| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
zanesville, ohio
2002 ranger xlt
Bad 4WD module?
i have a 2002 ranger xlt, when i start the truck, there is clicking coming from the 4wd control module, even when the 4wd selector is in 2wd. tried to put it in 4wd the other day, nothing, heard the random clicking coming from the module, turned the knob to 4wd, it engaged. i figure the module is going bad, but just wondered if anyone has had the same problem, and any suggestions would be appreciated.
#2 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've moved your thread into the transmissions & transfer cases section. It sounds like it's the module from your description.
#3 |
Courtenay, BC
99 B4000 4.0L OHV
I would like to suggest you check your voltage that is going thru the dash switch and grounds. Are you getting a voltage to the shift motor and is it operating properly?
#4 |
zanesville, ohio
2002 ranger xlt
bad 4wd module
i found out that after the truck warms up, interior wise, the module works fine, restarted the truck after it warmed up, and the lights in the dash lit up like they are supposed to, 4wd high and low worked fine, i ordered a new module yesterday, im not taking any chances with the white stuff right around the corner, ill post with the results as soon as i get them, thanks everyone for the replies, i really do appreciate it.
#5 |
zanesville, ohio
2002 ranger xlt
bad 4wd module ?
I replaced the module yesterday and it fixed the problem, 4wd lights work when you start the truck as they should, and no more clicking from the module. thanks to everyone who responded to my post.
#6 |
Brooklyn, NY
Thanks for the update! What was the part number of the module?
#7 |
zanesville, ohio
2002 ranger xlt
bad 4wd module
the part number is TM-101, there are other numbers on the box under these, they are.. 1L5Z-7E453-AC shift control module, this is for a 2002 ranger xlt, 4.0 automatic, the dealership told me there were a few different module numbers, for different engine/transmission combinations.
| Thread Tools | |
