#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Is my mounty a parts car?
Reply
Thread Tools
Old 08-25-2009, 10:34 AM   #1
-Jack-
Atlanta, GA
'97 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I've got a '97 Mounty 5.0 AWD with ~172k miles. The transmission is acting up, the ac doesnt work (my mechanic cant find the leak meaning its probably in the evaporator core), the tires have a lot of wear and it needs new shocks, the drivers seat belt wont "click in". The motor pulls strong and the transfer case has recently been rebuilt.
Depending on whats wrong with the AC and transmission it could very easily cost $4k to get it back into daily driver status.
Is this truck worth more for parts? And how much would it be worth as a parts car?
-Jack- is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-25-2009, 11:24 AM   #2
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
Quoted: 0 Post(s)
The trans acting up is the big one. I would get several estimates on the trans. Your mechanic should be able to find an A/C leak regardless. The rest depends on how good you are at parting out or changing out the engine to an other vehicle. I always thought that a ranger with a 5.0 would be cool.
robertoa1a is offline   Reply With Quote
Old 08-25-2009, 11:33 AM   #3
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
Vehicle Specs
Quoted: 118 Post(s)
FIX IT! You'll spend just as much buying something else. At least now you now what you have. We've already lost too many 2nd gen explorers, between recent wrecks and that C.A.R.S. crap.
NO it should not cost anywhere near 4K. Put a used tranny in it yourself for about $400. Evap core can also be used. Receiver/Dryer ($30) and expansion valve should be new. Take the opportunity, while it's all out to inspect and/or repair the blend door issue. Seat belt also can be junkyard, it's a couple of bolts.
Tires/shocks/ect.. are NORMAL maintenance. They should not really be a factor in the fix it decision, as you should assume anything else you buy will need these things anyway.
Scrap value is probably about $300. Unless you have the place and tools to strip, and store the parts until you sell them individually, that's what you'll get for it; and if you CAN do that, then you can fix it yourself.
FIX IT!
__________________
1999 Explorer XLT 4dr, 4.0L-SOHC, 5R55E Auto, A4WD
K&N FIPK Cold Air--XCAL3 w/ custom tunes from Henson Performance
On The Way: Gibson Cat-Back,U/D pulley,Professional Products Polished 70mm Throttle Body **Planned soon:80mm MAFS,Removal of the Cats,Electric Fan
Best Time 15.87 e/t @ 86.6MPH in the 1/4
Carguy3J is offline   Reply With Quote
Old 08-25-2009, 11:55 AM   #4
410Fortune
ELITE BRONCO2ERER
Crawlorado
410Fortune's Avatar
B2 Mod
Vehicle Specs
Quoted: 2 Post(s)
SELL IT!
to me for $500
__________________
96 Explorer daily driver build-1996 XLT 5.0L AWD to 4x4 conversion complete on 33's
88 BII 5.0L conversion - BII 5.0l drivetrain thread
My Bronco II - 1988 Bronco II 4x4 V8 on 35's - registry and updates
Wifes 07 FJ build - 2007 FJ cruiser locked and lifted
410Fortune is offline   Reply With Quote
Old 08-25-2009, 05:25 PM   #5
alohamonte
Glendale, AZ
1998 Explorer 4.0 4x4
Vehicle Specs
Quoted: 29 Post(s)
Sell it for $1000. Buy a 2001 explorer with half the miles for $4000.
__________________
1998 Xplorer 4.0 OHV 4x4, 3.73 L/S, 31x10.5 Good Year Silent Armor A/T, All Synthetic Fluids, Sony Audio System, Yakima Roof Rack w/ 3rd Crossbar, Bilstein Shocks, Silverstar Ultras, Clifford Alarm & Keyless Entry, Throttle Cable Mod, Moog Front End
alohamonte is offline   Reply With Quote
Old 08-25-2009, 06:23 PM   #6
robertoa1a
Jacksonville, FL
Vehicle Specs
Quoted: 0 Post(s)
I bought my X because It was a good deal, a low mileage trailer tower, and I have some skills. If it cost too much money then it's time to.... By what you are saying, it is a horse that has been rode hard and put away wet.
With all due respect, maybe let this one go.
Look on KBB.com, See whats out there.
Old 08-26-2009, 09:17 AM   #7
-Jack-
Atlanta, GA
'97 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I like this idea. But can I actually get $1k for mine? I guess so, the rebuilt transfer case is probably alone worth $500...
Old 08-26-2009, 01:35 PM   #8
ericautopart
Jersey Shore
1998 XLT 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
Sounds like a nightmare of a truck...Unfortunantly it's not worth anything really. Maybe a good time to start learning?
ericautopart is offline   Reply With Quote
Old 08-27-2009, 10:26 AM   #9
samickguy15
Delavan, IL
2000 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Hell yes! You should be able to get at minimum $1k for it. If not for somebodys DD, maybe a first car, winter truck, or offroad toy. Anything that's 4WD, running good, and drives good is worth $1k in my book and many others.
samickguy15 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
