Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
94 Ranger Heat Indicator Wandering
Reply
Thread Tools
Old 11-09-2009, 01:10 PM   #1
buck2850
Winchester,Tennessee
'99 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys!!
I have enjoyed all the info that I have managed to collect in this forum,so before I begin, I want to thank all for this forum,and the infor it contains.
Now to my current issue .... I just recently bought myself a used 1994 4X4 Ranger XLT ( 4.0 cu),and am really enjoying it... but as is usual for something this old, it needs a little TLC ... the heat hand in this unit keeps ranging from normal,all the way up to too hot, then back to normal. I have flushed the system really well, changed out the thermostat,and radiator cap to no avail, The engine begins very normal and as you drive down the road it runs in the normal range, then it'll begin to head up the heat scale pretty quick until it gets out of the normal range to hot .... then it'll just head back to normal ,and stay there a mile or two, then back up.
I am planning on looking at the clutch fan next ... the plastic fan has several cracks, so I am hoping I can find one of those too ....I would really welcome any advice that any of you guys ( or gals!) could offer... maybe ya'll have run into this very thing too ?
Thanks !
buck2850 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-10-2009, 10:02 PM   #2
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Could replace the coolant temp sensor. Also look into the fan clutch.
__________________
Explorer how to videos Brakes, Intake, Seafoam, Coolant Flush, Oil change, Differential Flush, Inertia Switch, Thermostat, Transfer Case Flush, Throttle Mod, and more!
http://www.youtube.com/user/jlsparky7
If you like/use my vids you can thank me by subscribing to my youtube page! Thanks!
jlsparky7 is offline   Reply With Quote
Old 11-11-2009, 07:47 AM   #3
buck2850
'99 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks!
Thanks Sparky !!
I will definitely replace the fan clutch, and will look at the sensor ...... I am going to also try to find a replacement fan as this one appears to be cracked.
I appreciate your input !
Old 11-11-2009, 05:22 PM   #4
jlsparky7
Woodhaven, Mi
1996 5.0 XLT AWD
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by buck2850 View Post
Thanks Sparky !!
Np. It would be nice to know if it was actually heating up or if the gauge is off. No way of telling... I dont think.
__________________
Old 11-12-2009, 08:12 AM   #5
buck2850
'99 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
RE:Thanks
Yeah, I know Sparky .... well, I have picked-up the clutch,and fan from O'Reilleys, and will put it together Sat ... if the heat hand continues it's wandering ways, I think I'll go after an after-market gage,and check the heat with it ....
I appreciate your thoughts Sparky !!
Old 11-12-2009, 06:18 PM   #6
35Remmy
Binghamton NY, Hazleton PA, Northern NJ
'88,'99 Ranger, '00 EX
Vehicle Specs
Quoted: 0 Post(s)
My 4.0 did this once. Turned out to be a 20$ coolant temp sensor. Takes 5 minutes to change.
35Remmy is offline   Reply With Quote
Old 11-12-2009, 07:45 PM   #7
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 68 Post(s)
I ran into a similar problem in my 95 4.0l. After a bunch of testing, I found the waterpump had low flow and needed to be replaced. I had all the same exact symptoms as you.
Try this: while your driving and the temp going up above normal (catch it before it starts to drop), rev the engine up above 3000 rpm (to speed the flow of the pump). If the temp drops quickly then it s prob the waterpump.
A fan clutch wont affect cooling while driving at highway speeds. There is more airflow then the fan can pull. So if it still gets hot on the highway, its not the clutch.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 11-16-2009, 10:47 AM   #8
buck2850
'99 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Changed it all
Well guys, I took advantage of a pretty Sunday to just change it all ( water pump, fan clutch,and plastic fan blade for good measure)..... I already had changed the thermostat,and radiator cap after flushingthe system. ....I then took it for a good drive ..... so for that drive at least, and after the fan clutch oil got distributed, the temp got pretty stable, and we quit wandering .... thanks for all the help guys !!!!
Now, all I gotta do is find the source of a slight leak at the lower right side, bottom of pump. LOL !! here I go now re-tightening bolts !!!
Again ,I really appreciate all your input !!!!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
