Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
How to replace Tranny dipstick tube 2000 XLT
Reply
Thread Tools
Old 10-07-2009, 08:10 AM   #1
a5thson
Liverpool, NY
2000 XLT
Vehicle Specs
(Original Poster)
My 17 year old son just handed me the tranny dipstick and top of rusted dipstick tube from my 2000 Explorer XLT. Don't yet know how that happened. Needless to say, I must replace dipstick tube. Nothing about in my Haynes manual. Anyone tell me how to replace it, and where to find the part? Much appreciate reply.
a5thson is offline   Reply With Quote
Old 10-07-2009, 09:37 AM   #2
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
First, you will need to state which transmission you have.
You could post a wanted ad in the classified forum here.
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is offline   Reply With Quote
Old 10-07-2009, 11:50 AM   #3
a5thson
Liverpool, NY
2000 XLT
Vehicle Specs
(Original Poster)
good point. 2000 XLT SOHV 4L engine, automatic transmission. if looking for transmission model, i don't currently know that info. how can i tell tranny model number?
Old 10-07-2009, 12:03 PM   #4
celly
disturber of the peace
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
Quote:
I think you meant SOHC. You have two choices for the V6...SOHC or OHV.
Try eBay or Car-Part.com. Lots of Exploders in the boneyards due to the Cash for Clunkers debacle so you should be able to find something second hand.
__________________
'99 EB
5.0 AWD, Torque Monster Headers, 1" Trick Flow UI spacer,
Custom Volant based CAI (incl C&L MAF body),
SCT XC2 w/Henson tunes, Flo Pro catback, EE swaybar & airdam, Morimoto HID projector retrofit (4300K), Bilstein shocks, Powdercoating by Turdle, Amsoil everywhere, other stuff.
Quote:
I didnt even waste my time to read that, nor will I, however I read some of it.
I, I, I, Me! Me! Me!,
Craigslist Scams for Dummies, Don't Be a Wannabe.
celly is offline   Reply With Quote
Old 10-07-2009, 12:22 PM   #5
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Try asking kbabiak who is a vendor here.
He is a dealer of used explorer parts.
send him a pm
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 10-07-2009, 12:53 PM   #6
celly
calgary
celly's Avatar
99 eb 5.0 awd
Vehicle Specs
send him a pm
Good point. I always forget about him and pedstang.
__________________
'99 EB
Old 10-08-2009, 08:04 AM   #7
a5thson
Liverpool, NY
2000 XLT
Vehicle Specs
(Original Poster)
re: 2000 XLT tranny dipstick tube
thanks for replying. yes, i meant SOHC, and not SOHV. i will try those venders. also, have i provided enough info about the my tranny for any suggestions on how to remove the remainder of the old dipstick tube, and install a new tube? i appreciate your advice.
Old 08-26-2011, 03:04 PM   #8
tjones99
Toronto, Ontario
95 XLT (was 94 XLT)
Vehicle Specs
CAN DIY Transmission dipstick Tube
I went to check my transmission fluid level the other day and pulled out and wiped the dipstick. As I inserted it I happen to see the dipstick as it emerged from the tube down near the manifold. Thats not right.
it was rusted right through. I bent the dipstick a bit to get it to navigate the bend and make its way down into the tranny and found I was low on fluid. Can't add since it all runs out the rust hole onto the ground.
I took a small funnel and a 3/8 inch piece of clear PVC tubing that I snaked down the dipstick tube and got fluid in my tranny. That was the 5 minute get me home fix.
At home I took the dipstick off, which is pretty easy on the 2000 Explorer Eddie bauer 4.0l SOHC 4wd V6. One nut near the manifold and then essentially pull (I went underneath and with some needle nose vise grips I grabbed the tube near the transmission and pushed it out from below after disconnecting it from the bolt up above).
Went to the wrecker to get a replacement. All were rusted beyond use. Went to Ford. $60 and it had to be ordered. Ouch.
So I made one. I used a piece of 1/2 inch EMT metal electrical conduit. Used a tubing bender to make it the same shape. Made sure (IMPORTANT) that the dipstick stuck out the same amount from my home made as the original. Ground the bracket off the old tube and welded it onto my DIY tube and it works great. At the bottom I filed a groove for an O-Ring to seal in the lower tube and I used a large countersink and a file in the top end to taper it inside so the rubber seal on the dipstick would go in. Its a bit small and tight but works great frankly. Pics below.
<img src="https://lh6.googleusercontent.com/-nbKFgU6gsxI/Tlf47h5gfdI/AAAAAAAAFjo/5vX193tfE5s/s144/DSCF0927.JPG" />
Hope this helps.
TJ
tjones99 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
