Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Here's one for all you Exploder heads (help!)
Reply
Thread Tools
Old 08-25-2009, 01:03 PM   #1
knappy
steamboat CO
2000 Explorer 2 Dr.
Vehicle Specs
(Original Poster)
a little background on my exploder first. I'm driving a 2000 2 door exploder with the 4.0 sohc 119,000 miles. Canadian made
situation #1
driving from Denver CO up to the mountains in the summer time climbing a big hill. my rig kind of stutters in power so I think nothing of it and keep driving. The situation gets worse and I have to stay down shifted in 3rd gear to keep the rpms up or else I'm going to stall out. By the time i get to the top of the hill (in the tunnel) my rig breaks down and I need to get pushed out by one of the tunnel workers) embarrassing and scary! I take a look under the hood and cant find anything wrong ten minutes later i start it up, runs fine. so i decide to go down the other side of the mountain, sure enough it stalls and I coast into the gas station on the other side of the hill. fill up with gas and have no problems for the next 1000 miles or so.
situation #2
driving out to the desert on a relatively flat road after about an hour I'm cruising through a small town, so i slow it down to 30 MPH. my exploder starts to not respond to my peddle again. so i grin and bear it and push on to the camp spot. I let it rest for the night and it runs fine the next day all 100 miles home.
after situation 1 I thought it was bad gas but according to situation 2 that rules it out (right)?
the way it feels is like right before you run out of gas you get those last few squirts of gas before your all out, except it happens when your at 3/4 tank.
or it feels like the trans is engaging and disengaging, engaging and disengaging. when it idles with the problem it has a really eratic up and down idle and wants to stall.
Please help! I'm going to the Grand Canyon in ten days and need to figure this out!
knappy is offline   Reply With Quote
Old 08-25-2009, 01:58 PM   #2
Fabbed4d88
Grand Forks North Dakota
98 XLT 5.0
Vehicle Specs
Any codes? It may indeed be bad gas. You may have some water in the tank an after your fill up it mixed it up enough to run okay. Before you look into any big repairs try running some HEET through the tank.
__________________
1998 2WD XLT 5.0, Mac CAI, Mac catback, Torque Monster Headers, 1" Trick Flow intake spacer, 2" drop with keys and blocks, Sens-a-Trac shocks, Energy Suspension bump stops, Black 17x9 03 Cobra deep dish wheels, 255x55x17 Michillen Pilots, Wheel Spacers, Removed emblems/door guards/pinstripes and roof racks, painted grill, Clear corners, Black ANZO tails.
Fabbed4d88 is offline   Reply With Quote
Old 08-25-2009, 02:46 PM   #3
knappy
steamboat CO
2000 Explorer 2 Dr.
Vehicle Specs
(Original Poster)
oops I forgot to mention
I put stabilafule in my tank in between situation 1 and 2 so I'm just not sure whats up? thanks for the input!
Old 08-25-2009, 03:51 PM   #4
t-thom1979
Solsberry, IN
'99 xls
Vehicle Specs
It sounds like your fuel pump may be going out.
t-thom1979 is offline   Reply With Quote
Old 08-25-2009, 03:53 PM   #5
nssj2
nssj2's Avatar
Vehicle Specs
my vote is a fuel pump. all of the trouble conditions are after its been running for a while, and not on a full tank. grab a pressure tester so when it dies, you can get a reading. also listen for the pump to prime when it dies.
__________________
-Jim
--97 Mounty (SOLD)
--2007 Volkswagen MKV (daily driver)
--05 Honda Shadow
nssj2 is offline   Reply With Quote
Old 08-25-2009, 03:56 PM   #6
joker1457
Aurora, Co
joker1457's Avatar
98 Eddie Bauer 4.0 SOHC
Vehicle Specs
Quote:
Agreed
joker1457 is offline   Reply With Quote
Old 08-25-2009, 04:24 PM   #7
Spdrcer34
Speed
Bremerton, WA
Spdrcer34's Avatar
1992 Explorer XL
Vehicle Specs
Replace the Fuel Pump, and the Fuel Filter.
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 08-25-2009, 05:31 PM   #8
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Vehicle Specs
Quote:
Ryan
X2
BTW, to my Knowledge the Ford Explorer was never made in Canada...
__________________
2000 Ford Explorer SOHC 4X4 249,000KM
2003 Ford Escape 101,000KM
bluestream1 is offline   Reply With Quote
Old 08-26-2009, 04:05 AM   #9
chance942
B
Las Cruces, NM
2000 Sport sohc con trac
Vehicle Specs
What octane gas do you get regular in the springs?
chance942 is offline   Reply With Quote
Old 08-26-2009, 05:15 AM   #10
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
2000 Sport SOHC 2WD
Vehicle Specs
Check your gas tank cap vent. You should be able to suck thru the cap but not blow thru it. Or the next time your Sport falters pull over, unscrew the cap to vent the tank and then screw it back on.
__________________
My Helpful Threads, Registry, 16.4/23 mpg, 3900 lbs, 5R55E, 3.73:1, 175 rwhp, Henson custom tune, CAI, Spectre air filter, Lightning 90mm MAF, 75mm throttle body, A/F ratio meter, synthetic oils, Accusump, 2 row radiator, 3+1 leaf springs, .75 inch drop, Edelbrock IAS lowering shocks, engine oil & ATF temp gauge & remote filters & coolers, remote crank
2000StreetRod is offline   Reply With Quote
Old 08-26-2009, 08:12 AM   #11
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Check the fuel pressure, also check for a failing or clogged cat.
my98nnj is offline   Reply With Quote
Old 08-26-2009, 02:03 PM   #12
John H.
Longmont, CO
2000 Mountaineer
Vehicle Specs
Remote but a very real possibility...!
Knappy,
I had the exact same thing happen 3 days ago when driving back into Colorado from Nebraska on I-76. Mine is a 2000 Mountaineer 4.0 V-6...made it to an exit ramp where it stalled completely. Restarted it but, it started bucking and then stalled. Checked under the hood, everything was in order, but noticed the passenger side ground wire from the firewall to the hood (at the hinge) had broken off on one end. I had my wife try to start the engine while I held the wire to it's connection...it started and ran normally. Took the wire off and the bucking and stalling took over again. Now, why would losing the ground to the hood cause this? It shouldn't. But, I duct taped the wire back on in order to get home to Longmont. On Monday I installed a new ground wire strap and all has been fine so far. Again, there is no reason for the engine to react to the lack of the hood grounding to the body but....who knows!
John H.
John H. is offline   Reply With Quote
Old 08-26-2009, 04:49 PM   #13
knappy
steamboat CO
2000 Explorer 2 Dr.
Vehicle Specs
(Original Poster)
keep em' comming
I did try the gas cap thing. I checked the hood ground and it was fine.
Has anyone out there had a fuel pump fail on them? If so at what mileage, what did it feel like?
How hard is a fuel pump install and does anyone know a good online manual that shows how?
thanks guys I really appreciate all the input keep it coming!
Old 08-26-2009, 05:29 PM   #14
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
A friend got some estimates for a new fuel pump installed, the cheapest he got was $850.00
Agreed on checking the fuel pressure.
There are diff fuel pumps as well, so wait till the old one is out before getting a new one. Expect to be down for a couple days if a shop does it. Be prepared for a tough job if you do it yourself. Search the forum, read up on the pump install, make up your mind if you think you can do it or not.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 08-26-2009, 07:24 PM   #15
Millertime1987
Excelsior, Minnesota
Millertime1987's Avatar
'99 XLT
Vehicle Specs
Before reading Situation 2 I thought might be because of elevation and the truck wasn't getting enough air to properly mix.
Millertime1987 is offline   Reply With Quote
Old 08-26-2009, 09:15 PM   #16
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Could be rust in the tank...
My 99 Sport has had the same tendencies in the past and I installed an electric fuel pressure gauge to monitor it... I could watch the fuel pressure drop as I put more demand on the throttle to accelerate.. I could also get the engine to run when this happens as the fuel pressure would drop and the engine would run like crap...
I finally dropped the tank and checked the in-tank pump since I had gotten rusty fuel from the external filter and found the in-tank filter was not on the pump!!!
I cleaned out the tank in May 09 and put in a new pump and filter set so I have no clue how long the in-tank filter had been off the pump but I do know the pump was pumping any dirt and rust that was still in the tank...So I replaced the pump and in-tank filter from Autozone for 123.00 and so far so good...
I did the external filter swap every couple of weeks and kept getting higher levels of rust on the input side of the filter until I pulled the tank again and found the missing in-tank filter...
Changing the pump on a 2wd Sport can't be that bad...I know I have dropped the tank a few times but if you have a couple of hours you can change the pump, filters, and reinstall tank and get the truck running again...Depending on the first number of the vin your truck can be made in the US, Canada, or Mexico...Vin 1 is USA made, Vin 2 is Canadian, and Vin 3 is made in Mexico...Oh and the Mexican made truck also has a return type fuel system.. The US and the Canadian trucks all have a returnless fuel system... The differences in the pumps usually is the terminal size and placement.. The AZ pump covered that with the harness that is included..
__________________
When in doubt, use a bigger hammer!
2008 Dodge Charger R/T
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
