Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Windshield washer pump problem.
Reply
Thread Tools
Old 09-03-2009, 10:04 AM   #1
666k9
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hoping someone could help with this one. Have a 98 Explorer XLT (4dr/4x4/4.0)that I bought used and found the front windshield wiper washer pump line was connected into the rear washer line (it has the correct pump with two outlets) and works only with the rear pump/wiper switch). Hooked the lines up correctly, replaced the mutli-position switch (turn signal), and still still get no power to the pump using the multi-pos switch. I want to run a wire directly from the steering column wiring harness to the pump (feel I might have a broken wire somewhere) but do not know which wiring harness wire to use. Suggestions and/or or a wiring diagram??? Appreciate any help.
666k9 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-03-2009, 08:31 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 426 Post(s)
Welcome to this forum! I've moved your thread to the stock 95-01 section. Get a schematic diagram, and trace the wiring.
BrooklynBay is offline   Reply With Quote
Old 09-03-2009, 08:35 PM   #3
TheJackal
Mandeville, LA
1999 Explorer XL 2WD
Vehicle Specs
Quoted: 1 Post(s)
Are you sure it's not the relay?
TheJackal is offline   Reply With Quote
Old 09-03-2009, 09:19 PM   #4
2000XPLORERSPORT
lambertville,mi.
2000 FORD EXPLORER SPORT
Vehicle Specs
Quoted: 6 Post(s)
check the relays in front of the washer reservoir.there in a black box.theres 3 relays. that was the problem with mine.
__________________
http://www.cardomain.com/ride/2429989
4.0l ohv red taylor 8.8mm spiro pro wires, motorcraft platinum plugs,royal purple 5w-30 oil,k&n oil filter,valvoline synthetic brake fluid,red top optima battery under the hood.volant cai,helix throttle body spacer,2 1/2" pipe ran into turbo 2 muffler with no cats,93 octane fuel,adjusted tps to .96volts,sct x4 with custom tune from james henson,lowered 3"
2000XPLORERSPORT is online now   Reply With Quote
Old 09-04-2009, 08:20 AM   #5
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
Indeed, it sounds like the relay is likely only working in one direction.
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 09-08-2009, 12:05 PM   #6
666k9
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Checked the relays but no luck. Am trying to trace the problem through the wiring harness. Thanks for the input.
Old 09-08-2009, 01:29 PM   #7
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Quoted: 10 Post(s)
Quote:
What do you mean by 'no luck?' There are two relays to check... One for the front and one for the rear. One should get power and close when it gets a signal from the MFS and one should get a signal to close when it gets a signal from the rear wiper control button. One relay acts as the ground path for the other relay.
Now, in your case, it sounds like someone re-plumbed the hoses to jimmy it and make it work. Not the right fix.
You need to pull the front and rear relays and check their function, as well as check for the proper signal coming to them from the switches. It could be a multifunction switch not working (not uncommon) or a bad relay. The easiest thing to try first would be to swap the front and rear wash relays and see if the problem moves from one to the other. If so, then we know you have a bad relay. If not, then it could be a wiring issue, or it could simply be the pump gone bad in one direction (not uncommon and a $30 part IIRC)
But telling us you 'checked' the relays doesn;t really tell us what you did...
__________________
Old 09-08-2009, 06:52 PM   #8
TheJackal
Mandeville, LA
Vehicle Specs
Quoted: 1 Post(s)
This relay box is near the air filter housing. It is not the Battery Junction Box, where the owner's manual tells you the relays are.
Try swapping the forward and reverse relays and see if that changes anything.
Old 04-02-2010, 10:37 AM   #9
cbranje
Vehicle Specs
Quoted: 0 Post(s)
How do you open the darn relay box??
cbranje is offline   Reply With Quote
Old 04-02-2010, 11:02 AM   #10
cbranje
Vehicle Specs
Quoted: 0 Post(s)
Figured that out, now when I open the lid all I see is one black cube and a bunch of plastic slots . . .
Thanks,
Carmen
Old 04-02-2010, 11:24 AM   #11
cbranje
Vehicle Specs
Quoted: 0 Post(s)
Hey all, I figured out all by myself by RTFM
Turns out the relay for the pump is in the main electrical junction for my explorer sport 2001. Switched the relays and now the front works, not the back. Will order a new relay soon.
Old 12-16-2011, 12:04 PM   #12
graciebrother
VAN, BC
Explorer Sport 1998
Vehicle Specs
Quoted: 0 Post(s)
I'm having a problem with my washers now too. rear seems to be working, which I assume means the pump is working? Going to check the relays this weekend and maybe swap them around.
The pressure for the front washers has been playing up for a while and was slowly getting less and less. This week - nothing. Took the unit apart ast night and checked the pump. It comes on when pushing the interior switch /button. I also blew through the hose and they also seem clear - wonder if there could be a hole in the line?
graciebrother is offline   Reply With Quote
Old 12-16-2011, 03:49 PM   #13
Millertime1987
St.Paul, Minnesota
Millertime1987's Avatar
'99 XLT
Vehicle Specs
Quoted: 4 Post(s)
I had a similar issue. Turned out mine was corroded relays i cleaned those up with a fine sand paper and now all is working. Did this after replacing the pump mind you.
Millertime1987 is offline   Reply With Quote
Old 12-16-2011, 04:00 PM   #14
graciebrother
VAN, BC
Explorer Sport 1998
Vehicle Specs
Quoted: 0 Post(s)
Thats good to know (but bad for you!)- thanks. Will take a look at the relays. From the threads I've read, they seem to be the culprit more often than not.
Old 12-16-2011, 11:18 PM   #15
comatose1
Naples, FL
'98 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I'm having a similar issue with my windshield washer, when I press the MFS in with normal pressure it doesn't work until I put an enormous amount of pressure on it. Is my MFS going bad?
comatose1 is offline   Reply With Quote
Old 12-17-2011, 02:39 PM   #16
graciebrother
VAN, BC
Explorer Sport 1998
Vehicle Specs
Quoted: 0 Post(s)
I just pulled the relays and switched them around. Back continues to wash fine buy nothing on the front washer. I also took apart the t-split which diverts to the two fron washers and tested to see if there are any blockages, nothing and no fluid got pumped through either. Looks like it the pump itself. Time to call and get a replacement. Anyone know a part number for it?
Thanks
Old 12-18-2011, 09:26 PM   #17
fixt
North Carolina
96 Explorer XLT AWD
Vehicle Specs
Quoted: 7 Post(s)
Quote:
Thanks
Check here at Rock Auto
http://www.rockauto.com/catalog/x,ca...,parttype,8840
fixt is online now   Reply With Quote
Old 12-21-2011, 10:12 AM   #18
graciebrother
VAN, BC
Explorer Sport 1998
Vehicle Specs
Quoted: 0 Post(s)
Ah jeez, it was the relay after all and I even bought a new pump!
Old 12-09-2013, 09:33 AM   #19
Metalhead Jon
Milwaukee,WI
1999 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
I know this is an old thread, but I figured I'd ask here rather than starting a new one and duplicating information. I'm having a similar problem (1999 Explorer Sport 4X4, 4.0 SOHC), except that I don't get any washer fluid sprayed either front or rear. Initially I found a blown fuse in the panel just inside the driver's door and replaced it (I don't remember which one anymore). When that didn't solve the problem, I tested power at the pump, no power when my wife pushed the MFS. After finding the image that TheJackel posted above, I got two new relays figuring that was the problem, and swapped them in for the washer pump relays (front and rear), but still the pump didn't work. I swapped the washer pump relays with the fog lamp relays (same P/N) as a test, and the fog lights still work but I'm still getting no pump function. Is there anything I missed, or anywhere else I should check? I'm really starting to pull my hair out on this one. Any help or advice would be greatly appreciated.
Metalhead Jon is offline   Reply With Quote
Old 12-15-2013, 02:55 PM   #20
Metalhead Jon
Milwaukee,WI
1999 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
I still haven't been able to make the washer pump work. Anyone have any ideas on whatever I might have missed? Using a spray bottle full of windshield fluid (what I'm doing now) is really not a good solution to all the road salt and other crap that cakes on my windows after it snows.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
