Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2001 Ford Explorer Suspension Squeak
Reply
Thread Tools
Old 09-22-2009, 12:38 PM   #1
Explorer01Sport
North Carolina
2001 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 2001 Ford Explorer Suspension Squeak
I have a 2001 Ford Explorer Sport. I just recently bought this explorer a couple days ago and did not notice the squeak while test driving it. I am sure that it is something that can be fixed with some lube or silicone spray but i'm not exactly sure what is making it squeak in the first place. There is a squeak that comes from the back left side im guessing its suspension but I'm not sure. Its often when I hit bumps ot take sharp turns. Its a high pitch squeak and I'm not sure why it is doing it. The ride is a little rough but Explorer Sports are known for their rough ride. The squeak is not something that annoys me to the point of not driving it but I would like to get it fixed. Help!!! Thanks
2001 Ford Explorer Sport Mine
2005 Ford Explorer Mom
1995 Ford Explorer XLT Dad
Explorer01Sport is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-22-2009, 08:11 PM   #2
ramren16
greeley, CO
01 explorer sport
Vehicle Specs
Quoted: 4 Post(s)
spray lube on all bushings in front in most likely it is the sway bar endlinks
ramren16 is offline   Reply With Quote
Old 09-22-2009, 08:43 PM   #3
Runnin'OnEmpty
Southeast USA
2000 Sport
Vehicle Specs
Quoted: 46 Post(s)
Also spray lube the torsion bar ends where they go
into the front A-arms. (Use the lithium spray lube.)
Tighten up the spare tire winch.
__________________
2000 Sport 4x2, 4.0 ohv, 5R55E w/Superior shift kit, 3.55 diff, Mazda truck alloys/BFG TAs, RoadMaster Active Suspension, EE anti-sway bar, F&R poly bushings, camber kit, Rancho shocks, Hooker Aero Chamber muffler, Medium Wedgewood Blue.....
Bought another 2000 Sport (God help me), 4.0 ohv auto, 60K actual miles, Cragar SS alloys/BFG TAs, AAL, EE anti-sway bar, Gibson cat-back, Harvest Gold, GT leather interior.
Runnin'OnEmpty is offline   Reply With Quote
Old 09-26-2009, 11:55 PM   #4
HR57
Hampton Roads, VA.
'01 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
You might also check the tire jack access hatch in the left rear area. That has a tendency to rattle and squeak. I put some 1/8" foam weatherstripping on mine to quiet it.
__________________
2001 Explorer Sport SOHC, Mobil 1, EE Rear Sway Bar
HR57 is offline   Reply With Quote
Old 09-28-2009, 09:55 AM   #5
ThePhoenix
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
a squeak wouldnt be end links...they rattle, right?
Old 09-28-2009, 10:21 AM   #6
GRNMACHINE
IL
GRNMACHINE's Avatar
95 Sport 4x4
Vehicle Specs
Quoted: 39 Post(s)
Have had a squeak in the left rear area for awhile now. HR57 can you post pics of where you installed the weather stripping?
Explorer01Sport, I also had a squeak like rusty bedsprings in the front drivers side area. Ended up being a bad lower ball joint.
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 09-28-2009, 10:44 AM   #7
ramren16
greeley, CO
01 explorer sport
Vehicle Specs
Quoted: 4 Post(s)
Quote:
bushings cant rattle if they are not tight enought they can squeak depending on the material mine have been doing this for a while i have sprayed them with wd-40 which helped for a while then came back and of course i know to use lithium based grease just didnt have any on had at the time
Old 10-02-2009, 09:22 AM   #8
Explorer01Sport
North Carolina
2001 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I have found that it's not the spare tire or jack access. When I grab the towing ring on the front and bounce the car up and down pretty hard the squeak reoccurs. I'm not 100% sure where I need to lube in order to stop this squeak, but kinda know the general area. If anyone could post a couple pictures of where the major problem spots are that would be awesome. Thanks Guys!
Old 10-02-2009, 10:41 AM   #9
ramren16
greeley, CO
01 explorer sport
Vehicle Specs
Quoted: 4 Post(s)
its the end links just spray every rubber piece in the wheel well
Old 10-02-2009, 02:02 PM   #10
GRNMACHINE
IL
GRNMACHINE's Avatar
95 Sport 4x4
Vehicle Specs
Quoted: 39 Post(s)
FYI-Sounds very similar to the problem I had. Ended up spraying parts individually as well as the entire front suspension on numerous occasions. The squeak would not go away. It was lower balljoints-since they are sealed no amount of cans of WD-40 or anything else would make the squeak go away. I am not saying it is your lower balljoints, but a possiblity to be aware of.
__________________
GRNMACHINE
Old 10-02-2009, 02:25 PM   #11
ThePhoenix
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
just dip your truck....
just kidding
Old 10-02-2009, 02:41 PM   #12
coppe
coppe's Avatar
01 xls v6 SOHC
Vehicle Specs
Quoted: 7 Post(s)
my most annoying squeak were the leaf springs. I first power washed the whole suspensión, rode it a bit, then more washing, waitd for it to dry,
hitted all the suspensión rubber parts with silicon or teflon lube first to protect the plastics from environment and oils and to displace the water that could still be there,
then used some regular transmision oil in metal to metal (got some between leafsprings with a sirynge, and certain pins, then used spray on lithium grease in every moving part, bushing, got some in between the leafsprings to sort of "seal the oil" in there and weather proof it a bit,
also i used the silicon lube in top and in the sides of every body mount (helped to eliminate the squeaks and cracks when the body flexes like in ramps or diagonal bumps, etc),
lubed and tighten the spare tire winch, and after that... took it for a ride, tried to brake suddenly, sharp turned, bounced it around a bit, to get the lube all over the suspensión.
After this, i only needed to add a bit of lube to the mmmmm front leafsprings shackels?? mounts?? whatever.... and i do this like every 3 to 4 months, and keeps the x completely silent, it´s great to feel that new car clickity, crackly, squeaky free feeling. Also you could get an undecarriage wash and a normal lube in certain carwash places, and it also works, but they tend to use old oil mixed up with diesel to spray everything, and while it also protects you from rust and stuff, the agressive chemicals also dry up your rubber parts.
to locate an specific problem, have someone bounce down the truck, while you are under it, and touch mobile parts, you will "feel" the squeak.
This works great for me, but i´m not a continuous off road kind of guy, maybe if i did i would havve to do this more often. hope this helps.
__________________
Even at 25, you gotta start someday!!
coppe is offline   Reply With Quote
Old 10-05-2009, 01:50 PM   #13
stangladesh
Raleigh, NC
2001 Sport
Vehicle Specs
Quoted: 0 Post(s)
i'm going to try coope's solution this evening. we have replaced the upper and lower ball joints and upper control arm,front shocks, and sway bar bushings. we still have a lot of squeaking going from the suspension and some noise when turning the steering wheel. we used to have this rattling going on in the rear. we found that it was a body mount bushing/shock mount bushing. repalced that and the rattle was gone.
stangladesh is offline   Reply With Quote
Old 12-14-2010, 09:00 PM   #14
kgerard
Key West Florida
01 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
2001 Explorer Sport noise
I have a 2001 Explorer and it squeaks so much that people turn around to see where the sound is coming from. I change my own oil frequently and while under the truck I found the problem. The rubber bushings ( the size of a donut) are all dry, cracking and falling apart. Have know idea what it would cost to replace them. I tried WD40 and it made the tuck quiet for maybe two days. All of the bushings need to be replaced. Hope a Ford mechanic on this site can give us more info as how expensive this repair may be.
kgerard is offline   Reply With Quote
Old 12-15-2010, 07:46 AM   #15
ThePhoenix
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
there are plenty of do-it-yerself threads on this...and shops can vary..
which are you going to do...yourself or pay?
Old 12-15-2010, 01:14 PM   #16
kgerard
Key West Florida
01 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
squeeky suspension 2001 Explorer Sport
I would like to replace the parts my self but need more information on how to do it and where to purchase the replacement rubber bushings.
Old 02-27-2011, 09:57 PM   #17
kgerard
Key West Florida
01 explorer sport
Vehicle Specs
Quoted: 0 Post(s)
Where do I find the site on replacing these rubber bushings that are causing my squeaks? I cant find anything on this subject. I have noticed other explorers on the road making the same noise. It must be a common problem.
Old 11-10-2012, 11:09 PM   #18
myf16
northern California
96 Explorer XLT 4WD
Vehicle Specs
Quoted: 1 Post(s)
Quote:
By feeling for vibration while an assistant bounced the suspension, I identified one lower front ball joint as the likely source of my rusty bed springs squeak. The ball joint had a grease fitting, so I was able to lube it. No more squeak.
I never would have guessed ball joint had I not read it here!
myf16 is offline   Reply With Quote
Reply
Tags
2001, explorer, sport, squeak, suspension
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
