Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Brown Wire Mod Help????
Reply
Thread Tools
Old 09-25-2009, 01:08 PM   #1
stsmoker
Cumberland City, TN
stsmoker's Avatar
05 Ford Explorer 4x4 XLS
Vehicle Specs
(Original Poster)
So i want to do the brown wire mod. I have a 2005 Explorer. I cannot find the brown wire anywhere except for right out of the TC. If i splice in the switch right there and run 10-15ft of wire into the cab to the switch then 10-15ft of more wire to go back to the brown wire would i be risking any loss of volatge or w/e because of the extra resistance? And I plan on using a 25 amp simple toggle switch and 14 gauge wire. Any input would be appreciated!!!
stsmoker is offline   Reply With Quote
Old 09-25-2009, 02:06 PM   #2
stsmoker
Cumberland City, TN
stsmoker's Avatar
Vehicle Specs
(Original Poster)
anyone?
Old 09-27-2009, 08:40 AM   #3
gunz2000
Port Colborne ontario
97 limited
Vehicle Specs
Quote:
haha i dont know what the brown wire mod is im new to the stuff here but i do have a fix for your problem,
install a relay at the wire at the TC run a wire from a switch in the dash, when you put 12V to the trigger pin on the relay it will eather open the circuit or close it witch ever one you want,
this website will give you some wireing examples that may help you out
http://www.fastronixsolutions.com/Te...lay_Wiring.pdf
this will fix your line loss problem
Andrew E
gunz2000 is offline   Reply With Quote
Old 09-28-2009, 12:55 PM   #4
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Yes, it will work just fine. No relay necessary as the clutch only draws 4A, and an extra 10 ft of wire will add minimal losses to the circuit. However, you must thoroughly weatherproof the connection. Solder and shrink-tube are a must, and crimp-on butt connectors are out of the question. Also, it will likely cause the 4wd lights to begin flashing, and you will not be able to switch it back on 'on the fly' like you can with the second-gens.
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will — we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 09-28-2009, 01:00 PM   #5
gunz2000
97 limited
Vehicle Specs
ya i dident know how much it drew, and he was worried about line loss so that was my solution, im going to have to do this my self with mine, i had my mud tires on for some time and had no problems then i started geting where it would auto shift into 4x4 when on the hwy and i ended up tearing 2 belts in 2 tires
Old 09-28-2009, 07:07 PM   #6
stsmoker
Cumberland City, TN
stsmoker's Avatar
Vehicle Specs
(Original Poster)
Well i went a head and did the mod. However i did use the little crimp connectors but i taped the SH*T out of the wires where crimped and also tied the wires off out of the way. Shouldnt get too nasty under there. Im going to be keeping an eye on the wires to make sure they stay put and clean...just incase :P.....
I just used a simpe 20amp switch, cut the brown wire and put the switch in between the brown wire. Seems to work fine, I'm still a little leery about using it all the time because i do not feel like replacing my TC haha. But it lets me switch on the fly and I can spin tires now ( as much as the traction control lets me anyways ) The explorer is a lot more fun to drive now in the rain though So unless i feel like gettin sideways on the wet road or on the gravel my 4x4 auto stays engaged. Hopefully I dont have any trouble with the switch or TC.
Old 09-28-2009, 07:08 PM   #7
stsmoker
Cumberland City, TN
stsmoker's Avatar
Vehicle Specs
(Original Poster)
ps.....will hopefully have pictures soon...its been nasty and rainy here the past couple days. so when it dries up (tomorrow should be nice) I will crawl back up under there and take pictures.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
