| Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Tampa, FL
2002 Ranger
No power to fuel pump relay
Whats up all. Ive read several of the posts but couldnt find one that has the same issue as mine. My truck had sat for about a year and the engine and tranny were replaced. Once installed, it fired up and ran fine. Then I tried to start it later and it would try to fire, but wouldnt run. I unplugged the battery and the next day it fired up and ran fine.
I had a hard time starting it again 8 miles later, but it ran and went about 100 yards and shut down again. Hasnt run since. I have verified that it is not getting fuel. The fuel pump works when the cover from the fuel pump relay is removed and operated manually. There is not 12V coming into the relay in the power box in the engine compartment. The check engine light turns on when you turn the key to on. What can I do to figure out if it is the computer or a wire issue, which seems to me it would be unlikely. Thanks for your thoughts. |
#2 | |
Offroad Moderator
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
Quote:
__________________ I have Rocks in my head. What's in yours? ![]() '95 ranger xl 4x4 2.3L std cab, 2 sticks Ranger RegistryThe Squirrel '91 4x4=To much to list, much more to add.. Project "X" and more Pics & Mod's ListHow to: Wheels,Tires, & Lifts... Buy Explorerforum.com Items here |
#3 | |
Living in Greenland
Holland, MI
'00 V8 XLT
I actually think it's a wiring issue. The time elapsed between shutdowns getting shorter and shorter until it completely dies sounds like a wire somewhere that was either overheating and burning the insulation off, then/or popped a fuse after shorting out. If it sat that long, I'll bet you had a rodent issue, and someone snacked on some wires...
__________________ Quote:
#4 |
prosperity,SC
Sounds like you whats goin on already. Time to get the wire diagram and start tracing the wires.
That is so much fun you wont be able to stand it. LOL __________________ 1994 4.0, auto, 4.56, welded rear, open front, 35s, 6" long arm lift, winch and a few trail scars. |
#5 |
In the Middle
'97 Ranger 5.0
Is there a fuse to check?
#6 |
Offroad Moderator
...There is a relay fuse and a relay, both located in the power distribution box under the hood on the 95 and newer Rangers...
#7 |
Tampa, FL
2002 Ranger
OK guys, I just got back into the country and messed around a little more. I have discovered that if I short the fuel relay out, the truck still wont start. That prompted me to check for spark.... And.... no spark. When I replaced the motor I replaced the complete engine with all components. I think the year was a 2003 and my truck is a 2002. Everything plugged in just fine so Im confident there is not a compatibility issue. I have 2 spare coil packs so I can swap that out to see if its the issue, but is that likely? Would a bad coil also effect the fuel supply?
Im still suspecting the computer or something to do with the PATS. Last edited by Pumfe; 12-14-2009 at 07:56 PM. |
#8 | |
everett
1994 limted
Quote:
| Thread Tools | |
