Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
How do I stop the beeping?
Reply
Thread Tools
Old 10-05-2009, 01:07 PM   #1
grandpaford
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello Enthusiasts,
I'm not sure if this is the right place to post this, but I guess it's worth as shot. I have a 1993 Explorer, and it always beeps when I open the driver side door. The actual problem is the key lock cylinder. The truck thinks that the key is still in the ignition switch when its not, and so the alert sounds ANYTIME the door is open. (I always thought this alert was an annoying feature of Fords, even when working properly).
At any rate, I would like to turn this alert off completely. Does anyone know the best way to disable this beeping? Perhaps a fuse I can remove, or a wire I can disconnect? I never want this vehicle to beep at me ever again for anything.
Thank you for your time.
grandpaford is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-05-2009, 01:30 PM   #2
Slowlyvverot
Greensboro, NC
93 ExElTee
Vehicle Specs
Quoted: 0 Post(s)
I hated the beeping too. In my 93, there is a box underneath the center of the dash with a bunch of wires going into it. Pull out the black wire and that should stop the beeping. This will also cause the Fasten Seat Belt light to always be on, but it doesn't bother me.
__________________
'93 XLT: 2" lift on 33s, 4.88s
DubDub
Quote:
Originally Posted by Stic-o View Post
Sway bars! You don't need no stinking sway bars!
Slowlyvverot is offline   Reply With Quote
Old 11-15-2009, 09:26 AM   #3
grandpaford
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It turned out to be an easy fix. I located the box that was beeping, and unplugged the wires going into it. No more beep.
Old 11-15-2009, 06:43 PM   #4
Currency
Bedford Indiana
94 XLT 4x4
Vehicle Specs
Quoted: 1 Post(s)
Mine does the same thing but it's caused by the ignition not being in the correct position which is caused by general wear and tear on the ignition switch over 15 year's.
__________________
My registry. http://www.explorerforum.com/forums/...d.php?t=257045
I may be interested in one or more first gen parts explorers. PM me if your not to far with pics and price.
Currency is offline   Reply With Quote
Old 11-16-2009, 12:38 AM   #5
KobeJ05
Marina, CA
1994 explorer 157k miles
Vehicle Specs
Quoted: 0 Post(s)
whats weird is if i have my key in the ignition my drivers door wont make it chime its all the other rest of the doors that make it chime.
KobeJ05 is offline   Reply With Quote
Reply
Tags
alert, beeping, disable, ingnition, sound
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
