 AM   #1
brian smith
lufkin tx
05 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
last few weeks my wife has been complaining that her explorer has been making a funny noise. I just figured she was making a big deal out of nothing. So today, after her nagging me about it I went out and took it for a drive. Sure enough, its making a loud humming sound as i drive it. It doesnt matter if its low speed or highway it makes the same humming sound. Any ideas on what it could be. It has been maintained very well and it has about 70,000 miles. Its V6 and 2 wheel drive
brian smith is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-13-2009, 08:19 AM   #2
Layinhp
CANADA BEST PLACE ON EARTH
2002 XLT v8
Vehicle Specs
Quoted: 0 Post(s)
Quote:
at a resonable speed swerve left and right does the noise go away and come back as you straighten out......
humming sounds like a wheel bearing
Layinhp is offline   Reply With Quote
Old 08-13-2009, 10:12 AM   #3
34Ford
North Carolina
2002 EB 4.6
Vehicle Specs
Quoted: 0 Post(s)
Jack up the front and see how hard it is to spin the wheels.
Sounds like a bearing. I've been there. Bought a hub on Ebay and saved some bucks.
__________________
Dennis
'03 Mustang Mach 1
'02 Explorer Eddie Bauer 4.6
'01 Lincoln LS
34Ford is offline   Reply With Quote
Old 08-13-2009, 10:41 AM   #4
brian smith
lufkin tx
05 explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok I'll jack the front up today and spin the wheels. Your saying that if they dont spin freely then its safe to assume its a wheel bearing. I guess i should try all four and see which one is not spinning free huh?
Old 11-01-2009, 05:45 PM   #5
Michael B
Waterford MI
2005
Vehicle Specs
Quoted: 0 Post(s)
Did you ever get the noise fixed? My wife's Mountaineer is making the same noise and I can't diagnose the issue. I changed the right front CV shaft and that wasn't it. I want to think it is a wheel bearing but I don't know. I checked the drive shafts and joints and they feel good. The noise begins at around 12 mph doesn't change noise levels when I turn left or right. The noise gets louder the faster I go but doesn't get any louder over 50 mph. Any insight on this would be appreciated.
Thanks,
Michael
Michael B is offline   Reply With Quote
Old 11-07-2009, 12:20 PM   #6
merc187
Overland Park, KS
2003 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp
Bump - Same issue
__________________
MERC187
merc187 is offline   Reply With Quote
Old 11-07-2009, 12:25 PM   #7
Michael B
Waterford MI
2005
Vehicle Specs
Quoted: 0 Post(s)
Just changed both front wheel end bearings - did not do the trick... I don't know where the noise/vibration could be coming from. Anyone?
Old 11-07-2009, 11:21 PM   #8
clarks2001
Ashburn, Virginia
2002 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
are you sure its coming from the front? might wanna check the rears. also could be the differential problem lots of people seem to have. I have a humming coming from my rear differential and from what i was told (by a shop) it sounds like bad bearings in the differential.. i dunno
clarks2001 is offline   Reply With Quote
Old 11-08-2009, 12:31 AM   #9
merc187
Overland Park, KS
2003 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
I have been tossing that idea around as well. I had my rear diff seal blow out on me at the beginning of the year. I was hauling a boat to Arkansas when it happened. I had read a post about front diff bearings going out. As hunting season is upon me that check will have to wait.
__________________
MERC187
Old 11-13-2009, 07:59 PM   #10
jsteele90
oceanside,ca
02 xlt
Vehicle Specs
Quoted: 0 Post(s)
wifes 02 explorer does this. the noise stops while going through right hand corners. no idea what it could be
jsteele90 is offline   Reply With Quote
Old 11-13-2009, 08:03 PM   #11
muhl5443
Minnesota
muhl5443's Avatar
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
are your tires balanced? if they are outta balamce that could cause it
__________________
'98 xlt 4.0 sohc
31" bf goodrich all terrain t/a tires
2" TT
REAR SHACKLES
message center mod
vent visors & bug deflector
muhl5443 is offline   Reply With Quote
Old 11-13-2009, 08:12 PM   #12
jsteele90
oceanside,ca
02 xlt
Vehicle Specs
Quoted: 0 Post(s)
i have a feeling for my problem its going to be the right side rear wheel bearing. wonder how big of a pita this is going to be.
Old 11-30-2009, 05:00 PM   #13
XCAMP
2005, XLT
Vehicle Specs
Quoted: 2 Post(s)
The rear differential whine is different... it only occurs at certain speeds, for example mine happens between 50 - 60 mph and if you let off the gas, it stops.
XCAMP is offline   Reply With Quote
Old 12-06-2009, 02:20 AM   #14
markedman450
Enola, PA
01 Sport
Vehicle Specs
Quoted: 0 Post(s)
I have a slight humming too, but when i put it in 4 wheel drive it gets extremely loud and feels like a grinding. Could it be the front differential fluid? Or would mis matched tires also cause this. For summer i had 255/70/16 in the back and 245/70/16 in the front. I figured in snow the difference would matter and the tires would slip but its def grinding bad.
markedman450 is offline   Reply With Quote
Old 12-06-2009, 04:21 PM   #15
bobbronco
B.C.
2003 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Quote:
If you are running different size tires on the front and back and you have 4 x 4 then you are heading for trouble. The diameter size of the tires matters. The reason being because your crown gears in the front and rear differentials are the same gear tooth- in other words if the rear has 3:55 to 1 then so does the front. If it has 3:27 to 1 then so does the front.Running 255/70 on rear and 245/70 on front MAY be enough to cause the rear crown to rotate at different RPM than the front crown with 245/70 on when in 4x4. Something to keep in mind when you turn corners.
bobbronco is offline   Reply With Quote
Old 12-06-2009, 05:58 PM   #16
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
i agree with xcamp. I had my rear end make noise. There is a tsb out there for it as it replaces the ring and pinion and switchs to thicker fluid.
Mine made noise after it warmed up, go about 50-60mph and let off the gas it would go away, tap the gas lightly and you could hear it, let off and it goes away.
good luck
jakedrew is offline   Reply With Quote
Old 12-07-2009, 10:03 AM   #17
lbstratford
Vehicle Specs
Quoted: 0 Post(s)
wheel hub bearing. I also experienced this and had it replaced.
lbstratford is offline   Reply With Quote
Old 12-07-2009, 01:42 PM   #18
20Exploder02
Virginia Beach, Virginia
'02 Limited
Vehicle Specs
Quoted: 0 Post(s)
i agree wit bobbronco aswell...also some of the 02-05 explorers in the rear had a bit of a mix up as mine did. some of the gears in the rear the teeth were manufactured wrong thus making a humming sound from the rear and ford did not address that problem. i had to replace my ring an pinion an went ahead an replaced races, braces an serviced the rear end and the humming sound went away. so if you replace the rear wheel bearings an the sound is still there its your rear differental.
20Exploder02 is offline   Reply With Quote
Old 12-09-2009, 01:11 AM   #19
02X
02
Vehicle Specs
Quoted: 0 Post(s)
Humming noise
Having the same humming noises coming from the front end (driver side). I replaced the wheel bearing and noise did'nt go away. Also, rotated wheels (did'nt make a difference) and checked diff oil (it was full) Is there something else i should look at? wondering if it could be a u joint?
thanks for all the input!
02X is offline   Reply With Quote
Old 12-09-2009, 01:15 AM   #20
rhauf
Ca
'93 and '91 explorer
Vehicle Specs
Quoted: 0 Post(s)
if you're still having trouble locating the noise, after driving it for a while, park it and feel for abnormally hot parts, friction = heat. so if one hub is far hotter than the other, it could be a sign there is a bearing bad in it and that's you're culprit. also, you're differential could be the problem too, i've had dif's make sounds very similar to what you're describing, if they're bad enough they'll do it at pretty much any speed. check dif fluid and see if it looks normal... if it looks silvery (full of metal dust) that would indicate a problem too.
good luck
rhauf is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
