Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
Oil pressure gauge & O/D switch are not working.
Reply
Thread Tools
Old 10-02-2009, 10:21 AM   #1
Francisco Rodrig
San Antonio, TX
2003 Ford Ranger LXT
Vehicle Specs
(Original Poster)
Thumbs up Oil pressure gauge & O/D switch are not working.
Hi! First time here.
My deaf 19 yearl boy got the first Ranger ever in the family in July, it lasted him a week when he totaled it!, but thanks to air bags, seat belts, crumbling (crumpling ?) zones not he or the girl with him had a scratch, !!!!!!!!!.
Therefore we looked & looked till we found another 2003 Ranger........
This second 2003 6 cyl. Ranger xlt, has a problem, the O/D swithc will not engage. Transmission changes all right, from 1 st, to 2 nd, 3 and 4 , no problem.
But if he pushes the button when going on 4 th gear, it will not downshift, nor the indicating light would turn on.
Is this fuse related? because the oil preassure gage is not working either.
Any help welcome, thanks
Francisco and Paco
Francisco Rodrig is offline   Reply With Quote
Old 10-02-2009, 01:33 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the Ranger section. It's always a good idea to check the fuses if there is a common problem.
BrooklynBay is offline   Reply With Quote
Old 10-02-2009, 09:47 PM   #3
rwenzing
Michigan
03 Ranger FX4 LII 5.0 S/C
Vehicle Specs
The oil pressure gauge and the O/D Cancel switch are not electrically related. The oil pressure gauge shares a common fuse and ground with the voltmeter. If the voltmeter works and the OP gauge does not, then it is not a fuse issue.
Possibilities:
OP gauge: The most common problem with Ranger oil pressure gauges is the sending switch. On a 3.0L, it is in the block behind the passenger side cylinder head. 4.0L have the switch on the driver side of the block below the A/C compressor. It is virtually impossible to see the sender from above on either engine. Better to look in through the appropriate wheel well. Color code of the single wire to the sender is green/white.
O/D Cancel: First, verify that dash fuse #2 is intact. Second, a wire or wires to the O/D cancel switch may be broken. Starting from the switch, the 2 wires pass through the hollow shifter stalk and then make a sharp turn before traveling down the top of the steering column to the dash harness. Over time, the repeated movement of the shifter can break one or both of the wires where it makes that turn. To check it, remove the top plastic trim from the column and inspect the two wires where they come out of the tubular shifter.
__________________
Bob
2003 Ranger FX4 Level II, 5.0L V8, 4R70W, BW4406 T/C, Aussie Locker front, Torsen rear
Torque Monsters, Magnaflow, duals; Explorer EATC, steering wheel controls, consoles
Bilstein 7100 reservoir shocks, Cadillac/Mustang SVO rear discs, Duff traction bars
CarDomain
Ford owners' manuals ONLINE, then click on "Glovebox"
rwenzing is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
