| Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35 |
Thread Tools |
#1 |
Wannabe Elite Explorer
2000 ford explorer xls
I have a 2000 ford explorer xls, vin digit is X it is a 4.0
It has Auto/4Hi/4lo on the selector nob. The axle code is D4 Have few questions: First I was wandering if it has Limited slip in the front or is it just in the rear? I have notice that it seems to not have good traction. What I mean is I got stuck on a small driveway that was slanted it had about 5 inches of snow on it. Had to have a pickup truck pull me out. The vehicle just sit and spin. I had some one look at the wheels see if all 4 wheels were spining and they wasn't. One wheel was spining in the front and one in the back. So I thought it was because I was in just regular 4 Hi, so I put it in 4 lo and still the same response. So my question is, could the limited slip be worn out? If so can I repair it? I have read that it is a good idea to change the fluid, but my rear end says it never needs to be changed. but some say to add new fluid and it might make it work. So if that is the case, where do I buy this fluid and what type? thanks Last edited by jbish1572; 12-21-2009 at 03:54 PM. |
#2 |
Land of Corruption
06 F-350
Sounds like the clutches are gone in the rear differential. But I am not an expert, nor do I play one online. LSD should engage both tires to spin given the conditions you gave. Yes, you can rebuild the LSD, If you have the proper tooling and knowledge to do so.
As for differential fluid that "lasts a lifetime" .. "lifetime" of your differentials depends on whos definition of lifetime you want to believe. I believe that if you want to have that LSD live, change the fluid. I use the motorcraft brand synthetic fluid availble at the Ford Stealership, and get the friction modifier. Might be pointless until you get the LSD to work properly..I dont know. Someone else with more expertise will add to this please. __________________ 1999 Mountaineer, RIP
Last edited by my pos mounty; 12-21-2009 at 03:55 PM. Reason: no LSD in front diff |
#3 |
Spokane WA
I'm pretty sure stock LSD's wear out pretty easily. Doubt new fluid will do much. I'd probably swap out the fluid if it's never been drained. I'd be more inclined to look into better tires then replace LSD clutches myself.
#4 |
Wichita, Ks
98 Sport, 95 Ranger SAS
limited slip is more like limited grip. Instead of all the power going to the wheel thats easier to turn, a tiny fraction goes to the gripping wheel. Check this out:
http://www.youtube.com/watch?v=q-rQTHMVAuw __________________ Wheel it, Break it, Fix it, Repeat... |
#5 |
Atlanta
98 Mountaineer
Next time try applying the parking brake to even out the power to both rear wheels.
Since the easiest wheel will spin, if you equalize the fricton, both will spin instead of just one. It works sometimes. |
#6 |
Elite Canuck, Eh ??
In the Great White North where winter never seems to end ,Ontario,, still ice fishing,,
96xl,99xls,old Rangers
hmm for the price of repairing a ls, and new fluid, maybe go look at the JY for an open carrier, and than put a locker in , than call it done for good,
than both wheels will definately have the same amount of drive,, http://www.aussielocker.com/item.php...6/306008/.html i have this one, works great , and good price too , __________________ Log Roller,, Fox Coilovers 35's and others, , Truck of the month Ranger Of Danger,,,project truck, also look for Blues Traveller Elite registry, , |
#7 |
Lebanon,Ohio
'91 EB & '96 xlt
You can improve the function of the stock limited slip. Stack the frictions differently when you rebuild it. I believe it's just Friction/steel/friction/steel and so on, but you can find different stacking orders online to make them grab harder. I don't remember off the top of my head. Another big thing you can do is use an S-spring out of an F-150. The spring is stronger and will apply more force on the clutches. If you use carbon fiber frictions ($$$) from ford racing, they will last a lot longer than the factory ones. I believe they put these stock in the 03/04 Cobras.
-Rob EDIT: I should add, with these mods, the LS won't be quite as street friendly and smooth as stock, but it is more forgiving than a locker. __________________ 1991 Explorer EB 4x4- 3" BL, 31" BFG a/t's, m5od, Warn manual hubs 1996 Explorer XLT 4X4(R.I.P. 1-27-07) - Rollover posse applicant (http://www.explorerforum.com/forums/...d.php?t=177801) 1989 Cougar XR7 |
#8 |
So what I am understanding here is that it doesn't make sense to rebuild the LSD because it really doesn't work all that great anyways.
What is the cheapest and best advice for me to make this explorer have traction. I don't off road a lot. I do have a boat and I use the explore to pull the boat. It is used when I go hunting. So I am not a big die hard off road driver, but I don't want to get stuck like I have been and have some one with a truck pull me out. |
#9 | |
Lebanon,Ohio
'91 EB & '96 xlt
Quote:
When I built the rear end in my Tbird, (8.8" LSD) I re-stacked the frictions, but did not go with the heavier spring. It works great and is very friendly on the street. It withstood me drag racing with it all last summer and still works great. I got the frictions from www.supercoupeperformance.com . If you can do this stuff yourself, you will save a lot of labor $$ and it is pretty easy. You don't even need to have the carrier out of the rear end to change the clutches. -Rob __________________ 1991 Explorer EB 4x4- 3" BL, 31" BFG a/t's, m5od, Warn manual hubs 1996 Explorer XLT 4X4(R.I.P. 1-27-07) - Rollover posse applicant (http://www.explorerforum.com/forums/...d.php?t=177801) 1989 Cougar XR7 |
#10 |
Spokane WA
4wd should be plenty of traction with decent tires. If you need more I'd start by rebuilding the LS and see if that does it for you.
#11 |
Land of Corruption
06 F-350
I agree with 91EX4X4, just rebuild the LSD you have. 4 wheel drive and good tires are plenty for the use you describe. A locker in your circumstance would be overkill. The carbon fiber frictions are $128.95 from Ford racing.
#12 |
Where is the cheapest places to buy all the parts that I will need?
Any schematics or diagrams would be helpful. Does the explorer come with LSD in the front? If so, I think I should rebuild it as well. thanks |
#13 | |
Land of Corruption
06 F-350
Quote:
There is no LSD in your front differential. Maybe not rebuild, but, how about a fluid change? Personally, I used the Motorcraft synthetic that the factory used. Available at your local Ford stealership. Try the search feature, maybe you can find one here. I know theres a boatload of information about the LSD on here, but as for diagrams? I dont know, probably are some photos of a rebuild here somewhere. Try searching 8.8 LSD rebuild or something similar __________________ 1999 Mountaineer, RIP
Last edited by my pos mounty; 12-23-2009 at 08:32 AM. Reason: Forgot to include somethin somethin, spellin errors too |
#14 |
* Fits all 8.8" Traction-Lok differentials
* Kit includes carbon fiber clutch pack, shims, S-spring and instruction sheet * Carbon fiber discs designed for higher torque usage * Used in 2003-2010 SVT Mustangs I went to the website (ford racing) But the frictions that you are talking about says it is for a mustang(posted above)? So do you know where I could buy ones for my vehicle. |
#15 | |
Lebanon,Ohio
'91 EB & '96 xlt
Quote:
"Fits all 8.8" Traction-Lok differentials" -Rob __________________ 1991 Explorer EB 4x4- 3" BL, 31" BFG a/t's, m5od, Warn manual hubs 1996 Explorer XLT 4X4(R.I.P. 1-27-07) - Rollover posse applicant (http://www.explorerforum.com/forums/...d.php?t=177801) 1989 Cougar XR7 |
#16 |
So I guess I have the 8.8 Traction-Lok differentials.
Is there a way to verify that in fact I do have that type of differential or is something that ford always used. |
#17 | |
Land of Corruption
06 F-350
Quote:
http://www.latemodelrestoration.com/item/M4700C On sale for $109.99 __________________ 1999 Mountaineer, RIP
#18 |
Gardner ks
97 xj
What do your tires look like before you go digging into your diff, having tires with good tread and a pattern that will work in the snow is much more beneficial then having a limited slip. Most of the time your better off to have open diffs in snow so the back end is not sliding around on you.
__________________ 97 Heep Cherokee 01 explorer sport 2wd |
| Thread Tools | |
