Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
Rumbling noise from front end.
Reply
Thread Tools
Old 09-07-2009, 07:29 PM   #1
GaryB2001
Erie, CO
2001 Sport Trak
Vehicle Specs
(Original Poster)
US Rumbling noise from front end.
I have a 2001 4WD Sport Trak that has developed a rumbling noise from the front end. As I have previously had a problem in the front spindles/brakes the truck has less than 5000 miles on new spindles, rotors, calipers, and brake pads. That solved the problems with the brakes. It has now developed a rumbling sound from the front. I do not feel that the spindles are a problem, they were a lower cost set from NAPA but still seemed to be of a good quality. I put the truck up on jack stands today and got under to check things out. The thing that stands out in my mind is that I seem to have some slack in the front diff. When I turn the driveshaft back & forth I hear and feel slack in the movement of the front axles. That is, when the driveline is turned, the axles have a lag before turning. In my past experience this indicates the ring gear & pinion have a problem. However I understand that some of these Sport Tracks came with limited slips (unusual in a front end I think). Could the slack could come from a limited slip? Anyone have any experience with these. Any help in where to look prior to tearing this thing apart would be welcome. Thanks
GaryB2001 is offline   Reply With Quote
Old 09-08-2009, 12:18 AM   #2
specialized7
saskatoon
99 SPORT
Vehicle Specs
i am having this exact same problem in my 97, it started tonite after a 2 hour highway trip.
ill post if i find anything
specialized7 is offline   Reply With Quote
Old 09-08-2009, 10:01 AM   #3
JohnnyO
Sport Trac Moderator
Pittsburgh, PA
JohnnyO's Avatar
'08 Sport Trac
Vehicle Specs
Cool
Quote:
That's normal.
No Sport Trac ever came from the factory with a front limited-slip. A front L/S was available on Rangers and Bronco II's from about '85 to '89 but that's all. Scarce as hen's teeth anyway and no it won't fit the ST's Dana 35 front even if you could find one.
When my previous '05 Sport Trac made what sounds like the same noise, it turned out to be a bad front wheel bearing.
Also check to make sure the front diff is full.
__________________
'08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia.
"It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776
JohnnyO is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
