| Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle. |
Thread Tools |
#61 | |
Wannabe Elite Explorer
Montreal, Canada
'96 AWD V8
Quote:
__________________ [B]'96 Xplorer V8 (sold ) '90 GT Mustang 11.32@123MPH http://www.montrealmustang.org |
#62 |
North Carolina
'99 Limited V8 AWD
Lekid302
That $25 price was 6 years ago. There was a $38.57 price quoted from a dealership in post #28 3 years ago. Right now, FastPartsNetwork.com has the adjusters for $34.25 each + $??.?? shipping to Canada.
This dealerships is about 50 miles from downtown Montreal. You can find out from them on Monday how much they cost unless somebody here can answer you first. 1. Riley Ford Inc 9693 Route 9Chazy, NY 12921 ![]() Tel: (518) 846-7131 Fax: (518) 846-8693 |
#63 |
Montreal, Canada
'96 AWD V8
I take this thread alive another time .
I change the torsion bar adjuster today , i paid 80$cad each . I took me one hour to change both side . Now i have the same clunking noise but less noisy since the kevlar patch is new . The adjuster bolt on the right side had 14 thread left and the right side was 6 thread so defenatly someone had try to adjust the suspension . I never had to take a puller to take off the torsion bar adjuster , only a couple of hard hitting and the adjuster start to slide off . I was suprised when i put the newer one , it was loose on the torsion bar . i mesured .030 difference between bar and adjuster . Is it normal ?? . And i dont know if i use the good procedure to adjust the height of my truck, i mesured the rear : 31½ from ground and the center of the wheel well . So i adjust the front a the same height . But the adjuster bolt have 16 thread left now. If i put it more stiffy , it raise the front . Maybe i wrong but just clarify if i have done this well . Thanks a lot __________________ [B]'96 Xplorer V8 (sold ) '90 GT Mustang 11.32@123MPH http://www.montrealmustang.org |
#64 |
Stinktown
96 Explorer 4.0 AT 4WD
After having Upper/Lower Control Arms and Inner Tie rods replaced per dealer recommendation, my 96 is still doing the Clunk. Do you need to have front end alignment after replacing Torsion Bar Adjuster?
#65 |
Knoxville, TN
98 Mountaineer A4WD
Yes, any height change requires an alignment. Hopefully your tires aren't new, and you can sort out the issue before a final alignment. Have you inspected your torsion bar keys? Those 95-97 models have a kevlar wear pad on them which often wears out?
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#66 |
Stinktown
I just bought torsion bar adjusters from www.fastpartsnetwork.com for $37 each.
#67 |
Stinktown
that's what I am about to replace. the chilton's book doesn't say realignment is necessary though. I just had it realigned after having upper/lower control arms, ball joints, inner tie rods replaced per ford dealer suggestion. still clunks too.
#68 |
Stinktown
Well, I finally figured out my front end clunking noise. So far I've changed upper/lower control arms and ball joints both sides (per ford deal recommendation), torsion bar adjusters, stabilizer bar bushings, Inner and out tie rods, none of which got rid of noise. My left front drive axle snapped today destroying my Monroe Reflex Shock that I was about to return under warranty which is now void. It looks like it may have jacked up the upper ball joint too. The $93 I spent getting it diagnosed at Ford and the $1000 I spent based on their advice apparently wasn't enough. Now I'm out another $100 for the shocks and who knows how much for the control arm and other damage.
First and last Ford I'll ever buy. |
#69 |
Port Huron, Michigan
2001 Sport Trac/1997 F150
Does this kevlar paded key, apply to the 2001 sport trac as well?I had my ball joints and tie rods checked.I had them replace the right outer and inner tie rods and a alingment.I have this "clunk" noise when I go over bumps.You can feel it in the floor board almost as if something on the front suspension is loose.Maybe a bushing or something?
#70 |
Knoxville, TN
98 Mountaineer A4WD
Welcome, and no. The torsion keys with Kevlar pads were only made from 95-97, that was a big improvement in 1998. From 1998 there is a pocket in the frame which holds a replaceable friction pad in it. They last a whole lot longer after 1997. Regards,
#71 |
Elite In Memoriam
2000 Sport 4x4
Any time or mileage range with the new ones, i.e. the 2000? I hear some stuff every so often as well. Checked out fine though at my last PM, so not sure what it is otherwise.
__________________ 2000 Sport -- BWM, 4 DR leaf springs, 100W aftermarket driving lights, 55W backup lights, Pioneer HU with iPod controls and remote housed in center armrest. "Whatever you can do, or dream you can, begin it. Boldness has genius, power, and magic in it." -- Johann Wolfgang von Goethe Home of the Fightin' 29 and Truck 297 -- The Tallest Aerial in Baltimore County A great cause -- Leary Firefighters Foundation RIP Jeff - You are truly missed |
#72 |
Knoxville, TN
98 Mountaineer A4WD
I have not yet heard of anyone replacing the 98-01 model wear pads. I had priced them once, they should be just over $30 each.
#73 |
Las Flores, CA
98 XLT 4X4 sohc
Wow, learned alot from this thread. Any idea if the B torsion bars (higher spring rate) are available for 98s. How would I know what I currently have? I've got to look at the wear pads. I've deffinitly got the clunk and can't find anything else.
__________________ Joe 98 XLT 4X4 sohc TT, Custom Deaver leafs, 31x10.5 BFG's Custom skid plates, recovery shackles Defender rack, Warn transformer mount and winch |
#74 |
Boonton, New Jersey
1998 XLT
I've got to bump this thread. I've got a clunk in my 98 that sounds exactly what is described in this thread. Has anybody ever replaced the friction pad on a 98 to get rid of the clunk? I'm at a loss as to what's clunking on my truck. Everything up front is new and tight! Any help would be appreciated.
#75 | |
Old and in the way
Humboldt, Kansas
2000 Mounty
Quote:
Also, grease the rear drive shaft slip yoke. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| b rated torsion bars | SGR1600 | Explorer - Ranger Shocks, Suspensions, Lift Kits | 6 | 03-19-2004 11:57 AM |
| Need help witht the torsion bars | snafu4u2s | Explorer - Ranger Shocks, Suspensions, Lift Kits | 1 | 02-25-2004 07:46 PM |
| aftermarket torsion bars | PUR PONY | Explorer - Ranger Shocks, Suspensions, Lift Kits | 8 | 05-19-2002 04:45 AM |
| Thread Tools | |
