Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Coolant Temp Gauge Not Working
Reply
Thread Tools
Old 12-12-2009, 04:41 PM   #1
DavidB82
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question Coolant Temp Gauge Not Working
Hello, I'm helping a friend fix their 2000 Explorer 4.0L OHV. The problem is that the temperature gauge sits below "C" whether or not the engine is warmed up. So, I searched around on this site and found the location of the Temp Sender (the sensor in near the thermostat with one 1 wire). I did the test of grounding the wire to see if the gauge works and it does. Straight to ground puts it pegged above "H" and putting a 100 ohm resistor in line puts the gauge somewhere in the middle.
So, I figured it must be the sender. I got a new one and put it in. Unfortunately, the needle still sits below "C". I let it warm up some to where the radiator hose was warm and the needle still hadn't moved.
I tested the resistance through the temp sender connector prong to the brass body and got about 2500 ohms. Given that 100 ohms put the needle in the middle I was wondering if the new temp sender might be bad? Does anyone have a chart/table of the resistance of the temp sender resistance vs temp?
If anyone has any other ideas I'm all ears.
Thanks,
David
DavidB82 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-16-2009, 11:23 AM   #2
DavidB82
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Nobody??
Old 12-16-2009, 02:18 PM   #3
Kriegen
Montgomery, AL
1999 Mounty 5.0L AWD
Vehicle Specs
Quoted: 0 Post(s)
how warm does the heater blow if you turn it all the way up? The issue could be a thermostat that is stuck open. My mountie had a similar problem, the temp gauge seldom went above C and my heater never blew more than slightly warm air. Replaced the thermostat and now the gauge goes to where it should and I get nice hot air.
__________________
Charles
1999 Mercury Mountaineer 5.0L AWD Stock ~190K miles
Kriegen is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
