| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
Illinois
2000 explorer xls 4x4
2000 explorer sticks in 4 wheel low
2000 EXPLORER XLS OCCASIONALLY STICKS IN 4 WHEEL LOW AND WILL NOT COME OUT. i KNOW THE PROCEDURE OF HAVING TO HAVE THE BRAKE AND CLUTCH ENGAGED AND IT WORKS SOMETIMES AND OTHER TIMES NOT.
tHIS SEEMS TO BE A SOMEWHAT COMMON PROBLEM - ANY IDEAS WHAT IS CAUSING IT ? |
#2 |
NC
'95 XL 4x4
Shift motor. There is a thread somewhere on cleaning it or more specially the contacts that tell the GEM what position the motor is in.
#3 |
Illinois
Thanks for the reply.
I could not find the link or reply you referenced, but I did take the sift motor off and the outer cover that contains the electronics is a sealed unit and not serviceable. Any other ideas ? |
#4 |
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Without being able to see what the GEM is seeing in terms of inputs and outputs, it's a guessing game at best. Could be an intermittent lack of signal from the neutral safety switch or the brake on-off switch, could be a bad motor, could be a bad switch a $3 relay.... It's tough to guess where the problem lies. 5 minutes with an NGS or WDS scanner at a dealership would pin the problem down.
Now, in general, I would expect that if the system was TRYING to get the case back into high range and failing, it would flash a trouble code. I would lean towards the system not trying in the first place, and that probably eliminates a few things, like the motor itself and the relays (but again, no way to know for sure without a good scanner and a knowledgable tech). __________________ -98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress! -'00 F-150, mucho mods "We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz We must believe in free will — we have no choice. ~ Isaac Bashevis Singer I'm not smart, just a resourceful idiot. ~ Me |
#5 |
Illinois
The problem is very intermittent, so trying to catch it on the scan tool is almost impossible at this point. After what I have been reading I am thinking it has to do with the shift motor and not knowing what position it is in from time to time. I will pull it apart again and take another look - it seems to make the most sense. Most of the time it works - in fact I can have the key in the on position (KOEO), depress the clutch and brake and place the selector dial from auto to 4 high and to 4 low and hear rthe shift motor working just fine. There is no signs of any strain on the motor at all. I will see what happens tonight and try to re-post what I found. Thanks ! |
| Thread Tools | |
