my windows dont work either when i push the button i hear a clicking under the dash close to the steering somewhere any ideas
Welcome aboard!!
The clicking sound could be a relay. The location of the relay for the power windows should be in the owner's manual. If you don't have an owner's manual,
Dead Link Removed.
I see that you have a Ranger.
The following information is for the 3rd Gen (2002-2005) Explorer. I don't know how much of this info will pertain to the Ranger. You might want to check the
Ranger Sub Forum.
Click here to go there now.
Having said that:
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the accessory delay wasn't working, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, the radio would shut off as soon as I turned the key off, the delayed accessories didn't work, etc.
Recently all 4 windows stopped working. Most recently the driver door lock actuator stopped working.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found 2 broken wires and repaired them. The thin black ground wire was broken and after repairing it all was back to normal.
When the windows stopped working, I repaired the thick black ground wire and the windows now work like a champ. I had to repair the pink/black wire to fix the driver door lock actuator.
Here is the thread for removing the door panel:
http://www.explorerforum.com/forums//showthread.php?t=303524
Here is a great thread for checking for broken/damaged wires, thanks to
synyster for this awesome write-up:
http://www.explorerforum.com/forums//showthread.php?t=270081
Be sure to take your time when looking for broken/damaged wire(s). Check all the wires for breaks/damage. When you think you're done looking, look again, and again, and again. A bright flashlight can be very helpful.
If all else fails, here is a great link for troubleshooting the power windows, thanks to
theofam for this great link
Dead Link Removed
Like I said,
This information is for the 3rd Gen (2002-2005) Explorer. I don't know how much of this info will pertain to the Ranger. You might want to check the
Ranger Sub Forum.
Good luck with the fix!! :biggthump
