Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
URGENT!!!!! My '01 Sport Trac won't shift out of park.
Reply
Thread Tools
Old 08-20-2009, 08:02 PM   #1
theforins
Sanford, Maine
'01 Sport Trac 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Angry URGENT!!!!! My '01 Sport Trac won't shift out of park.
At first, the brake lights on the bed weren't working so we tried replacing the brake light switch. NAPA gave us an after market one, which of course we couldn't figure out, and wasn't solving the problem. I did some research online and found that some people have been having trouble with steering column not being in the highest position, so we tried that and put the old switch back in, worked like a charm. Now we can start the truck but can't get it to shift out of park at all. What do we do? My husband has to go to work tomorrow. Please help!!!!!!!!!!
theforins is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-20-2009, 08:28 PM   #2
theforins
Sanford, Maine
'01 Sport Trac 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
More to add: After more research, we think it may be the brake interlock selenoid. If you turn the key to the on position, you can shift to neutral, then start the truck, and then shift into drive. You can shift into park again, but it will be stuck and you have start all over again. Does this make sense to anyone? It still doesn't explain why the steering column has to be in the highest position in order for the brake lights to work.
Old 08-20-2009, 08:36 PM   #3
theforins
Sanford, Maine
'01 Sport Trac 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
NEVER MIND!!!! Yet again, doing more research, I found a similar thread here that the guy was checking fuses and had put the fuse in the wrong place. I went out to check with the hubby and he had solved the problem. He had broken a fuse when messing with the brake light switch under the pedal. Don't as how. So now the brake lights work, the truck shifts. It still doesn't answer the question about why the steering wheel has to be in the highest position for the brake lights to work. Any thoughts????
Old 08-20-2009, 08:53 PM   #4
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Glad we could help!
Did you check wires for insulation wear? Something could be grounding out in the column, or even a broken wire inside of the insulation. When you raise the wheel, it could bend the wire enough to either ground the wire to something or to connect the broken wire to itself...
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 08-20-2009, 09:12 PM   #5
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
Quoted: 2 Post(s)
The wiring subharness to the Multifunction Switch is routed along the left side of the steering column and the brake lamp power must pass through the MS before being sent on to the 2 outer brake lamps. You probably have one of these issues when the column is in the lower position where the subharness is presumably pulled the tightest:
  • There is a connector that is not fully seated and locked.
  • There is a loose pin in a connector that is being pulled to create an open circuit.
  • There is a broken wire conductor that is being pulled to create an open circuit.
  • The Multifunction Switch itself is being pulled, creating an internal open.
The color code for the brake lamp circuit going into the MS is light green.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
rwenzing is offline   Reply With Quote
Old 08-21-2009, 01:44 PM   #6
theforins
Sanford, Maine
'01 Sport Trac 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys, when the hubby gets home from work, i'll let him know. I'll let you know the outcome.
Old 08-21-2009, 09:56 PM   #7
MR YAT
Central NJ
2001 Explorer Sport trac
Vehicle Specs
Quoted: 0 Post(s)
wire harness needs some slack!
Take the top cover off the steering column, you will see a white connector with about 4 wires just pull the harness toward you and the problem will be solved. It happened on my truck and never had any problems after that.
MR YAT is offline   Reply With Quote
Old 05-02-2011, 06:08 PM   #8
rokr1292
richardsville va
'01 Explorer Sport Trac
Vehicle Specs
Quoted: 1 Post(s)
Resurrecting an ancient thread, but what solved this? My truck has an almost identical issue, I replaced the brake switch, but I never thought to check my brake lights. Can anyone explain this all to me?
__________________
Gold 2003 Ranger regcab 2.3 xlt. (Old dd, handed off)
Silver 2001 Explorer Sport Trac 4x4 (new dd as of 3/7/11)
rokr1292 is offline   Reply With Quote
Old 05-02-2011, 06:25 PM   #9
bdmaash
YYC
'01 sport trac
Vehicle Specs
Quoted: 11 Post(s)
Quote:
Quote:
my limited reading skills sort of told me it might be a fuse
__________________
_____________________________
'01 sport trac
Yay another post, I'm well on my way to being a post whore!
bdmaash is offline   Reply With Quote
Old 05-02-2011, 06:26 PM   #10
rokr1292
richardsville va
Vehicle Specs
Quoted: 1 Post(s)
The fuses I actually checked. I don't have a fuse cover, so they were one of the first things I thought to check
__________________
Old 05-02-2011, 06:40 PM   #11
TxPlates
Marble Falls, TX
TxPlates's Avatar
2001 "Rock Trac"
Vehicle Specs
Quoted: 3 Post(s)
It's the harness on the steering column. The wires get backed out of the connector, mine went through the same thing - I had to buy a new connector - slipped the wires back into the new one and it solved the problem. Take the cover off right behind the steering wheel, and it'll be on the top left - grey connector - cost like $5 from ford to replace.
TxPlates is offline   Reply With Quote
Old 05-02-2011, 06:45 PM   #12
rokr1292
richardsville va
Vehicle Specs
Quoted: 1 Post(s)
Where exactly is it? Lol I didn't think that was it because I don't have a tilt column
__________________
Old 05-02-2011, 07:05 PM   #13
TxPlates
Marble Falls, TX
TxPlates's Avatar
2001 "Rock Trac"
Vehicle Specs
Quoted: 3 Post(s)
I'll see if I have a photo from when I did mine.
Old 05-02-2011, 07:24 PM   #14
rokr1292
richardsville va
Vehicle Specs
Quoted: 1 Post(s)
Thanks I appreciate it, its my only transportation and school isn't quite over yet, and work never ends.
__________________
Old 05-02-2011, 07:49 PM   #15
TxPlates
Marble Falls, TX
TxPlates's Avatar
2001 "Rock Trac"
Vehicle Specs
Quoted: 3 Post(s)
Man I can't find my pictures of it.. but here's a thread from 09 that had the same problem. Maybe if you e-mail that originator of the thread he has pictures and can show you.
http://www.explorerforum.com/forums/...d.php?t=261162
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
