Go Back   Ford Explorer and Ranger Forums "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Cost of a complete transmission fluid change?
Reply
Thread Tools
Old 11-12-2009, 01:02 PM   #1
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Exclamation Cost of a complete transmission fluid change?
It's time to get the transmission fluid changed on my 2002 Explorer Limited. It now has 100K miles on it. I was curious to know a couple things about getting a transmission fluid change job done:
1. What is the cost generally?
2. The filter gets changed but anything else other than the fluid?
3. Do I need to look out to make sure the fluid change is a "REAL" fluid change that includes a backflush or complete flush or is a fluid change on these things pretty much standard regardless of where you go?
__________________
2002 Ford Explorer 4x4 Limited
P275/45R20 on 20" Rims
SyberTiger is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-12-2009, 03:44 PM   #2
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
This is what I found so far:
Mr. Transmission
$89.95 Filter change, replace fluid, new pan gasket
$129.99 Complete fluid evacuation plus filter and fluid
AAMCO
$79.99 Filter change, replace fluid, new pan gasket
Ford
$149.99 Drop pan, replace fluid, new pan gasket
$179.99 Complete flush without removing pan.
What seems odd to me is that Ford says there is no filter to change. They state there is only a mesh type filter that is cleaned in a flush operation and even their pan drop option does not change the filter because there isn't one to be changed. They said the only reason to drop the pan is to replace a leaking gasket. If you want to replace the gasket and do the complete flush to get the fluid our retained in the torque converter you have to pay $149.99 plus $179.99.
I'm confused now regarding the existence of a changeable filter nor not.
__________________
Old 11-12-2009, 03:55 PM   #3
kert0307
Pella, Iowa
'00 Sport and '89 B2
Vehicle Specs
Quoted: 0 Post(s)
If all you're doing is changing the fluid, you can do it yourself. There is a how to if you search for it on the site. All it will cost is about 15qts max of trans fluid. (about $35 for the regular stuff)
Here's some reading
http://www.explorerforum.com/forums/...t=fluid+change
__________________
____________________
89' B2 -Sold
00' Explorer Sport - Sold
05' F250 Crew Cab 4x4 Diesel Clicky tow rig/DD
2011 Ford Edge - Wife's DD
1978 Glastron CVX16 Project Boat
kert0307 is offline   Reply With Quote
Old 11-17-2009, 02:59 PM   #4
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Thanks guys. But I don't think I up for changing the transmission fluid. Had my fill of transmission fluid/filter changing on my old Camaro. Yes, I did the typical pry the pan off with a screwdriver trick and spilled old fluid everywhere....LOL!
Anyhooo, unless any of you waive a red flag I think I'm going with option #1 below at AAMCO for $135. I have 100K miles on the tranny and have never changed the fluid or filter. I understand the power purge will get the 3 quarts of fluid sitting in the torque converter that are hard to get out without more sophisticated equipment than I have.
1. AAMCO Power Purge® Plus Transmission Flush & Filter Change
2. AAMCO Power Purge® Transmission Flush
3. AAMCO Safeguard® Fluid & Filter Change
__________________
Old 11-17-2009, 07:30 PM   #5
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
If it was me, and the issues be known of the 2002 Explorer transmissions, I would pony the extra money for the change at the dealer, and have the change documented there as having taken place.
I'm not privy on the filter, but my 2004 Taurus had a similar screen that only needed to be flushed in the process, not replaced. Two shops I went to before going to the dealer (one was AAMCO) wanted to charge me for a filter that wasn't there.
Just my .02 but for as often as it's done, I can say that I would, and have, spent the extra $40 to have it done at the dealer and know your getting true Ford-spec fluids as well.
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 11-17-2009, 07:38 PM   #6
SyberTiger
Orlando
2002 Limited 4x4
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
I have a V8 and a 5R55W tranny. I've confirmed that this tranny does have a filter. Meaning, it has a part that is replaceable which contains a mesh screen. Not exactly a paper filter if you know what I mean.
I suppose this is somewhat consistent with what Ford told me. After 100K miles I feel it is better to change out that screen filter. Ford didn't seem to want to do that unless the tranny pan was leaking around the gasket. To do the flush/filter/fluid complete package Ford said they would charge me $149.99 plus $179.99 because to them it was like doing two different maintenance routines.
I think that $329.98 is a little excessive considering I can have the same thing done at AAMCO for $135.
__________________
Old 11-17-2009, 10:08 PM   #7
jasongt06
Virginia
2005 XLT
Vehicle Specs
Quoted: 0 Post(s)
You need to find a different dealer.
jasongt06 is offline   Reply With Quote
Old 11-17-2009, 11:23 PM   #8
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
^ agreed ^
The flat rate should include an allowance for the other work being performed. If it's over $300- yeah, I'd look around too
__________________
Old 11-18-2009, 08:03 AM   #9
Fox Fader
Columbus, GA
searching
Vehicle Specs
Quoted: 0 Post(s)
All you need to do is flush it. Sears will do it 12qts $89 13qts $129. (^_^)
__________________
_______________
2005 XLS 115k not even side steps (sold)
2001 Sport-Trac 131k Wife's
Fox Fader is offline   Reply With Quote
Old 11-18-2009, 09:04 AM   #10
joecrna
Las Flores, CA
98 XLT 4X4 sohc
Vehicle Specs
Quoted: 28 Post(s)
Where ever you go, do a full power flush. There's a lot more than 3 quarts left behind if you don't. As for the "filter", it's just a metal screen. No need to change screen in my opinion. Never ever "clean" the filter. Whatever you use, rag/towel, will leave lint behind. This is often what kills a modern trans when the fluid is flushed due to tight tolerences and small passages that this stuff ends up blocking. The fluid really needs to be changed though and I mean all of it.
__________________
Joe
98 XLT 4X4 sohc
TT, Custom Deaver leafs, 31x10.5 BFG's
Custom skid plates, recovery shackles
Defender rack, Warn transformer mount
and winch
joecrna is offline   Reply With Quote
Old 11-18-2009, 09:10 AM   #11
explorerguy89
Marlton, NJ
1999 xls and 2000 xlt
Vehicle Specs
Quoted: 1 Post(s)
i need mine done soon to =p
__________________
"v8powerbaby[04:48pm] : explorerguy i will make love to you for helping me fix that"
99' ex. xls been through hell and back
Quote:
Originally Posted by benji
I LOVE PINK FUZZY HATS!!
Quote:
Originally Posted by Tim Shaw
great.....bought the wrong deodorant. now i smell like watermelon bubblegum.....
explorerguy89 is offline   Reply With Quote
Old 11-18-2009, 10:32 AM   #12
gtyates
Goodlettsville Tennessee
'04 XLT & '05 Sport Trac
Vehicle Specs
Quoted: 9 Post(s)
I suggest getting dealer to do this one. I just had my '04 done at dealer. It was right at $200 total, but to me, well worth it!! I had mine done at 50k, not willing to go 100k before replacing fluid. Still much cheaper than a tranny replacement!! They did put in 15 quarts of new fluid to refill.
gtyates is offline   Reply With Quote
Old 11-30-2009, 04:16 PM   #13
Pyzon
Central Ohio/Western NC
'04 XLT
Vehicle Specs
Quoted: 2 Post(s)
I've become a believer in Amsoil lubricants and have an '04 with 70,000 miles, so what would be the chances of finding a shop that would be able to do a power flush to get all of the old fluid out, replace the screen with the real filter and fill with Amsoil full syn fluid ? Am I dreaming ? ?
Pyzon is offline   Reply With Quote
Old 11-30-2009, 04:25 PM   #14
kert0307
Pella, Iowa
Vehicle Specs
Quoted: 0 Post(s)
Some will let you bring your own fluid in to change to. As far as the filter goes, your best bet is to put an inline trans filter in your cooler line.
__________________
89' B2 -Sold
Old 11-30-2009, 10:42 PM   #15
Limited02
Gardner, KS
Limited02's Avatar
'02 Limited V8
Vehicle Specs
Quoted: 101 Post(s)
Surprised on those needing new pan gaskets because it's stamped on the pan that the gaskets reuseable.
Either way, a new gasket is better than an old one.
__________________
"Spending money I don't have, on parts I don't need, to impress people I don't know"
Sold 12/31/2015 - 2002 4.6 4x4, K&N CAI, Henson tuned, FM70 and 20" Boss 306's
Limited02 is offline   Reply With Quote
Old 05-02-2014, 07:20 AM   #16
JeremyDudrow
Harpers Ferry, WV
2005 Explorer
Vehicle Specs
Quoted: 0 Post(s)
I have an 2005 Explorer that has 103k on it. I bought it with 83k on it as it was a one owner vehicle that kept up with the maintenance. I just called the Ford Dealer near me and they charge $225-$240 for the transmission servicing. I plan on getting this done at the end of the month.
JeremyDudrow is offline   Reply With Quote
Old 05-02-2014, 10:25 AM   #17
Rubberhead
Fort Mill, SC
'07 E.Bauer & '14 XLT 4WD
Vehicle Specs
Quoted: 100 Post(s)
I usually get it done at the same time as the rear differential. I usually pay right at $400 for both from my Ford Dealer.
Rubberhead is offline   Reply With Quote
Old 12-19-2014, 12:07 PM   #18
ccrider
Eugene, Oregon
2002 Ford Explorer EB
Vehicle Specs
Quoted: 0 Post(s)
Dk Exp complete transmission fluid change prices
I'm sure this varies regionally but out here in the PNW, I just priced out Aamco, Dealer and my usual shop for things I don't want to do myself. I want a full flush, both diffs and transfer case as well as transmission fluid changed.
Here's what they said:
Aamco - $435
Ford Dealer - $550
Local Shop - $550
So, I guess since the truck is new to me with 137K on it, I could spend the extra to have Ford do it, or have my shop do it for the extra C note.
__________________
02 EB X
4.6L
ccrider is offline   Reply With Quote
Old 12-19-2014, 12:20 PM   #19
Stick4503
Winder, Georgia
1996 & 2004Explorer 4x4
Vehicle Specs
Quoted: 20 Post(s)
The 5r55w you should have definitely has a changeable filter. Power flush can be a problem if your fluid has not been changes before as required. Flushing will stir debris up that can get in all of you valves and stuff.
Stick4503 is offline   Reply With Quote
Old 12-19-2014, 03:36 PM   #20
mikeinri
04 Explorer, 94 XLT (RIP)
Vehicle Specs
Quoted: 8 Post(s)
Quote:
So, should you drop and clean the pan first?
Mike
mikeinri is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
