Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Catalytic Converter Replacement Necessary?
Reply
Thread Tools
Old 10-28-2009, 04:02 PM   #1
NJExplorerFan
New Jersey
2015 Limited
Vehicle Specs
Quoted: 74 Post(s)
(Original Poster)
I was wondering how much of a job it is to replace a catlytic converter on my '97 Explorer 4.0L SOHC? Someone recently mentioned to me that it's an $800 job replacing the whole system because it's a Y-shape and you can't just replace the catalytic converter alone. I haven't gone under there to see set-up. Is this true? The car has almost 160K miles on it with a number of other things that need repair. Is it even worth fixing? It's probably only worth about $1,500. What harm would I cause driving around like this?
__________________
2015 Explorer Limited
3.5L V6
2003 Explorer XLT
4.6L V8 - Sold April 2015
NJExplorerFan is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-28-2009, 05:06 PM   #2
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
Quoted: 0 Post(s)
I looked up mine (5.0l ) at Advance a/p and they are asking about $400 for the two converters as a complete bolt on set. It's safe to assume that the bolts are rusted and will require some persuasion.
As far as your vehicle being worth $1,500, that depends on what value you put on it. If you kept up the maintenance then it could be an exceptional one. I look at the fact that mine cost about $60 per month in up keep and some elbow grease and don't think of it as an investment but an expense (cost of driving). Not bad!
robertoa1a is offline   Reply With Quote
Old 10-29-2009, 02:53 PM   #3
NJExplorerFan
New Jersey
2015 Limited
Vehicle Specs
Quoted: 74 Post(s)
(Original Poster)
What harm would I do if I kept driving it with a bad cat?
__________________
3.5L V6
2003 Explorer XLT
Old 10-29-2009, 04:38 PM   #4
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Why replace?
I have 151,000 miles on my Sport with SOHC. Each bank downpipe has as O2 sensor then a catalytic converter then another O2 sensor. There is a cross pipe (equalizer) after the cats. The pipe from each bank feeds into a dual input/single output muffler. I thought the Y system was used on the OHV engines and not the SOHC engines.
Why are you considering replacing the cats? I've read that many last for more than 200,000 miles - especially if the fuel mixture has been properly controlled. If you have an after cat O2 sensor then you'll get a DTC when the cat is no longer effective. I plan to replace my exhaust system in the next year or two because I want to experiment with a progressive dual pipe/muffler system. Otherwise, I wouldn't replace the cats until they fail.
2000StreetRod is offline   Reply With Quote
Old 10-29-2009, 04:46 PM   #5
robertoa1a
Jacksonville, FL
Vehicle Specs
Quoted: 0 Post(s)
Are you sure it's bad. Does it smell like sulfer when running? Is the cat glowing?
Over time a bad fuel mixture wich could cause engine damage and carbon build up.
There are aftermarket cats for around $100 that have to be welded in but I guess you know that.
Old 10-29-2009, 06:56 PM   #6
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
For one thing, your gas mileage would sux.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 10-30-2009, 07:26 AM   #7
NJExplorerFan
New Jersey
2015 Limited
Vehicle Specs
Quoted: 74 Post(s)
(Original Poster)
I know it's the catalytic converter because my "check engine" light has been on for months. I scanned the code, replaced the O2 sensor and nothing. So it's gotta be the cat.
__________________
3.5L V6
2003 Explorer XLT
Old 10-30-2009, 07:52 AM   #8
coonerboy
Herkimer, NY
98 Explorer XLT 4wd V8
Vehicle Specs
Quoted: 1 Post(s)
There are alot of O2 sensor related codes, and replacing the sensor isn't always the repair neccessary to fix the code. Can you post the code number?
You wouldn't want to replace the converter if your only problem was a vacuum leak or a bad wire. You would be right back at square one with the same code.
__________________
'98 Explorer XLT V8 4wd 100kmi. 4406 t-case, MAC intake and catback exhaust.
coonerboy is offline   Reply With Quote
Old 06-06-2012, 04:10 PM   #9
zoomtoob
New Joisey
99 4WD XLT
Vehicle Specs
Quoted: 0 Post(s)
i have this issue - got the P0420 code. i hae had fuel mix issues and at 212k, it makes sense for me. 1999 Exploder 4.0 SOHC. did the upstream O2s with no joy. i heard if you run some chemicals (Lacquer Thinner) through the system (AKA run the car for 150 miles - tank and motor) this can bring it back a bit... is this true and/or dangerous for the old girl???
zoomtoob is offline   Reply With Quote
Old 06-06-2012, 05:26 PM   #10
Sedition
Engine Repair Guy
Geelong, Australia
Sedition's Avatar
98 Explorer XLT SOHC
Vehicle Specs
Quoted: 40 Post(s)
If you want to do that, next time you fill up put 3oz of Acetone in there. This will give the system a good cleansing and you will notice the gas mileage difference almost instantly. I wouldn't do this too often though, it's strong stuff.
__________________
98 XLT SOHC V6 Export - Busted tranny - Recently Rebuilt Engine For Sale
2002 Limited SOHC V8 - Bent Rod - Awaiting Repair
It's the all American SUV, I tell you w'hut....
Sedition is offline   Reply With Quote
Old 06-06-2012, 06:02 PM   #11
delexploder
Greenwood De.
97 ford explorer sport
Vehicle Specs
Quoted: 190 Post(s)
I have seen alot of different factory setups for this motor. My 97 sport sohc had two seperate down pipes with no y pipe but I have seen the other ones mentioned here. If you run alot of additives or even if you run high octane fuel it can damage them. Like the others said if it smells like sulfer or sometimes it can smell like old gas or chlorene or they glow or rattle then u should change them. And if u can get it done with direct fits or weld in for under a grand then you are doin better then I am cause the cheapest direct fit set for mine was about 1200 at dealer cost. But since im about to do my 5.0 swap I got Magna flow direct fits for the 5.0 and other than the extra two cats and being 2.5 inch stainless they are the same as what came on it.
delexploder is offline   Reply With Quote
Old 06-06-2012, 06:20 PM   #12
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
Why did you revive this thread???
__________________
I strongly abide by the motto, "Safety third."
Quote:
Originally Posted by NICE59FORDF100 View Post
Dont forget numbers. Teacher Ladies LOVE numbers
FIND is offline   Reply With Quote
Old 06-06-2012, 06:33 PM   #13
delexploder
Greenwood De.
Vehicle Specs
Quoted: 190 Post(s)
Lmao dam I just noticed that
Old 06-06-2012, 07:07 PM   #14
bilzy7
MA
98 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Great job....
Btw magnaflow catalytic converters direct fits with pipes are no where near 800...
__________________
1998 Explorer XLT 4x4 4.0 SOHC
bilzy7 is offline   Reply With Quote
Old 06-06-2012, 07:16 PM   #15
delexploder
Greenwood De.
Vehicle Specs
Quoted: 190 Post(s)
Lol I knw they cost me about 560.00 a piece and that was with a major hook up from a friend at a parts counter. I think walk in price is like 740.00 per side. And I didn't revive this thread I found it under new threads lol sorry.
Old 06-07-2012, 10:46 AM   #16
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Vehicle Specs
Quoted: 461 Post(s)
zoomtoob revived the thread (from 2009).
SoNic67 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
