Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
97 4.0 SOHC- AC elimination/bypass???
Reply
Thread Tools
Old 12-23-2009, 05:45 AM   #1
brnltjo
Columbia, PA
97 XLT
Vehicle Specs
(Original Poster)
What is the part # or length of a new belt(any manufacurer) to bypass the a/c compressorre in place of the stock one? In 94' Ford had a "w/o a/c option/routing", but doesn't in 97'. The compressor is definitely locking up and the pulley bearing is froze and tearing the belt. I just want a cheap fix, don't need or want a/c. . Is it easier just to remove compressor and get a bypass pulley? Seems someone would have a smaller belt that would work for that year/model. I tried to trace a string around new belt path, but almost entirely impossible due to lack of room! Ford Service/Parts were no help either. Thanks in advance!
brnltjo is offline   Reply With Quote
Old 12-23-2009, 06:09 AM   #2
CASTLE95X
Houston, but in Anchorage w/ Army for now
'95 EX XLT 4DR
Vehicle Specs
Is the a/c comp clutch locked up? Try disconnecting the clutch control wire from the comp.
__________________
'95 EX ON 31S NEEDIN SOME LOVE
'10 SPORT TRAC BONE STOCK
CASTLE95X is offline   Reply With Quote
Old 12-23-2009, 06:26 AM   #3
brnltjo
Columbia, PA
97 XLT
Vehicle Specs
(Original Poster)
Yup...clutch is locked up and wire/plug has been disconnected. Pulley/bearing is 90% froze. Entire engine compartment is covered in blackish brown belt dust.
Old 12-23-2009, 01:39 PM   #4
CASTLE95X
'95 EX XLT 4DR
Vehicle Specs
the oreilly web site has a pt # for a belt without a/c masterpro K060810 but that is for a 4.0 pushrod engine on a 95, when i tried to put in a 97 it had three options, 4.0 pushrod, 4.0 ohc, and 5.0 pushrod. you also might have to get an idler pulley to go in place of the comp www.oreillyauto.com www.rockauto.com www.partstrain.com www.lmctruck.com these sites may be able to help. ld look but i got an appt.
__________________
Old 12-28-2009, 06:59 AM   #5
brnltjo
Columbia, PA
97 XLT
Vehicle Specs
(Original Poster)
thanks Castle
Old 09-03-2010, 12:13 AM   #6
mdak
Willow Ak
2000 Eddie Bauer
Vehicle Specs
2000 ford explorer eddie bauer. 4.0 need to bypass ac with a new belt. I have no idea what to do or how to get one. Will schucks or napa know???
mdak is offline   Reply With Quote
Old 09-03-2010, 07:20 AM   #7
brnltjo
Columbia, PA
97 XLT
Vehicle Specs
(Original Poster)
what i did was trace the belt route w/o AC pulley with a piece of heavy string and take measurement to Autozone to buy a belt that size. Be prepared, when you restart the truck, the power steering will probably chatter/shake. This is air that needs to be "worked/driven" out. I didn't realize this so I scrapped the simple and cheap belt bypass idea and bought a AC bypass pulley. With this you need to totally disconnect the AC compressor and mount the bypass pulley and new factory sized belt. Works like a charm. AdvanceAuto had the pulley for around $30.
Old 10-24-2010, 01:49 PM   #8
venice914
Las Vegas, NV
1997 EB
Vehicle Specs
I just did this on my 97 4.0 SOHC, going with the shorter belt and bypassing the AC compressor completely. Now my idle is hovering around 500-600RPM and it's dying out when I'm not on the gas. Any idea on what it could be?
Thanks in advance.
venice914 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
