EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Offroad Drivelines
Notices
Offroad Drivelines Ford Explorer and Ranger Transmissions, Transfer Cases, Driveshafts and Axles.
wasted passenger side axle u joint
Reply
Thread Tools
Old 11-09-2009, 11:12 AM   #1
MEANEXPLODER
HADDAM, CT
91 XLT
Vehicle Specs
(Original Poster)
Angry wasted passenger side axle u joint
wondering what the best axle u joints are available as i wasted a brand new Napa "superstrength" joint last night just putzin around some rock climbs near my house... is this a common failure w a dana 44 and 35 inch tires? it destroyed my outer shaft as well and scarred my inner shaft up pretty good...
__________________
91 xlt 4.0, auto, shortened hi-pin d44, disc8.8 5.13's detroit lockers, 35'' mud terrains=money pit
MEANEXPLODER is offline   Reply With Quote
Old 11-09-2009, 12:05 PM   #2
Fusion213
Jacksonville, NC
Fusion213's Avatar
'98 XLT 5.0L
Vehicle Specs
If you want the BEST axle joint, CTM U-joitns are good joints. Longfield, Yukon, and east coast gear supply have some nice joints too.
On the other hand, if you want something affordable and pretty strong, I recommend Dana spicers.
__________________
98 5.0L SAS
Fusion213 is offline   Reply With Quote
Old 11-10-2009, 05:27 PM   #3
MEANEXPLODER
HADDAM, CT
91 XLT
Vehicle Specs
(Original Poster)
Question
thanks fusion.... i think im gonna go w CTM... Is there anyway to upgrade to 3/4 ton axle shafts from an 8 lug d44?
__________________
Old 11-10-2009, 06:12 PM   #4
IZwack
Germantown, MD
IZwack's Avatar
Vehicle Specs
3/4 ton doesnt change axle shaft strength.
Except for weird exceptions, a Dana 44 is a Dana 44 - meaning the axle shaft diam is the same.
__________________
»»»»»...how'd the moon get there, how'd the moon get there?
IZwack is offline   Reply With Quote
Old 11-11-2009, 08:58 AM   #5
DB_1
Elite Ranger
La Quinta, Ca.
DB_1's Avatar
97 SC Ranger xlt
Vehicle Specs
Quote:
I run the Longfield joints and they are also made from 300m but cheaper.
With both of these joints, you'll have to grease them about every other trip you go out as they have no needle bearings in the caps.
These are a bushing style and the reason for this is so they can make the cross of the joint thicker and therefore stronger.
Honestly, these joints will do you no good without upgrading to cro-mo shafts at the same time.
Here's a new set-up that has just came available that uses CV style joints. It's 30 spline all the way out to the hubs...yummy!
https://www.rcvperformance.com/store...products_id=67
DB_1 is offline   Reply With Quote
Old 11-15-2009, 12:10 PM   #6
MEANEXPLODER
HADDAM, CT
91 XLT
Vehicle Specs
(Original Poster)
thanks DB1! me likey!
__________________
Old 01-27-2010, 04:59 PM   #7
RustENutz
Coos Bay, OR
1991 XLT
Vehicle Specs
Just shredded mine too again. 4th u-joint so far, only the second time it's taken out the axles. I'm cheap so I was looking at some Alloy USA X-joints. Not much more than spicer, can grease each cap individually and comes with full circle clips. Anyone have any luck with them??
Going to the junk yard today to find some Wagoneer axle shafts, then I'll take em' to the milling machine and machine them for the full circle clips....hopefully they'll last a while longer!
RustENutz is offline   Reply With Quote
Old 01-27-2010, 05:05 PM   #8
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
The number one cause of Ujoint failure on stock shafts/ujoints is the caps popping off. The half moon clips will not hold the caps on. It may be hard to tell what happened, because usually a couple of caps blow off, you dont realize it, the joint wallows around in the shaft ears and destroys them. Or, the ears break the ends off the joint. Or, the joint shock-loads the shaft ears and while the ears may hold it breaks the stub shaft behind its yoke.
You have 3 options-
1- Run aftermarket shafts and joints and never worry about it again (expensive)
2- Tack weld the caps on your stock axles
3- Cut the stock axles for full circle clips.
__________________
my rebuild
james t is offline   Reply With Quote
Old 01-27-2010, 08:12 PM   #9
RustENutz
Coos Bay, OR
1991 XLT
Vehicle Specs
Taking option 3. Just need to find my axles.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
