Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
How do I test the 4x4 switch (buttons)?
Reply
Thread Tools
Old 12-05-2009, 01:40 PM   #1
motopsycho650
Denver, CO
1994 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Not too long ago, I put a re-built tranny from a '92 explorer into a '94 explorer. The original '92 transfer case was installed in the '94 with the tranny, and I still have the t-case from the '94.
The other day, I tried 4 wheel drive. I hit the button, and nothing. Not clicks from the t-case, and no dash lights. Later that day, I had the 4x4 light on the dash, and the light next to the button come on. After more fiddling, they went back out.
I jacked up the front wheels, and tried turning the front drive shaft. Turns out that the t-case is stuck in 4 wheel drive regardless of if I have a dash light or not. I had not noticed the front end being locked because I have manual hubs.
Besides having a possible bad t-case motor, there are 2 other possibilities I am wondering about:
1. Is a '92 t-case and actuator motor compatible with a '94? (the 2 actuator motors looks a little different from each other).
2. Do I possibly have a bad switch/button? How would one test that?
__________________
'94 Explorer XLT - 4x4 - Automatic - 4 Door
There is a reason technicians call them "Exploders"
motopsycho650 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-05-2009, 04:49 PM   #2
shaggymane
topeka, kansas
91 navajo
Vehicle Specs
Quoted: 0 Post(s)
read this thread
http://www.explorerforum.com/forums/...d.php?t=202166
shaggymane is offline   Reply With Quote
Old 12-05-2009, 06:09 PM   #3
motopsycho650
Denver, CO
1994 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for that link. I'm going to go test the 4x4 module tomorrow. I bet I'll need to replace t-case motors...
__________________
Old 12-06-2009, 03:00 PM   #4
shaggymane
topeka, kansas
91 navajo
Vehicle Specs
Quoted: 0 Post(s)
you'll see in that thread the most common problem and an easy fix is replacing the broken/vanished *stop* with a piece of fuel line.
No need to rush out and blow money unless your buying drinks
Old 12-06-2009, 05:20 PM   #5
arco777
arco777's Avatar
1994 Explorer 2dr 4x4
Vehicle Specs
Quoted: 99 Post(s)
Second that, I have fixed one before with a chunk of fuel tube and it worked great. The motor assembly is easy to remove and rebuild.
arco777 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
