cb75
- December 11, 2009
- Florence, Ky
- 98 4wd
Hello, I am new to the forum so I hope I'm posting this properly. Anyhow, I've got a dead 1998 explorer which I desperately need to get up and running. Heres the problem. Started having low power problems the truck would lose speed while driving up decent sized hills, started stalling at stop signs and some hesitation while taking off. So I changed the fuel filter after work one night then left to go home, got on expressway and it would not go over 50mph, started slowing more until I pulled off into rest area, pulled into park spot where it died and would not re-start. Tried several times and finally got it to start one more time, but as soon as you put it in gear to try and move it died again. Ended up running the battery down, had a friend come and trailer it back to his garage. The following day I began the troubleshooting process. Replaced fuel pump, charged up the battery- still same results. Thats when I found this site and read about several things to check, including the crank position sensor, which I checked and noticed that it appeared to have been rubbing the toothed gear, so I tried smacking it to see if that would make any difference, and when I tapped it the fuel pump relay started clicking, and another relay or something also clicked and there was a buzzing sound on top of the engine that sounded similar to fuel pump. Anyhow, everytime I barely tap the CKP sensor, it trips the relays, and whatever it is on top of engine. I replaced the CKP sensor and the new one does the same thing, and still it won't start. Has anyone ever heard of this? (thats if my post makes any sense) I'm going back in tommorow morning to try and figure it out. Thanks for your time, sorry for such a long post. cb75
