Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
modulator valve location.
Reply
Thread Tools
Old 11-28-2009, 03:30 PM   #1
p2e1r12t
ocala, fl.
'91 sport 94 navajo 03xls
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hey guys, i've got a 1996 explorer 4.0 auto 4x4 that i'm trying to replace the modulator on. i've followed the advice of some of the threads here by going thru the access panel under the carpet but i don't see a modulator anywhere behind the two servos. anyone know if it could be somewhere else? do all explorers have them? i'm baffled. thanks for any help
p2e1r12t is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-28-2009, 04:37 PM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
no modulator
I believe that you have the 4R55E transmission on your 1996 V6 which is electronic shift controlled by the PCM. There is no modulator to find. The modulator was used on the A4LD transmission (1991 thru 1994).
2000StreetRod is online now   Reply With Quote
Old 11-28-2009, 04:44 PM   #3
p2e1r12t
ocala, fl.
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks for your reply. kind of a bummer to find this out after i have already torn it apart. autozone even sold me a modulator for my 96. do you know if there is another part that can cause a delayed shift from 1rst to second? it doesn't happen all the time and has been doing so for about 6 months. it's my daughters' truck and she lives in jacksonville so while she is home for holidays was hoping to get this and a couple of other problems sorted out. truck doesn't get the maintenance it used to since she moved. anyway, thanks for your help!
Old 11-28-2009, 07:24 PM   #4
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
ATF level?
I assume that you've checked the ATF level and it was normal.
You may want to confirm what type of transmission you have by checking the door plate under the heading TR I believe. I'll have to look up the code for the 4R55E and the A4LD since I have the 5R55E.
Is your check engine light on? If so, have you read the diagnostic trouble codes?
Old 11-28-2009, 07:40 PM   #5
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
transmission codes
Here are the transmission codes:
T (1992-1995) A4LD
T (1996-2001) 4R55E
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
