Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
2003 Sport track p0171 and p0174 CEL Codes
Reply
Thread Tools
Old 11-02-2009, 06:08 PM   #1
kev7554
OH
93 sport track
Vehicle Specs
(Original Poster)
Ok my CEL came on a couple of weeks ago so I took it and had the codes pulled off and they were P0171 and P0174. Tech said to replace both Oxygen Sensors. I didn't have the money so I just drove without fixing and everything seemed fine. Yesterday when i went to start it it was tough to start and stalled a few times. Also when at lights or stop signs it almost stalls and sometimes does. So I did some online research and found out that its usually never the o2 sensors. So I looked for Vaccum leaks and I found a pretty big one. Went and purchased the new rubber hose/boot from ford and put it on.
Had the codes cleared at autozone and thought the problem was fixed. Well half way home from autozone the light came back on and it seems to be idling rough again. I also noticed that when i rev the engine it gets to about 3000 RPMs and it starts to stutter REVS HIGH then low High then low no matter how far down i press the pedal it gets to 3000 and wont go any higher. So does anyone here have any ideas what to check next or should i just replace the o2 sensors. Thanks in advance
kev7554 is offline   Reply With Quote
Old 11-03-2009, 06:45 AM   #2
John_Rock
Moderator In Memoriam
Houston, TX
John_Rock's Avatar
2001 Sexy Sport Trac 4x4
Vehicle Specs
Quote:
That's the computer keeping you from over revving your engine when there is no load on it.
__________________
John_Rock - Mugshot - Click Here For info on my 2001 Sport Trac 4x4
- 2000 Explorer Limited AWD, 5.0L v8; 4.10 gears, KKM True Rev filter, B&M Tranny Super Cooler, Aux. Tranny Filter, Autometer Tranny & Water temp gauges.
Demon4x4.com
John_Rock is offline   Reply With Quote
Old 12-09-2009, 03:30 PM   #3
gguerra
McAllen, Texas
03 Sport Trac 4x4
Vehicle Specs
I had the same codes on mine and the same problem (rough idle) and it ended up being a faulty vacuum hose. The guy at the shop found the problem right away using one of their diagnostic machines. There are other causes but I would check the obvious first before spending a lot of money. Another common cause is the MAF sensor. Check out this page for more info http://www.aa1car.com/library/ford_lean_codes.htm
gguerra is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
