EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Question A4LD governor
Reply
Thread Tools
Old 11-10-2009, 08:46 AM   #1
stclist111
fraser, MI
91 ranger 2.3,2wd auto
Vehicle Specs
(Original Poster)
Unhappy Question A4LD governor
I have a 91 ranger 2.3 ,2wd A4LD auto trans, This last summer I had some shifting problems, changed fluid 2 times and filter. replaced indep servo, and put larger trans cooler on. The problem was, it would like be slipping comming out of first to second. I cleaned the governor, which seemed to be sticky a little, and I think it had been replaced before ,because it had a steel weight instead of an alum one. It worked fine, just had to make some small adjustments to the vac modulator,(new), However it seems to be acting up again, but just once and a while, and I'll have to shut it off and re-start, and it works ok. Is this a common problem with these governors and should I replace before the weather gets cold again (michigan). If I should replace, where can I get the parts cheap and fast, I had a hard time finding a governor before, I found one for $20.00 but not the weight or the gasket, I re-used the old gasket with sealent the last time.
stclist111 is offline   Reply With Quote
Old 11-10-2009, 09:13 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
WWW.Wittrans.Com sells the governor, and the other related parts. WWW.TransmissionPartsUSA.Com is a little cheaper in price on the weight.
BrooklynBay is offline   Reply With Quote
Old 11-10-2009, 10:38 PM   #3
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
Vehicle Specs
I've looked over the transmissionpartsusa site and I can seem to find an A4LD governor listed.
All that I find is the governor weight.. http://www.sonnax.com/announcements/56615-35.pdf
Can you post a link to the governor, please ?
J...thanks
__________________
Jack of All Trades
Retired From Most
www.internationalcuemakers.com
www.jimboarmy.com
Latest Project: '86 Ranger 4X4
Jack Flash is offline   Reply With Quote
Old 11-11-2009, 08:47 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
They don't sell the governor. WWW.Wittrans.Com sells it: https://www.wittrans.com/SchematicPa...E&LinkCode=680
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
