Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Should trans shop take care of this for me?
Reply
Thread Tools
Old 11-09-2009, 07:10 PM   #1
35Remmy
Binghamton NY, Hazleton PA, Northern NJ
'88,'99 Ranger, '00 EX
Vehicle Specs
(Original Poster)
So my transmission was rebuilt 12,430 miles ago. The warranty was for 12,000 miles.
The past week I thought I noticed the transmission slipping out of OD for a split second, and the RPM's increasing 200, maybe twice in 5 days. Today I'm on the highway for 45 minutes and it did this about 7 times. Not under load...only when I'm going downhill. I'm doing 68-70 and the transmission just slightly raises the engine 200 RPM's and then it drops back down. Same trip back, it did it only once.
I'm thinking TCC solenoid maybe? I can MAKE the transmission do the same thing by tapping the brake pedal while my foot is still on the gas. Same exact RPM increase (200).
I called the trans shop and it's going in Thursday. I want to bring up the point that I spent 2 grand having them rebuild it (they are a very reputable shop)...430 miles is a mere 2 1/2 weeks of driving for me. I'm wondering if he'll just take care of it? If it was just a TCC solenoid and he won't, I know it's not a big deal, either. Solenoid and gasket/fluid.
What do you guys think?
35Remmy is offline   Reply With Quote
Old 11-09-2009, 07:14 PM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Which vehicle is this for? Did you try to adjust the bands, and check the fluid level in the transmission?
BrooklynBay is online now   Reply With Quote
Old 11-09-2009, 08:26 PM   #3
35Remmy
Vehicle Specs
(Original Poster)
Brooklyn...sorry...it's my '99 4.0 5R55E. No, I didn't adjust the bands. Fluid level is perfect.
Old 11-09-2009, 09:27 PM   #4
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
Vehicle Specs
only dropping 200rpm sounds more like a torque converter problem. it sounds like your converter is unlocking & and then locking up again. plus, the converter could be causing slippage. tapping on the brake pedal unlocks the converter; doesn't kick the tranny out of OD.
Jack...just a thought.
__________________
Jack of All Trades
Retired From Most
www.internationalcuemakers.com
www.jimboarmy.com
Latest Project: '86 Ranger 4X4
Jack Flash is offline   Reply With Quote
Old 11-09-2009, 09:33 PM   #5
BrooklynBay
Brooklyn, NY
Vehicle Specs
The TCC on the 5R55E has slippage programmed into it since it uses PWM to cycle it. The older TCC solenoids in the A4LD were plain on/off solenoids.
Old 11-09-2009, 09:42 PM   #6
35Remmy
Vehicle Specs
(Original Poster)
Jack, the TCC solenoid allows the torque converter to lock/unlock, doesn't it?
Brooklyn...what is PWM? I understand that slippage is allowed between shifts, but why would this occur while cruising, in OD, at a steady speed? It has never done this before, I am certain. I'm a fanatic at monitoring what's going on while I'm driving...it's habitual after 4 years of sweating my @ss off working in military engine rooms. <working on POS GM diesels>
OIC...Pulse Width Modulation...I believe mine is far in excess of the allowed range! I would think that PWM would occur without noticeable incident to the driver! Although we are talking about 11 year old technology here. Nah, something is up, I am certain.
Old 11-09-2009, 09:52 PM   #7
BrooklynBay
Brooklyn, NY
Vehicle Specs
The TCC & EPC solenoids are considered high wear parts because they are constantly cycling with various stages of PWM. The older TCC solenoids had a rest period when they were unlocked, unlike the new ones which are always doing something. This also puts a lot of wear & tear on the valve body, and the gaskets. The bolts get loose, and the gaskets leak on these transmissions.
Old 11-10-2009, 12:33 AM   #8
nitro71
Spokane WA
Vehicle Specs
I wish you the best on your transmission but 12K warranty and reputable don't really belong in the same sentence.
nitro71 is offline   Reply With Quote
Old 11-10-2009, 07:00 PM   #9
35Remmy
Vehicle Specs
(Original Poster)
Brooklyn...there's no way it should need replacing every 12,000 miles!!! Oh, by the way, my OD on/off button isn't working, either. If I press it, nothing happens; no light, etc.
Nitro...NY state is the only area I have lived in where all of the transmission shops offer only a 12,000 mile warranty. I know...it's ridiculous. In PA and NJ 24,000 miles is the normal warranty. Around here the only thing they know how to work on is 25 year old vehicles. It's a joke.
Old 11-12-2009, 05:58 PM   #10
35Remmy
Vehicle Specs
(Original Poster)
OK, so trans shop looked at my truck today. They couldn't find anything wrong. The owner checked the TCC solenoid, it was fine. He "scoped" the TPS (not sure what this entails) and it was fine. He said he has a video for me to watch that shows the operation of the transmission and everything looks perfect. There aren't any codes stored so he basically told me that based upon his diagnosis there is nothing to be concerned about; he has nothing else to go by.
The OD on/off button is just not working-I have to figure that one out. Whether it's the shift lever switch, a bad wire, I don't know.
Well, I guess I just have to wait for a code to get stored. The trans never did this before and I find it hard to believe that this is normal. Oh, and he didn't charge me...
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
