EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Rear Suspension Toe Link Ball Joint
Reply
Thread Tools
Old 11-24-2009, 02:24 PM   #1
jhumbertoap
Painted Post, NY
2002 XLT
Vehicle Specs
(Original Poster)
Hello everyone,
My 2002 Explorer feels "funny" when driving in the highway; it changes direction slightly for no reason.
I recently replaced the rear bearing, and noticed that I could move the rear wheels side to side resulting in a very loud clunky noise. Then I noticed that both toe link-ball joints were shot, but I can't find the replacement online.
Any direction will be appreciated, thanks.
jhumbertoap is offline   Reply With Quote
Old 11-24-2009, 03:54 PM   #2
Tarpman
Escalon, CA.
Tarpman's Avatar
03 Explorer XLT 4.0
Vehicle Specs
Rear toe link
Try Rockauto.com, look under suspension and then rear suspension toe link. i replaced mine, but don't recall part #. easy to do, just make sure the new one is adjusted the same length as old. good luck
Tarpman is offline   Reply With Quote
Old 11-24-2009, 07:09 PM   #3
jhumbertoap
Painted Post, NY
2002 XLT
Vehicle Specs
(Original Poster)
Thanks...
It's been ordered!
Old 10-05-2010, 01:23 PM   #4
cjcentral
Indianapolis, IN
Limited
Vehicle Specs
I just looked at RockAuto, and could not find toe link, or suspension rear.
Cany you affer nay insight as to were else to look?
cjcentral is offline   Reply With Quote
Old 10-05-2010, 02:09 PM   #5
matt0248
Chicago
02 XLT V8
Vehicle Specs
This has been discussed many times. Dealer only item and back ordered at this time. Good luck and godspeed.
matt0248 is offline   Reply With Quote
Old 10-08-2010, 09:10 AM   #6
cjcentral
Indianapolis, IN
Limited
Vehicle Specs
Smile Newer Toe Links
I lucked out, my '02 Explorer used the newer 17mm stud, picked up two new toe links at the local Ford dealer yesterday, back on the road today.
Everyone gets lucky once in while!
Old 10-08-2010, 09:25 AM   #7
matt0248
Chicago
02 XLT V8
Vehicle Specs
How did you determine this? was it from the build date? Or did you have the old one in your hand?
Old 10-08-2010, 01:53 PM   #8
cjcentral
Indianapolis, IN
Limited
Vehicle Specs
Smile
I tried the VIN number decoder, and could not get a date.
So I used a pickle fork to 'pull' the old one out just far enough to slide a box wrench over the shaft, 17mm fint 15mm did not. Broke out my excel spred sheet, my reverse polid notation calulator and figured it must be a 17,, shaft.
Only took aout 20 minutes.
Three phone calls later I had two toe links reserved.
Old 10-12-2010, 01:55 PM   #9
MemorEsto
Corry PA
2002 XLS
Vehicle Specs
To let everyone know. The different sizes are based on before or after build date of 3/4/02.
Just called the dealer.. $186 bucks for this stupid rod. I hate independent suspension.
__________________
President of Acer Offroad and ErieJeepPeople
MemorEsto is offline   Reply With Quote
Old 10-13-2010, 09:28 AM   #10
xTOM153x
West Islip Long Island
2003 XLT
Vehicle Specs
Heres the part https://www.silverstatefordparts.com...ord-parts.html thats for the 03 explorer which I believe is the same 03-05 and the 02 is different according to Silver State Ford but just put your year in the search parts thing also your VIN when you go to checkout they'll make sure you have everything right. Apparently it is backordered but they should be back in stock within a week or so its annoying how theres no aftermarket part for this. My toe link is so badly worn its creaking and has a ton of play which I'm getting worried about.
xTOM153x is offline   Reply With Quote
Old 10-18-2010, 01:52 PM   #11
cjcentral
Indianapolis, IN
Limited
Vehicle Specs
In Stock
Paul Harvey Ford in Indianpolis has 3 of the 17mm (Late model 02 - 05) left in stock. $166 but at leat I'm back on the road.
Old 10-20-2010, 09:31 AM   #12
xTOM153x
2003 XLT
Vehicle Specs
One of my friends works at a Ford dealer and got me a great deal. The whole thing out to 110. Regularly the piece is 166+ tax what a rip off if you ask me it's just a bar with a tie rod end.
Old 12-20-2010, 05:31 PM   #13
codeman44
Washington State
02 XLS
Vehicle Specs
I also need to replace at least one of these in my 02 Explorer. Is there any reason why these wouldn't work? It's super cheap, so I'm not sure.
Moog Rear Sway Bar Link - Direct OE Replacement
2002-2005 Ford Explorer at
http://www.autopartsdeal.com/catalog...+Sway+Bar+Link
codeman44 is offline   Reply With Quote
Old 12-20-2010, 10:50 PM   #14
jhumbertoap
Painted Post, NY
2002 XLT
Vehicle Specs
(Original Poster)
Not quite the same part. It is riduculos. Ford puts a shity part in the X and then does not supply its replacement for months... Just unacceptable. My X handles like crap and I don't have a solution because f$#$#$# manufacturer does not want to supply the F%^#%$$% part... Sorry for venting... but this is one more bad experience with Ford...
I just visited the local dealer, and the guy seemed to enjoy my frustration... what kind of service is that?
I've owned VW's and Nissans... much better customer service, not to mention much better reliability... guess what's going to be my next car?
Old 12-21-2010, 06:32 AM   #15
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
The rears are adjustable and from the looks of it you might be able to buy just the tie rod end, not 100%, unless body side is whats worn out. Anyone try and see if the Fronts would work? They look similar but size might be different, they do work on the same principle, you might get lucky, fronts look cheap too?? But i would have to take it in to a parts store and compare . . .
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 15k
2010 Sport Trac Limited, V8 4WD, 55k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 12-21-2010, 10:28 AM   #16
jhumbertoap
Painted Post, NY
2002 XLT
Vehicle Specs
(Original Poster)
Quote:
Thanks for the advice... the tie rod end is the one worn out, so I may have to try something like that... I bet it's not going to be easy braking that tie rod loose at the end of the bar (salt and rust don't help), but I have to try it!
Old 03-20-2011, 07:38 PM   #17
jstorm001
Levittown , PA
2002 Explorer Eddie Bauer
Vehicle Specs
Last year i brought my 2002 explorer to tires plus i had them replaced my rear springs because i failed PA safety inspection so they installed quick struts but ever since then everytime i hit a small or big bump i hear this loud tap in my rear im thinking its the Toe Link's because the rubber cover on the ball joint on the toe link's is torn badly on both sides the quick struts look fine . never had this tap befor when my spring were broken i guess because i got it repaired now i hear it now . i always look at the rear end only thing i see wrong is that toe link everything else looks fine.
jstorm001 is offline   Reply With Quote
Old 09-02-2011, 10:02 AM   #18
Truth Explorer1
Detroit Michigan
2002 Limited
Vehicle Specs
Lightbulb Toe link Moog Part #s
So I fig out that moog has both inner, and outer toe link parts.
Inner link part # ES800560
Outer link part # ES800651
Just ordered them from my local auto prts store. Hope this clears up having to pay out the @ss at the stealer ship!
Truth Explorer1 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
