Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
HELP!! 8.8 pinion seal lsd
Reply
Thread Tools
Old 11-01-2009, 04:25 PM   #1
explorermudder
colorado
97 sport
Vehicle Specs
(Original Poster)
got an 8.8 i pulled the coer off, drained the oil. pulled the c clips, pulled the axles, pulled the ring gear, kept the bearings and races and seperate. cant get the pinion out... got the nut off and the flange the driveshaft bolts to. i have beat it with 3 lb hammer and a block of oak and it will not come out.
explorermudder is offline   Reply With Quote
Old 11-01-2009, 05:17 PM   #2
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
So just to make sure, you are hitting the pinion gear towards the back of the axle right (towards where the cover diff cover would be) ?
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 11-02-2009, 05:56 PM   #3
explorermudder
colorado
97 sport
Vehicle Specs
(Original Poster)
re
ya i am
Old 11-02-2009, 06:40 PM   #4
Jakee
Huntsville, Texas
Jakee's Avatar
01 Sport
Vehicle Specs
The wood is excellent in protecting the threads from damage but sometimes you need a bit more “shock” to get the pinion out.
I would screw the pinion nut back on until there’s about one thread from being flat with the pinion threaded end, then place a pc of scrap metal on the end making sure the nut is the only thing in contact. Then give it a solid knock (don’t have anyone standing on the other side although if it does shoot out it will catch the pinion nut). If it doesn’t come out then remove the scrap metal and inspect for damage. Repeat until it comes out but I can’t caution enough to make sure and not hit the pinion end or you’ll never get a pinion nut back on.
Also, replace the pinion nut afterwards (don’t try and reuse the one you hit) You’ll never get the right torque values from it.
__________________
STS turbo charged
Jakee is offline   Reply With Quote
Old 11-04-2009, 05:06 PM   #5
explorermudder
colorado
97 sport
Vehicle Specs
(Original Poster)
Thumbs down
i used a piece of lexan... and that dont work ill try the pc of scrap metal, are they suppossed to be this hard to remove?
Old 11-04-2009, 05:09 PM   #6
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
They arent supposed to be that difficult to remove - something is definitely wrong.
__________________
Reply
Tags
8.8, gear, pinion, rear end, ring gear
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
