Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How to replace the front wheel bearings on a 2003 Ford Explorer XLT.
Reply
Thread Tools
Old 09-10-2009, 12:42 AM   #1
TexasFord03
Dallas,Tx
2003 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok heres my problem:
On the front left..there is a wheel bearing hub assembly with speed sensor. Can the bearings inside the hub be replaced, if so, how do you get them out. Or do you have to replace the entire hub assembly?
TexasFord03 is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-10-2009, 09:36 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section.
BrooklynBay is offline   Reply With Quote
Old 09-10-2009, 10:49 AM   #3
gsmaclean
Strongsville, OH
03 Limited
Vehicle Specs
Quoted: 2 Post(s)
You replace the entire hub, speed sensor and all.
gsmaclean is offline   Reply With Quote
Old 09-10-2009, 06:26 PM   #4
thepotroast
Asheville, NC
3rd Gen EB 4x4 V8
Vehicle Specs
Quoted: 29 Post(s)
This thread has the info you need for replacing the front hub assembly on your 2002-2005 Ex:
http://www.explorerforum.com/forums/...=front+bearing
P.S. As stated, it's a complete assembly with ABS sensor and all.
thepotroast is offline   Reply With Quote
Old 09-12-2009, 09:05 PM   #5
Dianne Lawler
Russellville,Alabama
2003 xlt
Vehicle Specs
Quoted: 0 Post(s)
after replaceing hub unit the abs light came on and stays on how to turn it off
Dianne Lawler is offline   Reply With Quote
Old 09-12-2009, 09:12 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 417 Post(s)
Welcome to this forum! CHeck the connector on the ABS sensor.
Old 07-08-2012, 10:30 AM   #7
03explorerowner
Massachusetts
Vehicle Specs
Quoted: 0 Post(s)
Unhappy Can someone please tell me Why???
Background: I have a 2003 Ford Explorer XLT, December of 2010 I replaced the Right front hub assembly and Left Rear Wheel bearings. Christmas 2011, I replaced the Right rear wheel bearing.
Friday I was told that my right front wheel bearing has shit the bed again and needs to be replaced. Umm, I just did that a year an a half ago, bearing only has a little over 30,000 miles on it. Why is my explorer shitting through wheel bearings??? I am NOT rough on this vehicle at all, not even bumping curbs and I avoid all bumps possible in the road (I do live in new england so its not always possible). I feel like when I get them replaced they are not doing it correctly or screwing me over because I am a woman.
How long should a bearing be lasting me? Are certain bearings better than others to put on? Someone mentioned a timkin bearing has a life time warrenty on it so if I spend the money once I won't have to again. I just feel like this car is eating bearings like cherrio's
03explorerowner is offline   Reply With Quote
Old 07-08-2012, 02:17 PM   #8
tower
Millbury, MA
03 Limited centennial
Vehicle Specs
Quoted: 2 Post(s)
I put in a bearing from NAPA lasted about as long as yours, put in a timkin and about 110k later still works great.
__________________
2002 XLT 4.0 Flex - yard truck
2003 Limited Centennial Edition
tower is offline   Reply With Quote
Old 07-08-2012, 10:35 PM   #9
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
Same thing with me. I put in the cheap one and replaced it after a short while. Put in a Timken and it's good to go. Knock on wood!
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 07-09-2012, 01:04 PM   #10
joeburmeister
Augusta, GA
2003 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
The wheel bearings sold at Autozone is Timkin and it comes with a life time warranty. The only downside is that it doesn't come with new bolts (like the ones from the dealer). I did my front bearings last summer and so far no problems!
joeburmeister is offline   Reply With Quote
Old 07-10-2012, 01:23 PM   #11
antsmands
Chicago, IL.
2003 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
Seems like there should be or should have been a safety recall on these bearings. Does anyone know if Ford issues maintenance bulletins on these bearings? I need to replace my bearings also.
__________________
2003 Explorer XLT Sport 4.6L
antsmands is offline   Reply With Quote
Old 07-10-2012, 06:02 PM   #12
HCCA 250
IL
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
SKF is the best bearing you can get for your Explorer. I used a Raybestos, hub and wheel bearing. Also good. But, I'll bet that I should have used either MOOG, or SKF. Hind sight, is 20/20...
When it comes to wheel bearings, you CANNOT skimp...period!
HCCA 250 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
