#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Front wheel bearing replacement on a 2004 Explorer.
Reply
Thread Tools
Old 09-08-2009, 09:33 PM   #1
mm34033
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Front wheel bearing replacement on a 2004 Explorer.
HI ALL
New to the sight i hope someone can help as my explorer is out of order
i am trying to replace left front wheel bearing hub assembly on my 2004
rear wheel drive explorer it is a xlt none of the pictures on this sight look like mine i have no retaining nut holding on the roter just the housing for the caliper so as soon as you take the brakes off the truck you can slide the roter right off the hub assembly everyone else seems to gave a retaining nut now 3 bolts is all it takes to take the bearing housing off that seems normal AM I DOING SOMETHING WRONG IS MY EXPLORER MISSING SOMETHING or is it different please help
mm34033 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-09-2009, 10:49 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've renamed, and moved your thread into the stock 2002-2005 section.
BrooklynBay is offline   Reply With Quote
Old 09-09-2009, 10:55 AM   #3
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
Quoted: 1 Post(s)
two wheel drive no nut, its actually for the front half-shaft which you don't have.
Yours should be a piece of cake, hopefully.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 35k
2010 Sport Trac Limited, V8 4WD, 80k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 09-09-2009, 10:14 PM   #4
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
Yours is 2wd, the pictures posted on here by myself and other members doing this replacement are 4x4's. You should at least be able to get those 3 bolts out easily....
thepotroast is offline   Reply With Quote
Old 09-10-2009, 03:33 PM   #5
skeeter123
2002 XLT 4.6L
Vehicle Specs
Quoted: 0 Post(s)
you're OK.... I did both front wheel bearing hub assemblies on my 2002 Exp XLT (rear-wheel drive) with reference to this link:
http://www.explorerforum.com/forums/...d.php?t=165429
and just ignoring the part about the axle nut. I did have to buy a 1/2" breaker bar and 15mm socket to get the three bolts off.
You may want to consider doing the right hub while you're at it....
skeeter123 is offline   Reply With Quote
Old 09-10-2009, 07:25 PM   #6
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
The guide you posted is for 2nd gen explorers.
There is a better guide, for 3rd gen's (2002-2005) on replacing front hub assemblies, here:
http://www.explorerforum.com/forums/...=front+bearing
Old 09-12-2009, 04:59 PM   #7
mm34033
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys got the job done the truck drives better then when i first bought it i allways thought that the tires were humming but all along it must have been that bearing
well got it all done thanks for the help
NOW THE TRUCK IS TO QUITE HA HA
Old 09-12-2009, 09:16 PM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Thanks for the update!
Old 09-15-2009, 04:20 PM   #9
skeeter123
2002 XLT 4.6L
Vehicle Specs
Quoted: 0 Post(s)
Hey Potroast, thanks for the updated link for the 3rd-gen Exp's. I read the whole thing, didn't see anything about 2wd's; but now I sure am glad I bought the 2wd vice the the 4x4. Bolt-cutting & torches? Maybe I lucked out, but when I did my front hubs I didn't have the metric sockets and just picked up a 10-15mm extended (3") set from Sears which was on sale. No problems at all like those mentioned in that link. The 3 bolts came out pretty easy (with a 1/2" breaker bar), no real access problems; easy to disconnect/reconnect the sensor cable from underneath. I bought the Exp new in 2002, didn't see a need for 4x4 since I'm in flatland (FL) with no plans to take the family car swamp-riding. But I got the V8 and towing package since I planned to tow the sailboat; short story is that I soon sold the sailboat and have towed one trailer once in 7 years..... but now I can finally pat myself on the back for choosing the 2wd, since it was apparently much easier to change the hubs on my 2wd than on a 4x4. I've got about 30K miles on the new hubs, they're still running nice and quiet, but maybe I should knock on wood while I'm patting myself on the back (and try not to trip at the same time)
Old 10-23-2009, 09:28 PM   #10
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 99 Post(s)
I just changed my front right wheel bearing today and the job was much easier than some of the people on here. I have 4x4 and didn't need to pry anything(hub slid right off after taking all the bolts out) didn't need to take the steering arm off(not really sure why anyone would?) and all in all, took about 1.5 hrs taking my time with simple hand tools. So anyone around Kansas City, KS that wants help changing a wheel bearing, I'll be glad to help
But here's the problem. When driving the ex before the swap, I got a nice loud humming noise that seemed to get worse every other day. When I would turn to the left while going about 30mph, the humming would get much louder and you can feel the fine vibration in the steering wheel. Turn to the right and nothing. So I figured front right wheel bearing. Replaced it today and went for a spin. Exact same problem as before, so I made a video to show the sound and I'm hoping someone can point me to the problem. It's hard for me to believe it's the rear because I feel it in the steering wheel, but anythings possible. I will update this as soon as the video uploads onto my photobucket account. Seems like it's taking its sweet time
Edit:Here's the vid, sorry for the wait. Any help is appreciated!!!
__________________
"Spending money I don't have, on parts I don't need, to impress people I don't know"
Sold 12/31/2015 - 2002 4.6 4x4, K&N CAI, Henson tuned, FM70 and 20" Boss 306's
Limited02 is offline   Reply With Quote
Old 10-24-2009, 12:44 PM   #11
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 99 Post(s)
TTT for some help
__________________
Old 10-24-2009, 12:54 PM   #12
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Vehicle Specs
Quoted: 0 Post(s)
Didn't read through the whole thing, but I think the summary is "I think I have a bad wheel bearing and replaced it but the problem did not go away".
When you rotated the old removed bearing was it rough and grindy?
You may have replaced the wrong one - happens all the time. Since the system is all tied together any bad bearing is hard to isolate to one side or the other.
That's why I replaced both sides when I did mine. Problem fixed.
__________________
Wife's: '02 Limited 4.6L/4x4
Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe
EasyRhino is offline   Reply With Quote
Old 10-24-2009, 03:12 PM   #13
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 99 Post(s)
I should have put cliff notes on my post But yeah, replaced the right front bearing and the problem is still there. No it didn't really make any noise and I tried moving both wheels when jacked up with no luck. I thought the idea was when you turned left and the noise got louder, that it was the right front wheel bearing?(and vice versa) Guess that can't work everytime I am going to mess with the left bearing and see what's up.
__________________
Old 01-30-2010, 03:30 PM   #14
alexk
New Jersey
15 Sport
Vehicle Specs
Quoted: 27 Post(s)
Quick question, my front driver side bearing is bad. Can I just replace the bearing or do I need to do the entire hub?
alexk is offline   Reply With Quote
Old 01-30-2010, 03:56 PM   #15
EasyRhino
Kailua, Hawai'i
Vehicle Specs
Quoted: 0 Post(s)
Quote:
The front wheel bearings are sealed units; therefore, no bearing replacement is possible. You have to buy and replace the entire hub. Yeah, I know - plug and play car parts.
__________________
Old 01-30-2010, 04:17 PM   #16
alexk
New Jersey
15 Sport
Vehicle Specs
Quoted: 27 Post(s)
^Thanks! Im hoping to get an aviator this summer so I dont really need a Ford part do I? I was thinking about getting this one if it helps: http://stores.channeladvisor.com/Aut...LAID=443949655 or this one http://www.##################.com/sk...%26+Drivetrain
Old 01-30-2010, 04:28 PM   #17
alexk
New Jersey
15 Sport
Vehicle Specs
Quoted: 27 Post(s)
I guess the link isnt gonna work its from auto parts warehouse Timkin Part Number: TMSP470201 Manufacturer Number: SP470201 $171.91
Old 01-30-2010, 05:00 PM   #18
EasyRhino
Kailua, Hawai'i
Vehicle Specs
Quoted: 0 Post(s)
I would def go with OEM or Timkin. There are some cheap arftermarket ones out there that others have warned about.
Of course, the OEM ones that came on our Ex's were not that durable it turns out.
I don't know of any high mileage Ex's that have NOT had thier wheel bearings replaced.
__________________
Old 04-13-2010, 05:38 PM   #19
jakedrew
wisconsin
04 xlt
Vehicle Specs
Quoted: 3 Post(s)
limited 02. figure the issue out?
jakedrew is offline   Reply With Quote
Old 04-13-2010, 06:50 PM   #20
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 99 Post(s)
Quote:
Yup, left wheel bearing was the culprit So if anyone wants advice, replace both at the same time and be done with it.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
