Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Two vacuum hoses keep blowing off !
Reply
Thread Tools
Old 10-14-2009, 08:16 AM   #1
westfield
San Antonio, TX
94 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Okay...How do I fix this...this has happened twice over the past two weeks. At start up...the ex blow two lines off the vacuum tree and it runs crappy till i reattach the vacuum lines...what should I look for to correct the problem..
Thanks!
ps..the car has 150,000 miles on it and it runs great (till the lines blow)
westfield is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-14-2009, 08:55 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Check the modulator for leaking transmission fluid.
BrooklynBay is offline   Reply With Quote
Old 10-14-2009, 08:56 AM   #3
geoph1986
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
I would say that you should replace those lines as they are probably old and stretched. I had the exact same problem, and once I replaced the lines, they never blew off again.
Old 10-14-2009, 12:35 PM   #4
mrboyle
I Drive By Brail
Montrose, CO
mrboyle's Avatar
'95 Bronco '80 Toy
Vehicle Specs
Quoted: 12 Post(s)
Quote:
X2
The if tranny modulator fails it will allow vacuum to pull fluid up to the intake and soak the other vacuum lines with tranny fluid. Once soaked they expand and fall off. Check modulator (pull line off modulator @ tranny and if fluid runs out its bad), replace if bad, replace vacuum hoses that got soaked and return to service.
__________________
Mike Boyle
'92 XLT(RIP) 1980 Toyota PU
Quote:
Originally Posted by DiffWackDaddy
Some people go looking for God, others get broadsided by them
mrboyle is offline   Reply With Quote
Old 10-14-2009, 12:56 PM   #5
westfield
San Antonio, TX
94 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks all...i'll check the mod and see if the vac lines are old to
Old 10-16-2009, 11:32 PM   #6
camsdad
Atwater, Ca
1994
Vehicle Specs
Quoted: 0 Post(s)
Transmission modulator. Check your fluid level.
Been there and done that.
Swapped it out and never had the problem again.
Be very glad you are here asking.
When it was happening to our 94 explorer, my wife took it to a transmission shop and they said the transmission was shot.
They quoted $1200.
I spent $12.00 for the modulator.
Had my niece's boyfriend do the job since you could not just reach in there and remove it without removing some of the exhaust to gain access. I think he had to use some metric sockets too.
camsdad is offline   Reply With Quote
Old 10-19-2009, 08:21 AM   #7
ExploringNC
Hickory, NC
'98 XLT, '91 EB
Vehicle Specs
Quoted: 0 Post(s)
I'm confussed? How can a vacuum line (negative pressure) blow off? You would have to have a positive pressure in the line to blow it off.
__________________
'91 EB 4.0 OHV 4x4
31x10.5 Maxxis Bighorn's
Uwharrie 2010
BrooklynBay's List of Useful Threads
ExploringNC is offline   Reply With Quote
Old 10-19-2009, 08:45 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
A flow of transmission fluid being drawn into the hose could cause it to slip off.
Old 10-19-2009, 09:18 AM   #9
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
I've had a couple hoses slip off over the years.
Each time, The lines were soft, one from just age, the other had Trans fluid in it.
They never came off "while driving". They both came off while starting.. And both times it was when I started the X, but didn't let it turn over long enough to actually start. I'm guessing that when the motor stopped spinning the motor may have spun backwards a bit and causes positive pressure in the upper intake, blowing off the hose.
Once the hoses were fixed (not soft/squishy) they were fine.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 10-19-2009, 10:27 AM   #10
clearwtrbeach
washington
1992 eb, 1994 limited
Vehicle Specs
Quoted: 0 Post(s)
I just replaced a vacum modulator through the hump inside, there was a small hose maybe 3-4" from the modulator to a metal tube. Is there another hose that I may have missed.
clearwtrbeach is offline   Reply With Quote
Old 10-19-2009, 07:23 PM   #11
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 411 Post(s)
Check the hoses connected to the vacuum tree.
Old 07-01-2015, 03:50 PM   #12
Itchybruno47
93 EXPLODER XLT 4.0 OHV
Vehicle Specs
Quoted: 0 Post(s)
~Mark
X2. Has happened a few times to me. New hoses and keep key turned when starting till she fires. No more problema!
Itchybruno47 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
