EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
"How to" '02 explorer rear wheel bearing replacement (pictures)
Reply
Thread Tools
Old 01-20-2012, 12:09 AM   #261
Pontisteve
Florida
03 Eddie Bauer 4WD V8
Vehicle Specs
You would be well advised to have them score or cut into the outer race, to weaken it before trying to press it out, if it doesnt want to come out. At least one member broke the spindle with the press. Those outer bearings are really stuck in there! I believe they may have used loctite for bearing races from the factory.
Also, be careful how you support the spindle in the press. Don't put too much stress on the arms of the spindle. Keep the support near the middle around the bearing. And read carefully about how to press the new bearing in!!
__________________
EFI Tuner
SCT Dealer and Certified Tuner
Pontisteve is offline   Reply With Quote
Old 02-02-2012, 01:54 PM   #262
DVRDOWN
West Palm Beach, FL
'02 XLT Flex Fuel 4x4
Vehicle Specs
Quote:
Originally Posted by Pontisteve View Post
After reading Toms method, it sounds great to me. Just a couple thoughts to add. 1) By REMEMBERING when to put the backing plate back on, you don't have to cut the backing plate to do this job, which is great. I remember now... that I had forgotten to reinstall the backing plate at the appropriate time. That was why I had to cut my backing plate to install it... the hub was already pressed in. And pressing the new hub back out would probably ruin the new bearing!
Ok, the owner of the truck before me for some reason decided to just remove the parking brake from the passenger side altogether where i'm working. If i pull the backing plate off the knuckle, do i even need to bother reinstalling it if I dont even have any of the e-brake componants?
Where i use to live i was spoiled and had a buddy who was a Ford tech, so $100 and he'd do the whole job for me in an hour. So now its my turn - and yes this is #7 on my RR!
__________________
2002 XLT 4x4 4.0 Flex, 115K miles
DVRDOWN is offline   Reply With Quote
Old 02-02-2012, 07:47 PM   #263
Pontisteve
Florida
Vehicle Specs
#7 on my RR??
The parking brake cable attaches thru a hole in the spindle, and spreads the brake shoes apart when applied. As long as the parking brake cable is still there, I would return that system back to stock. Chances are that the prior owner just didn't know what he was doing, got frustrated trying to put the brakes back on, and gave up. Now's your chance to fix that.
The parking brake system is comprised of the parking brake cable, the backing plate, the shoes, the hardware kit (springs and holddown hardware, and the self-adjuster), the rotor (which acts like a drum on the inside), and that's about all I can remember. If you have the cable still on the vehicle, and you have the backing plate, then all you're really missing is the shoes and the hardware kit.
Even if you didnt' put the parking brake stuff back on, you should retain the backing plate so that they can be fixed in the future. Otherwise, you would have to reinstall a new bearing, or cut the backing plate in half to fix it. Just remember to put the backing plate on (as a whole) before you press the bearing back in.
__________________
EFI Tuner
Old 02-06-2012, 08:29 PM   #264
Mach 1 Pilot
Ryot, PA
'02 4.6 4x4 XLT
Vehicle Specs
Just completed this repair today
Thanks to everyone who posted their experiences, it helped me quite a bit in looking for possible trouble spots and to confirm the tools needed. I completed a change of my RR bearing this morning... took 2.5 hours including a trip to the hardware store for more antiseize because my bottle was empty. The hardest part was finding something just the right size to press out the outer race because the inners fell out. That took about an hour. Thankfully everything else came apart and went back together rather easily.. this vehicle was originally from North Carolina so it doesn't have the usual PA rusty components.
FWIW, Advance Auto has National bearings for $56 + tax. Online Amazon has Timken for $58.20 free shipping, but the difference wasn't worth the wait. Everyone else around here had the no-name bearings for more money!
Mach 1 Pilot is offline   Reply With Quote
Old 02-07-2012, 01:40 AM   #265
Pontisteve
Florida
Vehicle Specs
Those are really good prices! Did they come with a new snap ring and hub? Or did you have to re-use the old ones?
And what did you find to use to press out the outer race?
__________________
EFI Tuner
Old 02-07-2012, 09:48 PM   #266
Mach 1 Pilot
Ryot, PA
'02 4.6 4x4 XLT
Vehicle Specs
The price was just for the bearing, a National 516008.. And I need to correct myself a just little.... $56.99 + tax = $60.41. I reused the hub and snap ring.
Timing wise, it helps to have done something similar before.... just changed two of bearings about 4 months ago in the front of the wifey's Focus. And I have a 40 ton press in the shop, so no running for one of those.
As for the tool to press it out, I ended up finding and using a large 2 3/16", 3/4" drive socket. Whatever you use, it needs to be about 3" in diameter and fairly heavy to handle the load of the pressing action. The gauge on my press showed the peak pressure to be 12 ton. Not sure how accurate it is, though!
I drove it a bit this evening... still can't believe how much quieter it is with this changed!
Thanks again to those who posted before me, the pictures and experienced helped quicken my pace and make the experience easy!
Old 02-13-2012, 12:36 AM   #267
bottechia
2002 ford explorer Ltd
Vehicle Specs
My bearing was seized on the rear passenger side had a hard time just pulling the hub off the axle spindle. Thank goodness I had a big impact gun to use on the hub puller for some serious torque.
Machine shop guy had a hard time pressing the hub off too, said he had to cut the hub off.
This forum made the job go so smooth with all the tips
I took the advice to torque axle nut at 175 rather then 203 seems a little much.
My Explorer sounds so quiet now almost like it was when new.
bottechia is offline   Reply With Quote
Old 02-13-2012, 10:49 AM   #268
naz123
Fl
2003 explorer lmtd
Vehicle Specs
can this work
tackling job this weekend
can i press out the bearing like the video below uses?
can i also press the bearing the same way?
http://www.youtube.com/watch?v=D4PK1jXhppE
naz123 is offline   Reply With Quote
Old 02-13-2012, 09:48 PM   #269
Pontisteve
Florida
Vehicle Specs
Nope, that wont work. Although you may find that FWD bearing puller to be helpful. You need a 35mm socket, 250 ft lb 1/2 drive torque wrench, hub puller, mini sledge, and pull the hub off and bust the bearings out. Then score the race quite a lot, and then take the spindle to the machine shop anx let them press out the race and press in the new bearing. Use a quality bearing... your life depends on it. Youll need a headlight adjusting tool (spring puller) to get the ebrakes off. The axle is held in by a circlip, if you decide to replace the axle seals while youre in there. Read the thread.
Remove the big snap ring before trying to press out the bearing race! You wont believe how hard that race is in there. A 20 ton press wouldnt budge mine. A larger press will simply break the spindle. Also dont support the spindle by its ears in the press. And put the backing plate on before pressing in the hub.
__________________
EFI Tuner
Old 02-14-2012, 02:43 PM   #270
naz123
Fl
2003 explorer lmtd
Vehicle Specs
Thanks for the heads up.
Old 02-15-2012, 12:36 PM   #271
esclamada
KCMO
'02 Mountaineer AWD V8
Vehicle Specs
I inquired about the hub grappler from OTC long time ago and their tech confirmed that it could do ford trucks. Since the price is so expensive, buying a press or having the shop press it for you make sense economically (unless you replace hubs/bearings every year or use it for a business) Reviews on amazon are not that stellar either. Hopefully somebody on this thread might be interested and share the review.
http://www.youtube.com/watch?v=EQLge25pUQI
MY MOUNTY
http://www.facebook.com/diyfordexplorer?sk=photos
esclamada is offline   Reply With Quote
Old 02-28-2012, 07:52 AM   #272
wanderer351
Columbus,OH
Vehicle Specs
I tackled this last friday after work..I have a press and torches/goodies at the shop...
took a grinder to the end of the axleshaft so my 1 3/8 socket would get a good grip..(took about 1/4 in off the end of the non-threaded section)..
heated the bolts to get them all off...left the ebrake still connected just used a shim block to support the bearing receiver...
scored the bearing races before I even tried to press them out...it went in and out like butter!!
total took me 3hrs of not rushing!! just ordered the other ones to do over the next few weeks...
Thanks for all the tech info guys!!!
wanderer351 is offline   Reply With Quote
Old 02-28-2012, 01:01 PM   #273
PDH
Alaska
'94 XLT & 2002 XLT
Vehicle Specs
Yeah, my 3/4 inch socket set wouldn't reach over the end of the axle shaft either. I almost took the grinder to it - same as you. But when I was at O'Reilly's I saw that they had a socket in their tool loan program that would work, so I picked that up, in addition to their hub puller tool. I used a 6-point 36mm socket, because they didn't have a 35mm socket. 35mm is the correct size but no problems using the 36 either.
Now that you've done the one side, the other will be even simpler and less time consuming.
PDH is offline   Reply With Quote
Old 03-07-2012, 02:35 PM   #274
naz123
Fl
2003 explorer lmtd
Vehicle Specs
Need help everything disconnected
unable to get Hub off with hub puller
Old 03-07-2012, 05:24 PM   #275
Pontisteve
Florida
Vehicle Specs
The rear hub doesn't come off with a puller. The puller simply pushes the axle inward, pressing it out of the hub and toward the rear end. The spindle has to be loose and ready to swing out of the way as you press the axle inward with the hub puller. Otherwise, you're just trying to compress the axle joints.
The axle hub is pressed into a rear axle bearing. The axle bearing is pressed into the spindle from the back side, and retained by a snap ring. The CV axle just slides into the back side of the hub, and pokes out where you can put the nut onto it. The axle isn't really held into the hub by anything other than maybe time, dirt and corrosion. Once the spindle can swing freely, you use the hub puller to force the axle to break free from the hub, and slightly push it out the back side. Once it's broke free, it should come out pretty easy.
__________________
EFI Tuner
Old 03-07-2012, 05:37 PM   #276
naz123
Fl
2003 explorer lmtd
Vehicle Specs
Thanks but no good had everything disconnected per Tyler92 post
Everything was easy until attaching hub tool (same as Tyler hub puller/pusher)
Would not push the axle out of hub .
Might have to take it to the STealership.
Old 03-07-2012, 05:54 PM   #277
Pontisteve
Florida
Vehicle Specs
There's nothing holding the CV axleshaft end into the hub, except a little friction from dirt, wear, and galling. Spray it with PB blaster, and crank down on the hub puller centerbolt. The hub puller provides mechanical leverage pushing directly in the middle of the axle shaft. No reason that wouldn't work, if the spindle is allowed to swing loose as the axle drives inward.
You do have the axle nut removed, right?
Whatever you do, don't beat on the axle shaft. And make sure your hub puller's centerbolt is centered on the axle shaft. It's acting like a press, you almost can't lose. If you have to, upload pics.
__________________
EFI Tuner
Old 03-07-2012, 09:09 PM   #278
naz123
Fl
2003 explorer lmtd
Vehicle Specs
Thank you pontisteve tried everything put it all back together and took it to local mechanic. They too had a hard time removing hub. Off to dealer hopefully they could break it.
Wiil keep you guys posted
Old 03-07-2012, 09:46 PM   #279
PDH
Alaska
'94 XLT & 2002 XLT
Vehicle Specs
I'd crank down on that hub puller and then rap a tap tap with a hammer on the end of the hub puller bolt in the effort to allow the vibrations to break the corrosion bond that's holding the axle shaft tight. That'll usually break'em free unless somebody welded the axle in there (kidding on the weld). Gotta put a hefty amount of torque on that hub puller bolt.
I'm quite surprised it didn't pop the axle shaft outta there.
Old 03-07-2012, 10:27 PM   #280
Gary De
Central Wi
2004 Ranger
Vehicle Specs
Thank you
It looks like you did this a while back but I sure did appreciate it, so much so I became a member to be able to log in and thank you for the time and effort to make this post. I just did my daughters 02 explorer and your post was more than extremely helpful.
By your hard work to put this together I was able to complete the drivers side wheel bearing in about 5.5 hours. I would probably still be working on it if not for your help.
Thank you again,,,,,,,,,, a few years later,,,,,,,,,,,, yes your post has a lasting affect.
Great job!
Gary
Gary De is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
