Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Explorer dies when coming to a stop.
Reply
Thread Tools
Old 12-14-2009, 11:55 AM   #1
lpatno
Fort Campbell, KY
2000 Ford Explorer Eddie
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
When i am driving my ford Explorer Eddie baur edition when i put on my brake completely to stop at a stop sign it completely dies and then i have to put it in park and restart the car it stays running as along as i am driving it and then when it is in park i would like to know what could possible be causing this and if its an do it your self fix
lpatno is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-14-2009, 12:16 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome and that sux bout ur x dying when at a complete start
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 12-14-2009, 07:55 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section. Clean the IAC valve, and see if it helps.
BrooklynBay is online now   Reply With Quote
Old 12-14-2009, 08:00 PM   #4
Electrohacker
Clinton Twp, MI
'96 XLT V8 4WD
Vehicle Specs
Quoted: 1 Post(s)
FIRST GUESS
is your brake booster vacuum line connected?
I disconnected mine to clean the engine and it ran rough and almost died when it was disconnected unless I clogged it
__________________
it's funny that everyone's embarrassed to drive a station wagon, but drop a truck chassis under it and call it a SUV and suddenly everyone wants one...
my truck's build up (in progress)
Electrohacker is offline   Reply With Quote
Old 12-15-2009, 09:26 AM   #5
MATTS02
Columbus, Ohio
'02 Sport
Vehicle Specs
Quoted: 2 Post(s)
My 92 did that, and it would die if I took a corner fast. Fuel pump was going bad.
MATTS02 is offline   Reply With Quote
Old 12-15-2009, 01:05 PM   #6
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
What if you shift to neutral as you're coming to a stop? Does it still stall? I'm wondering if it could be a trans issue (failure to unlock the torque converter).
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline   Reply With Quote
Old 12-15-2009, 01:08 PM   #7
Mirge
Tulsa, OK
'98 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Any other symptoms? Rough idle? Rough idle during a COLD start (ie: overnight)? Any hesitation/stumbling under load? Any odd sounds/noises?
Mirge is offline   Reply With Quote
Old 12-15-2009, 01:45 PM   #8
jremington59
Watertown, NY
jremington59's Avatar
1997, 99 and 2000 5.0's
Vehicle Specs
Quoted: 142 Post(s)
I'd have to guess it's the idle air control valve. Does it stall all the time with your foot off the gas after it warms up?
jremington59 is offline   Reply With Quote
Old 12-15-2009, 02:07 PM   #9
98moutaineer
chesterland Ohio
98 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Can some one please help me
Quote:
hi i saw this post and i have most of these problems but only the first start of the day do you know anything i can do to stop this from happening.
__________________
1998 Mercury Mountaineer AWD, 2'' Wheel Spacers, 10'' Orian Sub, Boss 5.5'' Touch Screen Head Unit, 34,000 miles.
98moutaineer is offline   Reply With Quote
Old 12-15-2009, 02:09 PM   #10
Mirge
Tulsa, OK
'98 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Rough idle (to the point of stalling if I didn't give it gas) on a cold start (overnight) meant new upper & lower intake manifold gaskets in my case. Common apparently.
Old 12-15-2009, 03:04 PM   #11
98moutaineer
chesterland Ohio
Vehicle Specs
Quoted: 0 Post(s)
thanks a lot man i really appreciate it.
__________________
Old 12-15-2009, 03:18 PM   #12
Blazepet7
Queens, NYC
99' XLT 5.0
Vehicle Specs
Quoted: 0 Post(s)
welcome...my guesss would be a vacuum line, when the seafoam procedure is done you disconnect the pcv valve and run the seafom through if you leave the hose off it eventually dies try the seafoam i noticed better response when i did it.like the others asked does it ride rough or normal with gas peddal pressed or just when you stop..it could be a clogged hose it cant hurt to run the seafoam as long as you follow the directions...goodluck
__________________
99' 5.0 V8 XLT-FORD Red, Hella 500 Fogs,Pioneer AVIC D1 Navi, Sony DVD Player,TT/Shackles, AAL, Custom Rack lights, Rancho 5000's, LED Puddles, Custom Front Tow Hooks Many More Mods to Come
Blazepet7 is offline   Reply With Quote
Old 12-15-2009, 03:26 PM   #13
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Idle adjustment procedure
I agree that the most likely source of your trouble is the IAC valve. If cleaning it solves your problem then I suggest that you perform the Idle adjustment procedure . If you do, the next time that your IAC valve quits working your engine won't die.
2000StreetRod is offline   Reply With Quote
Old 12-15-2009, 03:55 PM   #14
lpatno
Fort Campbell, KY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
the only time it ever did it was coming to a complete stop as i put my foot on the brake but now when you put it in drive or 2nd or 1st it will die but it will stay running in park or netrual
Old 12-15-2009, 03:58 PM   #15
Mirge
Tulsa, OK
'98 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Well the IAC valve would probably be the first thing I'd check by cleaning it out... super easy to get to (it's literally RIGHT THERE on top)... and relatively inexpensive to replace if you determine it needs it.
Old 12-15-2009, 04:45 PM   #16
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
Quoted: 1 Post(s)
I'm having vibrations, like... a stalling kinda feeling when at a complete stop... and sometimes when on the gas at speed il feel it a little bit.. I've cleaned my relatively brand new IAC and no change... would this still be the issue? Not to mention weeks ago my idle stuck at 2-3K and I had to pull over... I've had that issue in the past... changed the IAC and I was good to go... Is this one going bad now too or.. idk... the way everything works on mine.. a lot of oil gets sucked through there.. can that mess up the IAC?
__________________
Lifted 98 302
Quote:
Originally Posted by joel903 View Post
These freaken explorers! Everything breaks
Ford: Fixed Or Repaired Daily. But still going, kicking and screaming all the way. =D Yeaaah.
storlied is offline   Reply With Quote
Old 12-15-2009, 07:07 PM   #17
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
Good call!
Quote:
Do your brake lights work? The PCM monitors the brake pedal stop switch to differentiate between coasting and braking. If the vehicle speed (or maybe its the engine speed) drops to a set value with the brake applied the PCM unlocks the torque converter.
Old 12-15-2009, 07:14 PM   #18
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
Quoted: 1 Post(s)
I tried the neutral thing with mine, it's lessened but it's still there... =\
__________________
Lifted 98 302
Old 12-15-2009, 07:32 PM   #19
gijoecam
Village Idiot
Trenton, MI
Vehicle Specs
Quoted: 10 Post(s)
Quote:
It unlocks the TC if the throttle position drops to the closed voltage (RATCH) too. It doesn't rely solely on the brake on input to unlock it (In other words it does it for both).
__________________
Old 12-16-2009, 08:35 AM   #20
lpatno
Fort Campbell, KY
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Could it at all be a timing issue and i will have my husband take a look at the IAC and clean it
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
