Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Hood Latch Stuck
Reply
Thread Tools
Old 12-19-2009, 01:15 PM   #1
Lazzman
Massachusetts
1998 Sport 4wd- V6 Sohc
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Hood Latch Stuck
I replaced the little rubber hood bumpers on my truck a year ago and at that time decided to, for some stupid reason take of the hood latch mechanism and then re-install it.
Ever since that time I have had trouble opening the hood, it has remained on many occasions jammed shut and will not pop up into the semi locked position. I can figure that I put the latch back not in the exact position it was in originally.
Well now I have done it good, the battery needs to be replaced and I cannot get the hood open.
I remember when this happened before, someone on the board told me that there is a manual latch that can be accessed from the grill area with a screw driver and it will take the tension off the spring latch and allow the hood to open, hoping someone knows how to do this so I can open the hood.
Also the excessive tension on the hood latch spring would indicate that the latch has too much force on it and needs to be adjusted, but would I need to move the latch assembly up or down to relieve some of this tension?
Thanks very much for the help.
__________________
1998 Sport, 4x4, K&N Filter, E3 Diamond Fire Plugs, Magnecore 8mm Wires, Screamin Demon Coil, 2.5" Flowmaster Catback, 255/70/16 tires, Performance 5R55E VB, Royal Purple synthetic lubricants, Zabteck breather bypass, 4.10 gears, Warrior Shackles, EBC Brakes.
Lazzman is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-19-2009, 01:20 PM   #2
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
Have somebody push down while you pull the release. That should get it open if indeed it's adjusted to tight.
my98nnj is offline   Reply With Quote
Old 12-19-2009, 02:51 PM   #3
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
Quoted: 0 Post(s)
I had to reach in the right hand side of the grill and push the cable out of the slot then pull on it.
robertoa1a is offline   Reply With Quote
Old 12-19-2009, 06:12 PM   #4
Lazzman
Massachusetts
Vehicle Specs
Quoted: 4 Post(s)
(Original Poster)
Thanks.
I am going to give this a try.
We are supposed to get slammed with snow tonight and I need the truck up and running for the morining.
Thanks again
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
