EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Loose Gas Cap Warning Light
Reply
Thread Tools
Old 12-26-2009, 09:54 AM   #1
sjmst
Long Island, NY
2007 Limited
Vehicle Specs
(Original Poster)
This keep coming on, 2007 Explorer Limited V8. After a while my check engine light icon lights up. My mechanic checked the systems and all seemed fine, so he reset the light. For about a week no problems, then the loose cap light keeps popping up (no check engine light yet). Truck runs 100% perfect except for the light.
Any ideas as to what this could be?
Thanks
sjmst is offline   Reply With Quote
Old 12-28-2009, 01:31 PM   #2
Riken
Vehicle Specs
i could be any leak in the gas tank/filler neck. my 98 has a gas tank pressure sensor, i think your will be similar. if the ecm closes all the vent solenoids, then takes some pressure samples, then compares them. i'm assuming its pointing the finger at the gas cap whenever it detects a vapour leak. those codes won't tell you whats wrong. you have to know how to interpret them.
take a regulated air supply, set it to no more than 1-2 psi and put it in your filler neck and seal it somehow, plastic bags, anything. then have someone listen under the truck for any sounds of a leak or strong gas odors.
Riken is offline   Reply With Quote
Old 12-28-2009, 02:06 PM   #3
sjmst
Long Island, NY
2007 Limited
Vehicle Specs
(Original Poster)
Thanks!
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
