#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1997 Ford Explorer 2 door 4.0L SOHC knock.
Reply
Thread Tools
Old 12-29-2009, 02:02 AM   #1
mike97ford
1997
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US 1997 Ford Explorer 2 door 4.0L SOHC knock.
Hello! I hope maybe I can get some help, the 4.0 I have has a knock like a diesel engine. It started about 24000 miles ago. I dont understand, the oil pressure is good, no pully problems. And runs the best. any ideas? I refuse to agree thats the nature of the horse...
mike97ford is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-29-2009, 07:28 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section. Don't rely upon the reading of the stock pressure gauge or indicator light. Remove the sending unit, and screw in a test gauge to get an accurate PSI reading.
BrooklynBay is offline   Reply With Quote
Old 12-29-2009, 10:05 PM   #3
robertoa1a
Jacksonville, FL
96 5.0 xlt 2wd white/char
Vehicle Specs
Quoted: 0 Post(s)
For starters I would use the highest auctane fuel as that will reduce the knock. Most likely the cause is carbon build-up in the combustion chamber. The carbon gets hot easy and creates hot spots that can cause a dieseling situation.
Secondly I would make sure you have the Motorcraft or autolight thin wire plugs. the other ones are less than satisfactory.
How did the carbon get in the C/C? Poor firing for a long time.
How to get it out. Well you can pull the heads and clean it out. If it is physically imposable for you to do that then you can try A can of Sea Foam (plenty of threads here and for good reason). The look of your plugs tells a story.
robertoa1a is offline   Reply With Quote
Old 12-30-2009, 06:51 AM   #4
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
Knock location?
Are you sure that you're not hearing timing chain rattle?
Does the knock sound external to the engine? Are the motor mounts in good condition? Could it be coming from the exhaust system being loose? Have you modified the intake system with no allowance for engine movement?
Does the knock sound internal to the engine? Have you maintained the oil system properly? Have you checked the oil level frequently making sure it is never low? Changed the oil filter and oil at normal intervals? Does the knock sound low or high in the engine? Does it change with engine speed?
The SOHC is equipped with a knock sensor to prevent detonation. It causes the PCM to retard the ignition advance when knock is detected. You should not hear any knock due to fuel if the knock sensor/PCM is working correctly.
2000StreetRod is online now   Reply With Quote
Old 12-30-2009, 10:45 PM   #5
mike97ford
1997
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US The 97 Explorer that knocks
Well, Here is what this Explorer does, When its cold out like this morning (ohio) 24... There was not knock one,,,but once she warmed up it started and the warmer it got the louder it gets... Could it be lifters? Cam? A couple of friends say there known for the lifters. The 4.0 that is...Hey folks thanks for all your help
Old 12-31-2009, 06:34 AM   #6
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
Tick vs knock
Doesn't match timing chain rattle which is worst when engine is cold. Valve train noise usually sounds more like ticking than knocking. Piston pin and piston knock is usually the worst when the engine is cold. The power steering pump, water pump and A/C compressor can sometimes produce a knock. Connecting rod bearing knock is louder when the engine is unloaded. Main bearing knock is louder when the engine is loaded. The air conditioner compressor is useful in loading the engine when listening for knocks. You can use a two or three feet long hose to listen with and try and isolate the source of the knock. You can remove the serpentine belt and run the engine for a minute or two to eliminate the alternator, water pump, power steering pump and A/C compressor as the source. Has the knock gotten any louder in the last 24,000 miles?
Old 01-22-2010, 02:10 PM   #7
Mitzi
St. Louis, MO
1997 Ford Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
Not sure where to post this...
I just got a 1997 Ford Explorer Sport 4wd. It has a clicking or higher pitched knocking (constant, sounds like it comes from the top or front of the engine). It sounds plastic-y and it never stops.
I just got the vehicle so I don't know how long it has been doing this.
I started pricing engines and it seems that they aren't plentiful - the ones I have found have very high mileage. The cheapest is $700 for a motor with 110k.
I was going to replace the engine because I thought it would be cheaper than the labor costs of having a mechanic seek out the problem and fix it.
Any thoughts?
Mitzi is offline   Reply With Quote
Old 01-25-2010, 02:13 PM   #8
Mitzi
St. Louis, MO
Vehicle Specs
Quoted: 0 Post(s)
The guy who sold it to me said he thinks that it is the "caskets" that guide the timing chain. Has anyone heard of this?
Old 01-25-2010, 08:19 PM   #9
2000StreetRod
Greenville, SC
Vehicle Specs
Quoted: 45 Post(s)
Cassettes not caskets
Quote:
The mechanic probably meant cassettes that include the timing chain, sprockets and guides. The cassettes are shown in the photo below.
Old 01-25-2010, 09:20 PM   #10
Mitzi
St. Louis, MO
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Attachment 57907
Thank you! There is tons of info when I google that as opposed to 'caskets'. Thanks again!
Old 03-10-2010, 04:53 PM   #11
wow97
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
hearing timing chain rattle? every morning when i start my 97 ford explorer xl 4-door fulltime awd with 5-speed automatic 4.0 e.f.i what the deal
Old 03-10-2010, 08:13 PM   #12
03silversvt
Pa
99 mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Quote:
best way for the guys on here to diagnose your problem is to get it on video tape and post it up on here. Thats what i did awhile ago and the guys were pretty much dead on being one of the tensioners. I just got around to opening the engine up and it was the balance shaft tensioner that was broke
03silversvt is offline   Reply With Quote
Old 03-11-2010, 04:25 AM   #13
wow97
Unregistered
Posts: n/a
Vehicle Specs
Quoted: Post(s)
hearing timing chain rattle? every morning when i start my 97 ford explorer xl 4-door fulltime awd with 5-speed automatic 4.0 e.f.i what the deal DOES ANYBODY HAVE PICTURES THANK YOU
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
